428i not starting - Bimmerfest - BMW Forums
Old 04-14-2018, 08:40 PM
Schaerz Schaerz is offline
Mein Auto:
428i not starting
I have a 2014 428i coupe. I parked it last night, no issues. When I tried to start it this afternoon, it didn't with a error code "Chassis Stabilization (ABS)". Plus the brake pedal is stiff; it depresses very little (if any). Can anyone assist? Thanks
Old 04-15-2018, 03:07 PM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
A mechanic will have to read the codes. The brake pedal would be stiff with no engine assist. Was the car in an accident?
Old 04-15-2018, 03:16 PM
Mein Auto:
No accident. The car had ZERO issues when I parked it.
Old 04-15-2018, 03:26 PM
Assuming it is not out of fuel it'll have to be towed. Unless you know a good mechanic that does home calls.
Reason I asked is that ressurected auto auction cars can have mysterious maladies.
Old 04-16-2018, 07:32 AM
Mein Auto:
The tank is nearly full.
Old 04-16-2018, 07:37 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
possible the brake interlock is not disengaging? try pressing the brake pedal really hard and then starting, if the residual brake pressure is gone, you might not be depressing the brake far enough to allow the car to start
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Present: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC
Old 04-17-2018, 12:35 PM
sensistarbmw sensistarbmw is offline
Mein Auto: 2014 328i M Sport
it was my starter when that happened to me with my 08 E92. just a click click click when i hit the start button and the brake pedal was stiff
Old 04-17-2018, 05:58 PM
42Ate 42Ate is offline
Mein Auto: 428i Sport Line Coupe
go smack the starter with a wrench, if you can get a clean shot at it. May have the selinode (?) stuck
Old 04-26-2018, 07:08 AM
Mein Auto:
Clogged Drains
I took my car to the dealership. It was a bad alternator that in turn damaged the battery.
Upon further inspection the conduit from the alternator to the battery was the culprit. It was damaged causing a short circuit. Debris, mainly leaves, had clogged the drains.
I wash my car once a week and had noticed that every time I park my car after a wash, a huge puddle accumulated below. Initially I thought that it was an oil leak. I couldn't figure out where the water was collecting.
Long story short....debris clogged the drains, water accumulation led to bacteria that eroded the conduit exposing wire.
Lessons learnt: I should have followed up on the fact that every time that I washed my car, it was obvious that there were drainage issues
Alternator Replacement $1300
Battery Replacement $ 350
Conduit Replacement $950
Old 04-26-2018, 11:25 AM
Closem Joe Closem Joe is offline
Mein Auto: locally
Ugh! Sorry for your troubles.
Joe
428i coupe, chassis stabilization, not starting problem
