Can anyone answer this quicky? My wife has a BMW 118d 2008 that has a BMW Business stereo. Can this be fitted with a CD Auto Changer? I bought and fitted an emulator that allows an iPod connection, but although it charges the iPod I get no sound when the iPod plays. I've tried coding in the CDC with NCS Expert but it does not appear to take the changes.
I can’t find a clear answer online but from my experience sg_reset doesn’t code the module, it just reboots it. You’ll need to do sg_codieren with an empty psw_fsw.man file for $672 to take hold.
Thanks for the feedback. The sg_reset should force the module to re-read the VO and pull any changed information from there. This does appear to work ok, as the 1RAD module changed the CDC line item from "nicht_aktiv" to "aktiv" and all I did was sg_reset. Pulling the VO from CAS and NFRM also now shows the $672 applied.
As it happens I'm going to back out the $672 as it appears to have fooked the park distance control sounds.
Yeah, my German is definitely nicht aktiv! From some more googling, and trawling the module descriptions in NCS Dummy it appears I'm on a hiding to nowhere. Think I'll just have to go back to using the AUX IN for the iPod and my better half will just need to forget about the tempting steering wheel controls.
Now that I have removed the $672 from CAS and NFRM and re-run the SG_RESET against 1RAD, the 1RAD module is again showing "nicht_aktiv" against CDC. The park distance control is still not functioning. I re-checked the 1RAD module and PDC is set to "aktiv", not sure what else to do now.
Guess I'm in trouble!! I've broken the missus' car ....
Thanks for the suggestion, but if the module is not responding to either INPA or NCS Expert, will any attempt at recoding, even with the factory coding profile, make any difference?
I know its been a while but have you managed to bring back the PDC? I have simillar problem only my pdc stopped working after I added $540 to VO (cruise control), written new VO to CAS, NFRM and then Sg_codieren every module with empty trc file. cruise control works fine, in INPA i can see that PDC reads distances correctly only no audio thru radio (1RAD). also my car 2007/09 LCI, using K/D CAN cable.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
