Carly recommended settings - Bimmerfest - BMW Forums
Old 06-15-2018, 01:37 PM
chitown312 chitown312 is offline
Mein Auto: 2011 x5 v8 M adapative
What are some recommended Carly settings?
So far I set the allow video while in motion and have removed the disclaimer on the nav upon starting.
Old 06-15-2018, 01:42 PM
ATL Markus ATL Markus is offline
Mein Auto: 2013 X5d
I set the one-touch indicator to 5 blinks and I set the tailgate to open and close from the dash button and remote.
I fiddled with having the side mirrors fold in when locking (and open upon unlocking) but there are times when i do not want them to unfold until I have moved away from the wall in my garage, so I went back to manual operation for those.
For your video in motion, do you have rear seat entertainment, or is this for the dash screen?
Old 06-15-2018, 01:49 PM
I don't have the rear seat entertainment. Just did the dash.
I tried the trunk close option but it didn't work out. I'll revisit it over the weekend cause that would be useful.
Old 06-15-2018, 04:24 PM
giaka giaka is offline
Mein Auto: 2009 X5 3.0
I set the mirrors to fold if you hold the lock button for 1.5 seconds (they unfold with just a press). Turned on digital speedo, turned of voltage monitoring on just about every light bulb so I could run LEDs. Set the windows to fully open with the sun roof if you hold unlock and fully close on holding lock. Set the third brake light and inner brake lights to flash with the dynamic braking thing (haven't tested it). Turned off the disclaimer. I thought my hatch already opened and close with the inside button. I need to double check that.
Old 06-15-2018, 06:06 PM
cvgtpc1 cvgtpc1 is offline
Mein Auto: 2002 E39, 2008 E70
How did y'all turn off the disclaimer, in the CCC module?
cvgtpc1
- 08 E60 LCI 528i - VIN: C112981, Engine: N52K, MONACOBLAU METALLIC, Prod.date: 2008-05-15
- 08 E70 X5 3.0Si - VIN: L008866, Engine: N52K, TITANSILBER METALLIC, Prod.date: 2007-12-22
RIP 04/23/18
- 02 E39 525i
Old 06-16-2018, 06:45 AM
mr_robot mr_robot is online now
Mein Auto: E53 4.8iS
You enter the iDrive menu on the app and for me that was the only option available.
Sent from my iPhone using Tapatalk Pro
Old 06-16-2018, 09:35 AM
Tried that already and said I must have iDrive...so think something is up with my iDrive.
cvgtpc1
RIP 04/23/18
- 02 E39 525i
Old 06-16-2018, 09:37 AM
Does the speed then show on the center display between the speedometer and RPM gauges?
cvgtpc1
RIP 04/23/18
- 02 E39 525i
Old 06-16-2018, 02:27 PM
Anyone have the digital speedo dash picture? Does the dealer frown on this if the car is still under warranty?
Old 06-16-2018, 07:44 PM
I get what's in the pic. Can you see iDrive in coding on your Carly? Emailing Carly to see what's up.
cvgtpc1
RIP 04/23/18
- 02 E39 525i
Old 06-16-2018, 07:53 PM
Yes mine can and I disabled the disclaimer warming message on startups.
Old 06-16-2018, 07:56 PM
The kicker is my E60 has the same issue as my E70. Can't get into iDrive either. Hopefully Carly tells me a solution.
cvgtpc1
RIP 04/23/18
- 02 E39 525i
Old 06-17-2018, 12:13 PM
Yes something like V = xx
Old 06-17-2018, 03:38 PM
Can you elaborate on the voltage monitoring for LEDs? I switched out my interior bulbs to LED and they seem to work fine without flickering.
On the other hand, I tested out bright LED reverse bulbs but they kind of flicker after starting the car even when not reversing. I see something in Carly for the reverse light which i could set. Wonder if the setting is a sure thing. I don't want to get pulled over that my light is flickering.
Im going to leave the old fashioned light bulbs for the brake lights. They seem to work well. Sad thing is I had a 2004 330ci coupe and that came with stock LED tail lights. I mean they weren't just LED bulbs the entire enclosure was made with dispersed LEDs. 7 years later my 2011 x5 has bulbs.
Old 06-17-2018, 07:02 PM
Im not 100% sure where the setting is in Carly (I shipped my Carly to my son so he could setup his M3 and X5) but there is an option for voltage monitoring and error reporting for each exterior light. The interior lights are not monitored from what I can tell but all of the exterior bulbs are. So when you start your car the voltage check causes them to flash several times. I turned off Voltage Monitoring and Error Reporting for all the exterior lights.
Old 06-18-2018, 09:56 AM
By chance is there an exterior light test mode so I could test exterior replacement bulbs, like the backup lights without getting a hand from another person?
Old 06-18-2018, 09:59 AM
Example
Old 06-18-2018, 10:03 AM
Example
Do you find it helpful/useful?
Old 06-18-2018, 10:15 AM
No I wish we could toggle voltage and temp instead. Its about as useless as that MPG gauge under the tach.
Old 06-18-2018, 12:39 PM
Ozer's Avatar
Ozer Ozer is offline
Mein Auto: 2011 X5 diesel
I code my headlight washers on for winter and code them off for summer.
Increased the halo voltage to high since i have yellow halogens, it makes them brighter.
Changed bunch of things for both keys.
My wifes key has the fog light turning illumination where as i hate it so i disabled that. People think your foglight is out. I have LEDs in there.
The speedo, windows up and down with remote, tailgate, 5x turn signal, welcome light settings and so on..
Old 06-18-2018, 02:07 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Moment to moment voltage is useless and meaningless.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 06-18-2018, 02:17 PM
In your world.
Old 08-15-2018, 05:34 AM
0-60Motorsports 0-60Motorsports is offline
Mein Auto: E46 M3
So are most of you using the Android or Iphone Version. I have both types of phones so was thinking which version to pick up. I guess Android is cheaper......
Current Mods: Eibach Pro Kit, Eibach AntiRoll Bar kit, INTRAVEE II + Alpine KCA-420i, EAS B & W Roundel Kit, EAS Monochrome M3 Badges, Depo Smoked Signals, EAS Screen protector for OEM 16:9 display, H & R 12mm & 10mm spacer kit, VCSL Bumper + Race Lip, V-GTS3 Hood CF, VCSL CF Boot, VCSL CF Rear Diffusor, DIETZ TV in Motion, Streamline Panel Filter, AP Muffler, Z8 Starter Button, BBS CH 19", Lamin-X, GM SMG Paddles......
Old 08-15-2018, 08:43 AM
Jersey John Jersey John is offline
Mein Auto: 2013 X5 xDrive35i Premium
Has anyone been able to do any utilize the transmission feature in the latest version?
"So many faces in and out of my life. Some will last, some will just be now & then. Life is a series of hellos and goodbyes, I'm afraid it's time for goodbye again" - Billy Joel
"If winning isn't important, the why keep score"
Every day I'm reminded that Common Sense isn't common.
Old 08-15-2018, 08:44 AM
sunny_j's Avatar
sunny_j sunny_j is offline
bmw addiction
Mein Auto: X5d
I would rather get Bimmer Geeks ProTool as it's a 1 time fee unlike Carly which is subscription based now
2012 X5d | White on Black | Sports Package | EGR/DPF/SCR Delete | BRR Tune | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Log
https://www.bimmerfest.com/forums/sh....php?t=1290337
