Fxx-/Ixx-/Gxx-series help please with INPA - Bimmerfest - BMW Forums
Old 12-07-2019, 08:46 AM
blink_ blink_ is offline
Car Nut
Mein Auto: 750LI & Opel Astra Turbo
hi
I just ordered an ethernet cable and software from bcables.com, its arrived but without the software. (for my F02 2014)
Since im having problems with the car, can anyone point me to where i can download the software? I have downloaded v5 but it wont let me access the airbag module (plus others), plus its all in German
Thanks in advance
Old 12-07-2019, 08:52 AM
EdgaBMW EdgaBMW is offline
Mein Auto: BMW
Download rheingold (ista-d)
Old 12-07-2019, 10:06 AM
Car Nut
thanks, I think technology is getting the better of me, I had it downloaded, but the instructions to install it dont correspond to the software, so I found it elsewhere, and at 13gig it says it needs 500gig of disc space, which I dont have.
Old 12-08-2019, 12:30 AM
Mein Auto: BMW
500 gigs is with istap, no need it. Download just istad, itís arround 100gb
Old 12-08-2019, 02:14 AM
Car Nut
I did wonder because the download is only about 13 gig. Gonna try it later on. Bought a new ssd, been low on space for a long time tbh. Thanks for your help
Old 12-08-2019, 11:14 AM
Car Nut
I have got the files, followed the instructions, but when i run istagui as administrator, nothing happens, but it creates a log file like this
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.ConfigSettings() - called
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.OperationalMode" from "" to "ISTA_PLUS" (read from "Configuration file").
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.ConfigSettings() - OperationalMode is ISTA_PLUS
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Logging.RotatingTextWriterTraceListe ner.FileName" from "" to "" (read from "").
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Logging.Directory" from "" to "..\..\..\Logs" (read from "Configuration file").
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Logging.Directory" from "..\..\..\logs" to "..\..\..\Logs" (read from "Configuration file").
2019-12-08 18:11:51 INFO [T] ISTA: [1] App.StartIstaServices() - Try to start ISTA Services host ...
2019-12-08 18:11:51 INFO [T] ISTA: [1] IstaProcessStarter.Start() - called.
2019-12-08 18:11:51 ERROR [T] ISTA: [1] IstaProcessStarter.Start() - Failed to start ISTA operation. Reason: "System.TypeInitializationException: The type initializer for 'BMW.Rheingold.CoreFramework.CoreFramework' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'RheingoldCoreBootstrap.dll' or one of its dependencies. The specified module could not be found.
at BMW.Rheingold.CoreFramework.CoreFramework..cctor()
--- End of inner exception stack trace ---
at BMW.Rheingold.CoreFramework.CoreFramework.get_Debu gLevel()
at BMW.Rheingold.CoreFramework.Log.Debug(String method, String msg, Object[] args)
at BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessB ase`1.Initialize(String[] args)
at BMW.ISPI.IstaServices.Host.IstaServicesProcess.Ini tialize(String[] args)
at BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessB ase`1.Perform(String[] args)".
2019-12-08 18:11:51 ERROR [T] ISTA: [1] App.Init() - Failed to start ISTA: BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessS tartException: Failed to start ISTA operation. Reason: "System.TypeInitializationException: The type initializer for 'BMW.Rheingold.CoreFramework.CoreFramework' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'RheingoldCoreBootstrap.dll' or one of its dependencies. The specified module could not be found.
at BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessS tarter.Start[TArgs](String pathToIstaProcessFile, TArgs istaProcessArgs)
at BMW.ISPI.IstaServices.Controller.IstaServicesContr oller.StartHost(IDictionary`2 configuration)
at BMW.Rheingold.ISTAGUI.App.StartIstaServices(LogCle aner logCleaner)
at BMW.Rheingold.ISTAGUI.App.Init()
at BMW.Rheingold.ISTAGUI.App..ctor()
Old 12-08-2019, 03:14 PM
Car Nut
sorted it now, in case anyone else comes up against this, it turned out that Mcafee was quarantining the file without telling me
