Valve adjustment video... - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 07-07-2019, 06:38 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
Fresh from the editing room:
Good food, good people, good times.
Old 07-11-2019, 10:10 PM
skuhlke skuhlke is offline
Mein Auto: E34 535i Touring
Great video and production. I donít have an M30, but if was done for an M50 engine this would be a great reference
Old 07-13-2019, 03:17 PM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
@ radian....good video, nice job. Just curious; Bentley shows placing the feeler gauge between lifter eccentric 'wheel' & valve tip. You set it between lifter & cam. Why? Is one better than the other? I have always measure between wheel & valve. Also, I liked the way you used the open end wrench & torque wrench to set torque. I just used my 'torque hand'! Very clean top end too. How many miles on it?
Here's another link for the procedure. Gale's Page
I also use a remote start on my "old' timing light & pins #11 & 14 on diagnostic socket to turn engine. I permanently marked them so I know which they are.
BMW CCA #132981 Tarheel Chapter,
Old 07-15-2019, 06:28 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
M50's use hydraulic lifters, which are self adjusting. If you are hearing the tappet (ticking), you may want to bleed your lifters, so start with the following:
- Check your oil level and quality. Should not be low or overfilled. Rubbing the oil between your fingers should be slick and smooth, no granular bits or stickiness. Light gold/brown color is good.
- Run your M50 until it is at operating temp
- Then hold the revs at 2500-3000 RPM for 3 minutes
- Let idle for 15-20 seconds
The tappet should be gone; if it isn't, repeat the process (I wouldn't do it more than 3 times). If it still doesn't work, then change your oil with the expensive, real good, BMW recommended, BMW provided, oil. then try bleeding it.
1995 525iA 250k mi
2003 350Z 91k mi - SOLD
1984 733i/5 105k mi
2014 F-150 45k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 07-17-2019, 08:22 PM
Radian's Avatar
Thanks Rav!
I set it between the lifter and cam as a matter of personal preference.
In short, it works. I used to set the thickness gauge between the eccentric and valve, but after trying the procedure out on the other side, I find the above method much more convenient and consistent.
Folks could argue the merits and pitfalls of either method. The spec is derived at the interface of the valve stem for engineering purposes, so that's what sticks in the books. Rocker arm ratio isn't always guaranteed to spec, but neither is the interface of a high mileage eccentric / valve stem assembly.
Top end has just under 60,000 miles on it. The car almost 190,000.
Old 07-24-2019, 05:11 AM
jcwhy jcwhy is offline
Mein Auto:
Just curious, Bentley specifies adjusting valves to 0.012mm (cold) but you used a .009 feeler gauge.
Any reason for this?
Old 07-24-2019, 08:55 PM
Radian's Avatar
Rocker Ratio
.009" clearance on the cam side equates to nearly .012" on the valve side.
Old 07-25-2019, 06:49 PM
Mein Auto:
BTW, did you adjust the torque setting to achieve the required 10nm on the eccentric nut while using the box end wrench as a lever?
Old 07-25-2019, 06:57 PM
Interesting question jwhyland. Explain to me how that works. I'm intrigued.
Never mind, I found it on Youtube
Sent from my SM-G930R4 using Tapatalk
Old 07-28-2019, 07:25 PM
Radian's Avatar
Yes, the torque wrench was adjusted.
On cylinder #1 you see me using the extension at 90 degrees (and fussing over trying to keep it there while applying force), which requires no calculations or adjustments from the spec.
From cylinder #5 onwards, however required calculating the required value and adjusting the wrench to the lower setting.
