My. First bmw. 110000 on the clock 120i e87 .very nice but as a issue with camshaft sensor exhaust code 2b63 .cam sensor changed but engine light keeps coming back on .when cleared as anyone had this problem and how was it fixed . mine is a 2006 model.thank u
there's 2, wondering if you have a faulty one, think there the same thing , you could try swapping them over,
inlet and outlet, see if the fault moves
where did you get it from, was it OEM ? cabling ok ?
are you getting any other codes ? or other symptoms, I've seen several threads even after swapping the parts has not resolved
let us know what other codes are stored and what other symptoms.
(I know from your PM) you swapped the sensors and the code has stayed the same
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
