Parting out 1992 535i Manual - Michigan - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds
Classifieds
Post for sale items in one of the for sale categories. Click here to browse new posts.
Old 11-11-2013, 05:31 PM
92-535i-Manual 92-535i-Manual is offline
Mein Auto: 1992 BMW 535i Manual
Yes, I know this was posted within another thread, but I felt it would do a better job on it's own. Sorry for those whom have already seen this.
I am parting out my 1992 Black 535i Manual - Grand Rapids, Mi
Interior: (Parchment)
Front door skins - 40
Steering wheel airbag - 45
Fog light switch - 5
Glove box (w/ working latch!) - 25
Sunroof motor - 20
Door: (all from passenger rear)
Window motor - 35
Actuators - 15
Door handle w/ trim - 5
Glass - 10
Lights:
Low beams (w/ bulbs) - 25
High beams (w/ bulbs) - 25
Turn signals (w/ bulbs) - 10
Front end:
Grille (w/ inserts) - 30
Headlight surrounds - 10
Front bumper support - 50
Radiator Support - 10
Washer Fluid Reserve - 15
Air box w/ new filter - 30
Radiators: both w/ fan shroud - 75
Drivers side front fender (black) - 25
Side mirrors - 25
Steering & Suspension:
Front brake assembly: Rotors, Pads, (both <1k miles w/ new sensor), & Calipers - 50
Racing Dynamic Front Sway Bar: 27mm - 100
Lower control arms (<5k miles) - 25
Upper control arms (<5k miles) - 50
Center tie rod (<5k miles) - 50
Tie rod ends (<5k miles) - 25
Pitman arm (<5k miles) - 10
Engine Compartment and other things:
Drive shaft (new center support & bearing) - 150
5-speed Getrag Manual Trans (w/ linkage) - 300
ABS pump - 30
AC compressor - 40
HVAC blower motor - 20
Coolant reservoir - 10
Rear End:
Trunk lid (w/ bulbs) - 50
Taillights (w/ bulbs) - 40
Fuel pump (new filter) - 50
Bumper trim - 20
Spare tire - 30
Modules:
ECU - 45
ABS control module - 30
Relay Module (RM) ending in 741 - 10
Light Control Module & Relay (LKM–L) - 15
Cruise Control Module - 10
Check Control Module (CCM) - 5
Stereo Amplifier - 40
Security System Control Module - 20
I have tried to make this list as accurate as possible, but if you don't see it on here, just ask and I can tell you if I have it or not.
As things are bought I will delete them from the list.
ID:	406963   Click image for larger version
ID:	406964   Click image for larger version
ID:	406965   Click image for larger version
ID:	406966   Click image for larger version
ID:	406968   Click image for larger version
ID:	406969   Click image for larger version
ID:	406970   Click image for larger version
ID:	406971   Click image for larger version
ID:	406973   Click image for larger version
Old 11-11-2013, 05:35 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
Fuel Tank?
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 11-11-2013, 05:39 PM
Sadly no. I did not think to keep that (even though it was in great condition).
Old 11-11-2013, 05:47 PM
Nothin like an E34
I bought one "like new/reman" it had a 2" hole, wrinkled, and had rust. Mine is rusted in half, and has many holes in it.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 11-11-2013, 05:48 PM
Sorry about the bad luck. Mine was definitely solid.
Old 11-15-2013, 11:14 AM
mtlay mtlay is offline
Mein Auto: 1992 BMW 525i
Re: Parting out 1992 535i Manual - Michigan
Will the cluster and headlight switch fit a '92 525i? If so, I'll take them. PM me?
Sent from my SPH-L720 using BimmerApp mobile app
Old 11-15-2013, 12:01 PM
Yes it will. PM me with your email address.
Old 11-15-2013, 02:49 PM
Dionte Dionte is offline
Drive her like an ///M
Mein Auto: 1992 BMW 535i (manual)
OEM front floor mats? Could I see a picture?
Sent from my SGH-T839 using BimmerApp mobile app
1992 535i 5-Speed
1984 533i 5-Speed
Douglasville, Georgia
