Dot 4 brake fluid - Bimmerfest - BMW Forums
Old 04-16-2019, 10:08 PM
pastman pastman is offline
Mein Auto: 2007 328xi
Dot 4 brake fluid
I'm about to replace calipers, rotors and pads on my '07 328xi coupe. With 214K on the car, I think it is well-deserved. Question: are all DOT 4 brake fluids created equal? Any opinions out there on what to avoid (if that's possible) or to recommend? Please advise.
Pastman
Old 04-16-2019, 11:14 PM
gbalthrop gbalthrop is online now
Mein Auto: 2007 328xi E91
Have you bled system every 2 years as BMW recommends? Have you used "Low Viscosity" DOT 4 fluid as BMW recommends? I have NO IDEA how critical either is to preventing fluid boiling issues from water absorption, leaking caliper seals, or any other issues with the system. Here is an example of the options available. If anyone has an engineering-based opinion on which one is the best value and why, please advise:
https://www.autohausaz.com/catalog/k.../brake%20fluid
As for replacing calipers or rotors, my thoughts:
1) Calipers: Unless they leak or are sticking so as to pull when you apply or release brakes, or one or more feels noticeably hotter than the others after a 10 minute run in traffic (a sign of sticking), I would NOT replace a caliper "just because" of age or mileage.
2) Rotors: TIS & Bentley provide minimum thickness specs, and unless a disc is at or below minimum thickness, or causes "Judder" when braking due to "runout" or glazing issues, or has obvious rust or structural issues, I also would NOT replace Rotors "just because." I have seen cheap replacement rotors cause Judder issues within a year of being installed, where there were NONE before.
Your car & your money/time. I'm a "bottom-fisherman" (cheap) and basically don't "fix" something until wear specs, or performance/ safety concerns appear, suggesting it's "broke."
Please let us know your thoughts & reasoning,
George
Old 04-17-2019, 07:09 AM
08 335Ci 08 335Ci is offline
Mein Auto: 2010 335 M sport
I suggest you consider changing your flex lines while the system is apart. After 12 years and 214K I'm sure they need it. ECS has reasonable SS kits.
Also replace the caliper 'pins', they do wear.
Make sure the fluid says 'low viscosity' or 'For ABS use'. If you're not using BMW fluid, make sure you get all the old stuff out. Some fluids don't play well together. Buy extra fluid and make sure you cycle the ABS pump during the bleed.
No matter how fast I go, there's always someone slower in front of me.
2010 E92 335 M Sport, Titan Silver Metallic, Steptronic, JB-4 G5 ISO, WMI, 3.5 Tmap (22 psi boost), BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC, Escort Max 360
Gone, but not forgotten ( totaled)
'08 335 E92, M-Sport suspension, 6 sp auto, w/paddle shift
CCA Member 109065
CQ ... CQ...Kilo Charlie 3 Bravo Whiskey Zulu calling CQ
e 92 brake fluid
Similar Threads
the VERY best of E39 Links chivas E39 (1997 - 2003) 107 12-29-2018 05:09 AM
E39 Front Brake Caliper Rebuild DIY stinkpalmd E39 (1997 - 2003) 68 05-07-2017 01:26 PM
DIY: 1998 BMW 528i Brake Hydraulic System Overhaul (6 Hoses, Caliper Seals/Boots) cn90 E39 (1997 - 2003) 88 12-28-2016 10:59 AM
DIY: BMW 650i / 645Ci / E63 / E64 Brake Pad and Rotors Yorgi 6 Series DIY 93 09-09-2016 11:06 AM
In a case of brake system fails t_clealy 7 Series - E65 / E66 (2002 - 2008) 32 09-20-2010 06:07 AM
