65th Inpa error - Bimmerfest - BMW Forums
Old 04-17-2019, 09:19 AM
Edvinac Edvinac is offline
Mein Auto: BMW 523i e39 manual
65th Inpa error
BMW e39 523i 98' Hey guys, can anyone help me with this dreaded code? Already changed the camshaft sensor to oem but did not change much... Read somewhere it could be the timing(was not touched for the time I have my car(over 2 years)), some say it is vanos seals.. I am lost to what is the answer to this
Old 04-17-2019, 12:16 PM
djbecker djbecker is offline
Mein Auto: e30,e34,Z3,e39
Is that the only error?
What was the condition when it was report? Does the engine run?
The camshaft sensor wasn't reporting the expected pulse, but it happened only once at very low RPM. And from the low system voltage, it might have been cranking. I assuming that it had been running from the reported temperature. The sensor might be magnetically "contaminated" (rust, residual magnetism, magnetized camshaft) so that it's not reading accurately at low speeds, but it is likely working OK at normal running speeds.
Old 04-17-2019, 02:38 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
have you reset the code and see if it returns or not? your battery is showing 10.61 vdc...any idea why?
99 528i 5sp sport
be alert...the world needs more lerts
Old 04-17-2019, 03:00 PM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
+1 mattmar1
10.61 v is very low voltage, whether the engine is running or not.
Check test your battery/alternator. Recharge it and/or replace it. Then test again.
<=E39=>
Old 04-18-2019, 09:48 AM
The voltage is low because it appears while cranking as someone already said. Everything else seems ok. Only had few random deaths of the engine. Code always comes back after clearing
Old 04-18-2019, 01:40 PM
But if there is a code at low rpms, does it not intefier while driving? P.S. you're the only one realised that's the cranking voltage not stable one
Similar Threads
'08 with multiple error lights, troubleshooting with INPA chrisificti0n X3 E83 (2004 - 2010) 0 11-23-2018 07:04 PM
LCM II internal error, no check engine light 528iAut E39 (1997 - 2003) 4 10-09-2018 09:16 AM
Easy straight forward software for K+DCAN? SenadG E90/E91/E92/E93 (2006 - 2013) 37 08-14-2018 07:07 PM
Limp Mode INPA Error Codes Help - Danny1x E90/E91/E92/E93 (2006 - 2013) 5 05-13-2018 11:09 PM
INPA not Error with N62 Engine Campbellsignal E60 / E61 (2004 - 2010) 6 05-09-2018 07:29 PM
