BMW Wont start HELPPPPP! EWS Fault???? - Page 2 - Bimmerfest - BMW Forums
Old 05-02-2013, 02:12 AM
krish0240 krish0240 is offline
Mein Auto: e39 520i
Ive been trying that for a few days. Ive tried various different versions on IPNA/EDIBAS and still get the same error codes. Ive tried different laptops and different versions on them too and still nothing.
Pictures are what I am selecting and what errors are coming up. Theyre all the same on different machines and versions.
ID:	374340   Click image for larger version
Name:	Screen shot 2013-05-01 at 19.51.48.jpg
ID:	374341   Click image for larger version
Name:	Screen shot 2013-04-27 at 19.48.39.jpg
ID:	374342   Click image for larger version
Name:	Screen shot 2013-04-28 at 22.18.07.jpg
Old 05-02-2013, 08:03 AM
HTK12 HTK12 is offline
Mein Auto: E39 540i
Then it would seem the issue is narrowed down to: wiring / connector issue, bad EWS, bad DME. I know few cases where a faulty EWS caused that no-start and that error code. You might want to remove EWS and DME connectors and inspect them for corrosion and make sure they are seated properly, if that won't solve your issue new EWS is quite cheap from the dealer (under 100), it would be worth a shot to try it. www.schmiedmann.com sells EWS for ~85. Just to be absolutely clear the battery is fully charged (low voltage can cause issues)?
FYI you can't code a used EWS from another vehicle with BMW scanner/NCS Expert.
Old 01-02-2015, 07:18 AM
AKulaRet AKulaRet is offline
Banned
Send a message via ICQ to AKulaRet
Mein Auto: Божена
***1052;***1072;***1088;***1090;***1099;***1096;** *1082;***1072; ***1089; ***1091;***1076;&
***1069;***1090;***1072; ***1087;***1086;***1090;***1077;***1096;***1085;** *1072;***1103; ***1093;***1088;***1086;***1085;***1080;***1082;** *1072; ***1089;***1086;***1089;***1090;***1086;***1103;** *1083;***1072;***1089;***1100; ***1074; ***1086;***1090;***1076;***1072;***1083;***1077;** *1085;***1085;***1086;***1084; 1989-***1086;***1084; ***1075;***1086;***1076;***1091; ***1074; ***1089;***1086;***1083;***1085;***1077;***1095;** *1085;***1086;***1081; ***1040;***1073;***1093;***1072;***1079;***1080;** *1080;. ***1055;***1086;***1089;***1083;***1077; ***1063;***1077;***1088;***1085;***1086;***1073;** *1099;***1083;***1103; ***1088;***1077;***1073;***1103;***1090; ***1080;***1079; ***1079;***1072;***1075;***1088;***1103;***1079;** *1085;***1077;***1085;***1085;***1086;***1081; ***1086;***1073;***1083;***1072;***1089;***1090;** *1080; ***1074;***1099;***1074;***1086;***1079;***1080;** *1083;***1080; ***1085;***1072; ***1086;***1079;***1076;***1086;***1088;***1086;** *1074;***1083;***1077;***1085;***1080;***1077; ***1082; ***1084;***1086;***1088;***1102;. ***1052;***1077;***1085;***1103; ***1085;***1072;***1087;***1088;***1072;***1074;** *1080;***1083;***1080; ***1076;***1080;***1088;***1077;***1082;***1090;** *1086;***1088;***1086;***1084; ***1090;***1072;***1082;***1086;***1081; ***1075;***1088;***1091;***1087;***1087;***1099; ***1076;***1077;***1090;***1077;***1081; ***1074; ***1043;***1072;***1075;***1088;***1099;. ***1045;***1097;***1077; ***1087;***1088;***1080;***1087;***1080;***1089;** *1072;***1083;***1080; ***1074; ***1087;***1086;***1076;***1082;***1088;***1077;** *1087;***1083;***1077;***1085;***1080;***1077; ***1076;***1074;***1091;***1093; ***1087;***1077;***1076;***1072;***1075;***1086;** *1075;***1086;***1074;. ***1054;***1076;***1080;***1085; ***1091;***1095;***1080;***1090;***1077;***1083;** *1100; ***1090;***1088;***1091;***1076;***1072;, ***1072; ***1076;***1088;***1091;***1075;***1086;***1081; - ***1092;***1080;***1079;***1082;***1091;***1083;** *1100;***1090;***1091;***1088;***1099;. ***1071; ***1073;***1099;***1083;***1072; ***1101;***1090;***1086;***1084;***1091; ***1088;***1072;***1076;***1072;, ***1090;***1072;***1082; ***1082;***1072;***1082; ***1076;***1077;***1090;***1086;***1082; ***1073;***1099;***1083;***1086; 30 ***1095;***1077;***1083;***1086;***1074;***1077;** *1082;. ***1044;***1072; ***1080; ***1074; ***1040;***1073;***1093;***1072;***1079;***1080;** *1080; ***1074; ***1090;***1086; ***1074;***1088;***1077;***1084;***1103; ***1073;***1099;***1083;***1080; ***1085;***1077;***1087;***1088;***1086;***1089;** *1090;***1099;***1077; ***1074;***1079;***1072;***1080;***1084;***1086;** *1086;***1090;***1085;***1086;***1096;***1077;***1 085;***1080;***1103; ***1089; ***1043;***1088;***1091;***1079;***1080;***1077;** *1081;. ***1042; ***1075;***1086;***1088;***1086;***1076;***1082;** *1077; ***1086;***1090;***1084;***1077;***1095;***1072;** *1083;***1080;***1089;***1100; ***1087;***1088;***1086;***1073;***1083;***1077;** *1084;***1099; ***1089; ***1087;***1086;***1089;***1090;***1072;***1074;** *1082;***1072;***1084;***1080; ***1087;***1088;***1086;***1076;***1091;***1082;** *1090;***1086;***1074;. ***1053;***1086; ***1085;***1072;***1089; ***1040;***1073;***1093;***1072;***1079;***1080;** *1103; ***1087;***1088;***1080;***1085;***1103;***1083;** *1072; ***1087;***1088;***1080;***1074;***1077;***1090;** *1083;***1080;***1074;***1086; ***1080; ***1088;***1072;***1076;***1091;***1096;***1085;** *1086;. ***1055;***1099;***1090;***1072;***1083;***1072;** *1089;***1100; ***1085;***1072;***1089; ***1086;***1090;***1083;***1080;***1095;***1085;** *1086; ***1087;***1086;***1076;***1082;***1072;***1088;** *1084;***1083;***1080;***1074;***1072;***1090;***1 100;. ***1044;***1077;***1090;***1082;***1072;***1084; ***1087;***1086;***1083;***1085;***1086;***1089;** *1090;***1100;***1102; ***1093;***1074;***1072;***1090;***1080;***1083;** *1086;, ***1076;***1072; ***1080; ***1103; ***1085;***1077; ***1080;***1089;***1087;***1099;***1090;***1099;** *1074;***1072;***1083;***1072; ***1075;***1086;***1083;***1086;***1076;***1072;. ***1053;***1086; ***1084;***1091;***1078;***1080;***1082;***1072;** *1084; ***1073;***1099;***1083;***1086; ***1084;***1072;***1083;***1086;. ***1050;***1072;***1078;***1076;***1099;***1081; ***1076;***1077;***1085;***1100; ***1086;***1085;***1080; ***1087;***1086;***1076; ***1074;***1077;***1095;***1077;***1088; ***1091;***1093;***1086;***1076;***1080;***1083;** *1080; ***1074; ***1075;***1086;***1088;***1086;***1076; ***1080; ***1074;***1086;***1079;***1074;***1088;***1072;** *1097;***1072;***1083;***1080;***1089;***1100; ***1089; ***1087;***1086;***1083;***1085;***1099;***1084;** *1080; ***1089;***1091;***1084;***1082;***1072;***1084;** *1080; ***1087;***1088;***1086;***1076;***1091;***1082;** *1090;***1086;***1074;. ***1055;***1086;***1089;***1083;***1077; ***1091;***1078;***1080;***1085;***1072; ***1086;***1085;***1080; ***1091;***1089;***1090;***1088;***1072;***1080;** *1074;***1072;***1083;***1080; ***1074;***1077;***1095;***1077;***1088;***1080;** *1085;***1082;***1080; ***1089; ***1095;***1072;***1077;***1087;***1080;***1090;** *1080;***1077;***1084; ***1080; ***1087;***1086;***1075;***1083;***1086;***1097;** *1077;***1085;***1080;***1077;***1084; ***1086;***1090;***1089;***1091;***1090;***1089;** *1090;***1074;***1091;***1102;***1097;***1080;***1 093; ***1082;***1072;***1083;***1086;***1088;***1080;** *1081; ***1085;***1072; ***1085;***1086;***1095;***1100;. ***1053;***1072;***1083;***1080;***1095;***1085;** *1099;***1077; ***1091; ***1084;***1091;***1078;***1095;***1080;***1085; ***1079;***1072;***1082;***1086;***1085;***1095;** *1080;***1083;***1080;***1089;***1100; ***1073;***1099;***1089;***1090;***1088;***1086;. ***1054;***1085;***1080; ***1073;***1088;***1086;***1076;***1080;***1083;** *1080; ***1075;***1086;***1083;***1086;***1076;***1085;** *1099;***1077;, ***1079;***1083;***1099;***1077; ***1080; ***1075;***1088;***1091;***1073;***1099;***1077;. ***1071; ***1080;***1084; ***1074; ***1076;***1086;***1083;***1075; ***1089;***1088;***1077;***1076;***1089;***1090;** *1074; ***1085;***1077; ***1076;***1072;***1083;***1072;, ***1090;***1072;***1082; ***1082;***1072;***1082; ***1085;***1072;***1083;***1080;***1095;***1085;** *1099;***1077; ***1091; ***1084;***1077;***1085;***1103; ***1073;***1099;***1083;***1080; ***1090;***1086;***1095;***1085;***1086; ***1088;***1072;***1089;***1089;***1095;***1080;** *1090;***1072;***1085;***1099;, ***1076;***1086;***1087;***1086;***1083;***1085;** *1080;***1090;***1077;***1083;***1100;***1085;***1 099;***1093; ***1085;***1077; ***1073;***1099;***1083;***1086;...
***1052;***1085;***1077;, ***1082;***1072;***1082; ***1096;***1077;***1092;***1091; ***1075;***1088;***1091;***1087;***1087;***1099;, ***1085;***1072;***1076;***1086; ***1073;***1099;***1083;***1086; ***1076;***1077;***1088;***1078;***1072;***1090;** *1100; ***1076;***1077;***1085;***1100;***1078;***1072;** *1090;***1072; ***1085;***1072; ***1074;***1089;***1103;***1082;***1080;***1081; ***1089;***1083;***1091;***1095;***1072;***1081;, ***1085;***1072;***1083;***1080;***1095;***1085;** *1099;***1084;***1080; ***1088;***1072;***1079;***1073;***1088;***1072;** *1089;***1099;***1074;***1072;***1090;***1100;***1 089;***1103; ***1085;***1077; ***1076;***1086;***1074;***1086;***1076;***1080;** *1083;***1086;***1089;***1100;. ***1042;***1089;***1077; ***1087;***1080;***1089;***1100;***1084;***1072;, ***1087;***1077;***1088;***1077;***1074;***1086;** *1076;***1099; ***1080; ***1090;***1077;***1083;***1077;***1075;***1088;** *1072;***1084;***1084;***1099; ***1076;***1086;***1089;***1090;***1086;***1074;** *1083;***1103;***1083;***1080;***1089;***1100; ***1085;***1072; ***1084;***1086;***1077; ***1080;***1084;***1103;. ***1050;***1072;***1082;-***1090;***1086; ***1087;***1086;***1091;***1090;***1088;***1091; ***1074;***1083;***1077;***1090;***1072;***1077;** *1090; ***1082;***1086; ***1084;***1085;***1077; ***1074; ***1085;***1086;***1084;***1077;***1088; ***1091;***1095;***1080;***1090;***1077;***1083;** *1100; ***1090;***1088;***1091;***1076;***1072; ***1089; ***1087;***1077;***1088;***1077;***1074;***1086;** *1076;***1086;***1084; ***1074; ***1088;***1091;***1082;***1077;. - ***1052;***1099; ***1080;***1079;***1073;***1072;***1074;***1083;** *1077;***1085;***1099; ***1086;***1090; ***1075;***1086;***1083;***1086;***1076;***1085;** *1086;***1081; ***1087;***1086;***1075;***1080;***1073;***1077;** *1083;***1080;, ***1076;***1080;***1088;***1077;***1082;***1090;** *1086;***1088; ***1096;***1082;***1086;***1083;***1099; ***1086;***1090;***1087;***1088;***1072;***1074;** *1080;***1083; ***1087;***1086; ***1087;***1086;***1095;***1090;***1077; ***1085;***1072;***1096;***1091; ***1087;***1086;***1083;***1091;***1095;***1082;** *1091;, ***1085;***1086; ***1085;***1072; ***1090;***1074;***1086;***1077; ***1080;***1084;***1103;. ***1045;***1077; ***1085;***1077;***1086;***1073;***1093;***1086;** *1076;***1080;***1084;***1086; ***1084;***1075;***1085;***1086;***1074;***1077;** *1085;***1085;***1086; ***1074;***1079;***1103;***1090;***1100;.
***1071; ***1089;***1086;***1073;***1088;***1072;***1083;** *1072;***1089;***1100; ***1080; ***1086;***1090;***1087;***1088;***1072;***1074;** *1080;***1083;***1072;***1089;***1100; ***1074; ***1075;***1086;***1088;***1086;***1076;***1086;** *1082; ***1079;***1072; ***1085;***1072;***1083;***1080;***1095;***1082;** *1086;***1081;. ***1057;***1074;***1077;***1090;***1080;***1083;** *1086; ***1089;***1086;***1083;***1085;***1099;***1096;** *1082;***1086;, ***1085;***1072; ***1084;***1086;***1088;***1077; ***1073;***1099;***1083; ***1096;***1090;***1080;***1083;***1100;, ***1074;***1089;***1077; ***1087;***1072;***1093;***1083;***1086; ***1080; ***1094;***1074;***1077;***1083;***1086; ***1074; ***1086;***1082;***1088;***1091;***1075;***1077;. ***1056;***1072;***1073;***1086;***1090;***1099; ***1089; ***1076;***1077;***1090;***1100;***1084;***1080; ***1093;***1074;***1072;***1090;***1072;***1083;** *1086; ***1085;***1072; ***1074;***1089;***1077; 24 ***1095;***1072;***1089;***1072;, ***1080; ***1087;***1086;***1090;***1086;***1084;***1091; ***1087;***1086;***1075;***1091;***1083;***1103;** *1090;***1100; ***1074; ***1075;***1086;***1088;***1086;***1076;***1077; ***1074; ***1072;***1073;***1089;***1086;***1083;***1102;** *1090;***1085;***1086;***1084; ***1086;***1076;***1080;***1085;***1086;***1095;** *1077;***1089;***1090;***1074;***1077; ***1073;***1099;***1083;***1086; ***1087;***1088;***1086;***1089;***1090;***1086; ***1089;***1095;***1072;***1089;***1090;***1100;** *1077;***1084; ***1076;***1083;***1103; ***1084;***1077;***1085;***1103;. ***1053;***1072; ***1085;***1072;***1073;***1077;***1088;***1077;** *1078;***1085;***1086;***1081; ***1085;***1072;***1093;***1086;***1076;***1080;** *1083;***1086;***1089;***1100; ***1087;***1086;***1083;***1085;***1086; ***1083;***1102;***1076;***1072;. ***1055;***1072;***1087;***1072;***1088;***1072;** *1094;***1094;***1080; ***1087;***1088;***1077;***1076;***1083;***1072;** *1075;***1072;***1083;***1080; ***1089;***1092;***1086;***1090;***1082;***1072;** *1090;***1100;***1089;***1103; ***1085;***1072; ***1092;***1086;***1085;***1077; ***1084;***1086;***1088;***1089;***1082;***1086;** *1075;***1086; ***1074;***1080;***1076;***1072;. ***1052;***1085;***1077; ***1079;***1072;***1093;***1086;***1090;***1077;** *1083;***1086;***1089;***1100; ***1079;***1072;***1087;***1077;***1095;***1072;** *1090;***1083;***1080;***1090;***1100; ***1089;***1074;***1086;***1102; ***1087;***1086;***1077;***1079;***1076;***1082;** *1091; ***1074; ***1040;***1073;***1093;***1072;***1079;***1080;** *1102; ***1080; ***1089;***1092;***1086;***1090;***1086;***1075;** *1088;***1072;***1092;***1080;***1088;***1086;***1 074;***1072;***1090;***1100;***1089;***1103;. ***1055;***1088;***1077;***1076;***1087;***1086;** *1095;***1083;***1072; ***1092;***1086;***1090;***1086;***1075;***1088;** *1072;***1092;***1072; ***1089; ***1086;***1073;***1077;***1079;***1100;***1103;** *1085;***1082;***1086;***1081;. ***1047;***1072;***1073;***1072;***1074;***1085;** *1072;***1103; ***1090;***1072;***1082;***1072;***1103;, ***1093;***1086;***1088;***1086;***1096;***1077;** *1085;***1100;***1082;***1072;***1103;... ***1058;***1086;***1083;***1100;***1082;***1086; ***1083;***1080;***1096;***1100; ***1103; ***1087;***1086;***1076;***1086;***1096;***1083;** *1072; ***1082; ***1092;***1086;***1090;***1086;***1075;***1088;** *1072;***1092;***1091;, ***1082;***1072;***1082; ***1086;***1085;***1072; ***1074;***1089;***1082;***1086;***1095;***1080;** *1083;***1072; ***1084;***1085;***1077; ***1085;***1072; ***1087;***1083;***1077;***1095;***1086; ***1080; ***1089;***1090;***1072;***1083;***1072; ***1090;***1077;***1088;***1077;***1073;***1080;** *1090;***1100; ***1090;***1086;***1085;***1082;***1080;***1084;** *1080; ***1087;***1072;***1083;***1100;***1095;***1080;** *1082;***1072;***1084;***1080; ***1082;***1091;***1076;***1088;***1080; ***1085;***1072; ***1084;***1086;***1077;***1081; ***1075;***1086;***1083;***1086;***1074;***1077;. ***1060;***1086;***1090;***1086;***1093;***1091;** *1076;***1086;***1078;***1085;***1080;***1082; ***1091;***1089;***1072;***1076;***1080;***1083; ***1095;***1080;***1085;***1085;***1086; ***1084;***1072;***1088;***1090;***1099;***1096;** *1082;***1091; ***1080; ***1085;***1072;***1095;***1072;***1083; ***1076;***1077;***1083;***1072;***1090;***1100; ***1092;***1086;***1090;***1082;***1080; ***1074; ***1088;***1072;***1079;***1083;***1080;***1095;** *1085;***1099;***1093; ***1088;***1072;***1082;***1091;***1088;***1089;** *1072;***1093;.
***1073;***1086;***1083;***1100;***1096;***1072;** *1103; ***1083;***1102;***1073;***1086;***1074;***1100; ***1088;***1077;***1072;***1083;***1100;***1085;** *1072;***1103; ***1080;***1089;***1090;***1086;***1088;***1080;** *1103;
***1053;***1086; ***1074;***1086;***1090; ***1084;***1072;***1088;***1090;***1099;***1096;** *1082;***1072; ***1089; ***1087;***1083;***1077;***1095;***1072; ***1087;***1077;***1088;***1077;***1087;***1088;** *1099;***1075;***1085;***1091;***1083;***1072; ***1085;***1072; ***1084;***1086;***1102; ***1089;***1086;***1075;***1085;***1091;***1090;** *1091;***1102; ***1088;***1091;***1082;***1091; ***1080; ***1074; ***1086;***1076;***1085;***1086; ***1084;***1075;***1085;***1086;***1074;***1077;** *1085;***1080;***1077; ***1083;***1072;***1087;***1086;***1081; ***1079;***1072;***1083;***1077;***1079;***1083;** *1072; ***1084;***1085;***1077; ***1074; ***1082;***1072;***1088;***1084;***1072;***1085; ***1080; ***1074;***1099;***1090;***1072;***1097;***1080;** *1083;***1072; ***1087;***1072;***1089;***1087;***1086;***1088;** *1090; ***1089;***1086;***1074;***1084;***1077;***1089;** *1090;***1085;***1086; ***1089; ***1087;***1077;***1088;***1077;***1074;***1086;** *1076;***1086;***1084;. ***1054;***1085;***1072; ***1090;***1072;***1082; ***1091;***1076;***1072;***1095;***1085;***1086; ***1076;***1077;***1088;***1085;***1091;***1083;** *1072; ***1087;***1086;***1074;***1086;***1076;***1086;** *1082;, ***1095;***1090;***1086; ***1077;***1081; ***1087;***1086;***1089;***1095;***1072;***1089;** *1090;***1083;***1080;***1074;***1080;***1083;***1 086;***1089;***1100; ***1074;***1099;***1088;***1074;***1072;***1090;** *1100;***1089;***1103; ***1080; ***1091;***1076;***1088;***1072;***1090;***1100; ***1089; ***1084;***1086;***1080;***1084; ***1087;***1072;***1089;***1087;***1086;***1088;** *1090;***1086;***1084; ***1087;***1086; ***1087;***1072;***1083;***1100;***1084;***1072;** *1084; ***1080; ***1082;***1091;***1089;***1090;***1080;***1082;** *1072;***1084;. ***1071; ***1089;***1090;***1086;***1103;***1083;***1072; ***1074; ***1088;***1072;***1089;***1090;***1077;***1088;** *1103;***1085;***1085;***1086;***1089;***1090;***1 080; ***1080; ***1091;***1078;***1072;***1089;***1077;. ***1042; ***1095;***1091;***1078;***1086;***1084; ***1075;***1086;***1088;***1086;***1076;***1077; ***1073;***1077;***1079; ***1076;***1086;***1082;***1091;***1084;***1077;** *1085;***1090;***1072;... ***1071; ***1086;***1090;***1086;***1096;***1083;***1072; ***1074; ***1089;***1090;***1086;***1088;***1086;***1085;** *1091; ***1082; ***1084;***1086;***1088;***1102;, ***1089;***1087;***1091;***1089;***1090;***1080;** *1083;***1072;***1089;***1100; ***1085;***1072; ***1083;***1072;***1074;***1086;***1095;***1082;** *1091;, ***1089;***1085;***1103;***1083;***1072; ***1087;***1072;***1085;***1072;***1084;***1091;. ***1057;***1080;***1078;***1091;, ***1086;***1078;***1080;***1076;***1072;***1102; ***1092;***1086;***1090;***1086;***1075;***1088;** *1072;***1092;***1072;, ***1082;***1086;***1090;***1086;***1088;***1099;** *1081; ***1087;***1086;***1073;***1077;***1078;***1072;** *1083; ***1079;***1072; ***1084;***1072;***1088;***1090;***1099;***1096;** *1082;***1086;***1081; ***1080; ***1075;***1086;***1088;***1077;***1089;***1090;** *1085;***1086; ***1088;***1099;***1076;***1072;***1102;. ***1071; ***1085;***1077; ***1087;***1086;***1084;***1085;***1102;, ***1089;***1082;***1086;***1083;***1100;***1082;** *1086; ***1074;***1088;***1077;***1084;***1077;***1085;** *1080; ***1103; ***1090;***1072;***1082; ***1087;***1088;***1086;***1089;***1080;***1076;** *1077;***1083;***1072;, ***1083;***1102;***1076;***1080; ***1096;***1083;***1080; ***1084;***1080;***1084;***1086; ***1084;***1077;***1085;***1103;, ***1082;***1072;***1082; ***1074; ***1085;***1077;***1084;***1086;***1084; ***1082;***1080;***1085;***1086;. ***1054;***1095;***1085;***1091;***1083;***1072;** *1089;***1100; ***1103; ***1086;***1090; ***1101;***1090;***1086;***1075;***1086; ***1089;***1086;***1089;***1090;***1086;***1103;** *1085;***1080;***1103;, ***1091;***1089;***1083;***1099;***1096;***1072;** *1074;, ***1082;***1072;***1082; ***1074; ***1084;***1086;***1102; ***1082;***1077;***1087;***1091; ***1082;***1090;***1086;-***1090;***1086; ***1073;***1088;***1086;***1089;***1080;***1083; ***1084;***1086;***1085;***1077;***1090;***1099;. ***1071; ***1088;***1077;***1079;***1082;***1086; ***1087;***1086;***1074;***1077;***1088;***1085;** *1091;***1083;***1072;***1089;***1100; ***1080; ***1091;***1074;***1080;***1076;***1072;***1083;** *1072; ***1085;***1072; ***1087;***1077;***1088;***1080;***1083;***1072;** *1093; ***1083;***1072;***1074;***1082;***1080; ***1089;***1080;***1076;***1080;***1090; ***1085;***1072;***1075;***1083;***1072;***1103; ***1086;***1073;***1077;***1079;***1100;***1103;** *1085;***1072; ***1089; ***1084;***1086;***1080;***1084; ***1083;***1102;***1073;***1080;***1084;***1099;** *1084; ***1087;***1072;***1089;***1087;***1086;***1088;** *1090;***1086;***1084; ***1074; ***1083;***1072;***1087;***1072;***1093;, ***1072; ***1074; ***1084;***1086;***1077;***1081; ***1087;***1072;***1085;***1072;***1084;***1077; ***1085;***1072;***1082;***1086;***1087;***1080;** *1083;***1072;***1089;***1100; ***1076;***1086;***1089;***1090;***1072;***1090;** *1086;***1095;***1085;***1086; ***1074;***1085;***1091;***1096;***1080;***1090;** *1077;***1083;***1100;***1085;***1072;***1103; ***1089;***1091;***1084;***1084;***1072; ***1076;***1077;***1085;***1077;***1075; ***1076;***1083;***1103; ***1086;***1073;***1077;***1079;***1100;***1103;** *1085;***1099;. ***1071; ***1084;***1086;***1083;***1085;***1080;***1077;** *1085;***1086;***1089;***1085;***1086; ***1074;***1099;***1093;***1074;***1072;***1090;** *1080;***1083;***1072; ***1080;***1079; ***1077;***1077; ***1083;***1072;***1087; ***1089;***1074;***1086;***1081; ***1076;***1086;***1082;***1091;***1084;***1077;** *1085;***1090;, ***1089;***1093;***1074;***1072;***1090;***1080;** *1083;***1072; ***1086;***1073;***1077;***1079;***1100;***1103;** *1085;***1091; ***1079;***1072; ***1088;***1077;***1084;***1077;***1085;***1100; ***1080; ***1087;***1088;***1080;***1078;***1072;***1083;** *1072; ***1087;***1072;***1089;***1087;***1086;***1088;** *1090; ***1082; ***1089;***1077;***1088;***1076;***1094;***1091;, ***1082;***1086;***1090;***1086;***1088;***1086;** *1077; ***1087;***1099;***1090;***1072;***1083;***1086;** *1089;***1100; ***1074;***1099;***1087;***1088;***1099;***1075;** *1085;***1091;***1090;***1100; ***1080;***1079; ***1075;***1088;***1091;***1076;***1080;. ***1063;***1077;***1088;***1077;***1079; ***1085;***1077;***1082;***1086;***1090;***1086;** *1088;***1086;***1077; ***1074;***1088;***1077;***1084;***1103; ***1087;***1088;***1080;***1083;***1077;***1090;** *1077;***1083; ***1092;***1086;***1090;***1086;***1075;***1088;** *1072;***1092;. ***1054;***1085; ***1087;***1088;***1086;***1076;***1086;***1083;** *1078;***1080;***1090;***1077;***1083;***1100;***1 085;***1086; ***1080;***1079;***1074;***1080;***1085;***1103;** *1083;***1089;***1103; ***1079;***1072; ***1089;***1086;***1073;***1089;***1090;***1074;** *1077;***1085;***1085;***1091;***1102; ***1074;***1086;***1089;***1087;***1080;***1090;** *1072;***1085;***1085;***1080;***1094;***1091; ***1080; ***1087;***1086;***1086;***1073;***1077;***1097;** *1072;***1083;, ***1095;***1090;***1086; ***1089;***1076;***1077;***1083;***1072;***1077;** *1090; ***1092;***1086;***1090;***1086; ***1076;***1083;***1103; ***1084;***1077;***1085;***1103; ***1073;***1077;***1079;***1074;***1086;***1079;** *1084;***1077;***1079;***1076;***1085;***1086;. ***1044;***1072;***1078;***1077; ***1093;***1086;***1090;***1077;***1083; ***1089;***1076;***1077;***1083;***1072;***1090;** *1100; ***1077;***1097;***1077; ***1085;***1077;***1089;***1082;***1086;***1083;** *1100;***1082;***1086; ***1082;***1072;***1076;***1088;***1086;***1074;, ***1085;***1086; ***1103; ***1076;***1072;***1083;***1072; ***1077;***1084;***1091; ***1085;***1072;***1083;***1080;***1095;***1085;** *1099;***1077;, ***1082;***1086;***1090;***1086;***1088;***1099;** *1077; ***1087;***1086;***1076;***1086;***1073;***1088;** *1072;***1083;***1072; ***1086;***1073;***1077;***1079;***1100;***1103;** *1085;***1072; ***1080; ***1091;***1076;***1072;***1083;***1080;***1083;** *1072;***1089;***1100; ***1087;***1086;***1083;***1091;***1095;***1072;** *1090;***1100; ***1076;***1077;***1085;***1100;***1075;***1080; ***1085;***1072; ***1077;***1076;***1091; ***1089;***1074;***1086;***1080;***1093; ***1085;***1077;***1085;***1072;***1089;***1099;** *1090;***1085;***1099;***1093; ***1084;***1091;***1078;***1095;***1080;***1085;.
***1087;***1086;***1084;***1085;***1080; ***1080;***1084;***1103; ***1089;***1074;***1086;***1077; ***1088;***1077;***1072;***1083;***1100;***1085;** *1072;***1103; ***1080;***1089;***1090;***1086;***1088;***1080;** *1103;
e39, ews, ipna, not starting problem
