BMW M2 Technical Information - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1M & M2 > F87 M2 (2016 - current)
BMW will be unveiling the upcoming F87 M2 and this is the place to talk about it. Are you adding one of these to your garage?
Old 01-15-2016, 05:56 PM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest Founder
Mein Auto: Various
BMW M2 F87 technical details
Bimmerfest brings you initial technical details on the BMW M2. We'll have more technical info as it comes out but for now enjoy these goodies.
BMW F87 M2 BMW technical training doc
Engine - N55B30T0
The M2 is powered by a 3.0L inline 6 cylinder with M TwinPower Turbo Technology (N55). This engine is based on the N55 engine from the M235i, but with significant changes and enhancements. The M2 N55 has gained selected components from the BMW M3/M4 S55 engine. Components including the pistons, top ring (optimized for grey-cast iron liners), and crankshaft main bearing shells. The new engine in the BMW M2 is also equipped with the requisite high-performance spark plugs designed to optimally work at higher temperatures.
Engine specs include:
  • 370hp at 6500 rpm (7000rpm redline)
  • 343 lb-ft of torque from 1,400 - 5,560 rpm
  • Overboost function allowing an additional 26 lb-ft of torque (available from 1,350 - 4,500 rpm) for a maximum of 369 lb-ft
  • Single twin scroll turbocharger
  • VANOS
  • VALVETRONIC
  • Direct Injection
  • Grey-cast iron cylinder liners
  • Forged crankshaft
  • Closed-deck block
  • Baffled oil pan with dual pickups
  • Additional radiator (racetrack proven cooling capability)
  • Optimized exhaust manifold
  • Optimized airbox with 2 inlets
2016 BMW M2 Pricing and Ordering Guides
Transmission
The M2 is available with either a 6 Speed Manual Transmission or an M Double Clutch Transmission
Manual Transmission:
The 6 Speed Manual is equipped with a new cabron-fiber friction lining which enhances shifting precesion. It also employs a sump design that prevents gears sloshing through fluid and pumps the gear oil to the necessary locations. The Manual Transmission also has Rev Matching on both downshifts and upshifts. On downshifts, the correct engine speed is applied to ensure a smooth downshift. This can be disabled by switching DSC completely off. On upshifts, the engine speed drops to the optimal engine speed and is held there until the gear is engaged. This is only noticeable when shifting slowly. The Manual Transmission is capable of a 0-60mph time of 4.3s.
M DCT Transmission:
The M DCT is the latest generation of the 7 speed double clutch gearbox found in previous M models. The DCT transmission also includes the Launch Control feature for optimal accelleration. Using Launch Control, the M2 is capable of a very impressive 0-60mph is 4.1s.
Read more about the 2016 BMW M2
Brakes
While the Engine and Transmission are able to get the M2 up to speed very quickly, the equally impressive brake package sheds speed with confidence. The standard and only braking option includes:
  • Perforated Compound Brake Rotors (Aluminum hubs and Steel friction surface)
  • 15" front diameter and 14.5" rear diameter
  • Four piston fixed front calipers supplied by Brembo
  • Two piston fixed rear calipers
Carbon ceramic brakes are not an option
Curious about the BMW M2? Photos and first impressions from Detroit
Rear Differential
The Active M Differential takes grip and directional stability to a new level. Unlike an open differential that allows the wheel without grip to spin freely, or a traditional mechanical limited slip with a fixed locking percentage, the Active M Differential allows between 0 and 100% locking depending on the situation and is based on various inputs from the DSC control unit. The locking percentage is changed by using an electric motor to vary the pressure on the hydraulic clutch pack.
Old 01-15-2016, 07:12 PM
Campfamily's Avatar
Campfamily Campfamily is offline
Mein Auto: 2008 550i
I want this car..................................
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod SOLD, but not forgotten
Old 01-23-2016, 12:54 AM
LycanNyc's Avatar
LycanNyc LycanNyc is offline
BMWCCA '505245
Send a message via AIM to LycanNyc
Mein Auto: F80 ZCP
I hope the "B30" means it has some B58 upgrades too
Custom CTS Turbo FMIC + Custom CTS Turbo Downpipe + E30 BM3 OTS Map *PM if any questions on X4 M40i and mods*
7/14 - 3/16 | 14' X3 Msport
3/16 - 7/18 | 16' X4 M40i LBB
7/18 -Present | 17' F80 ZCP
WishList - X3M or X4M
Member: BMWCCA #505245
Old 02-05-2016, 03:25 PM
tim330i's Avatar
Bimmerfest Founder
Mein Auto: Various
I just got a hold of the complete F87 M2 BMW technical documents. Check the first post for a full run down of all the technical features of the M2
Tim
Old 02-05-2016, 04:11 PM
u3b3rg33k u3b3rg33k is offline
Mein Auto: e30, e60, R1100S
I wonder, do those brakes fit other vehicles...
e30: '87 325i: MAF+WAR chip, long tube STAHL headers, 5MT swap, 4.27 torsen
e60: '08 550i M-sport, 6MT, ARC, Active Steering, 19" wheel delete
R1100S - oilhead FTW
Originally Posted by MeNoo View Post
Although I have nothing scientific to say, I can confidently say that it works.
Originally Posted by Burning2nd View Post
If you want to use the fuhrers snowmobile you gotta have das tires
Old 02-07-2016, 10:09 PM
LycanNyc's Avatar
BMWCCA '505245
Mein Auto: F80 ZCP
Tim
thank you !!!
So this is the same engine going into the X4 M40i except a little detuned no over boost correct?
Old 02-14-2016, 01:56 PM
jonesmclean jonesmclean is offline
Buddy
Mein Auto: 135is, 328xi, Triumph TR6
engagement speed control function
Please tell me that the damn "engagement speed control function" can be turned off. Anyone who doesn't know how to double clutch and blip the throttle without a computer doing it for them shouldn't' be allowed to drive an M2... or any car with a manual transmission for that matter.
Old 02-14-2016, 05:58 PM
tim330i's Avatar
Bimmerfest Founder
Mein Auto: Various
It is turned off when your turn DSC off, otherwise there is no way to turn it off.
Old 02-14-2016, 07:08 PM
Buddy
So as long as I remember to turn off the DSC every time I start the car, it won't do my throttle blipping for me. Thanks.
I understand that the M2 also has the auto start / stop function that turns off the engine when stopped. Can that be permanently turned off?
Thanks.
Old 02-14-2016, 07:10 PM
tim330i's Avatar
Bimmerfest Founder
Mein Auto: Various
Yes, you have to turn off DSC every time.
Auto stop start can be disabled with the switch and it remembers the last setting.
Old 02-14-2016, 08:16 PM
LycanNyc's Avatar
BMWCCA '505245
Mein Auto: F80 ZCP
deleted
Old 02-14-2016, 08:19 PM
tim330i's Avatar
Bimmerfest Founder
Mein Auto: Various
No, I didn't see that. But I was there and will be publishing my review soon.
Old 02-14-2016, 08:24 PM
LycanNyc's Avatar
BMWCCA '505245
Mein Auto: F80 ZCP
He just said good technical points which are very nice to hear for those who didn't read the pdf.
Thanks for the technical docs and looking forward to your review
Old 02-14-2016, 08:33 PM
tim330i's Avatar
Bimmerfest Founder
Mein Auto: Various
I've only watched the first few minutes but there are numerous errors in that video about the engine.
Old 02-14-2016, 08:36 PM
LycanNyc's Avatar
BMWCCA '505245
Mein Auto: F80 ZCP
Oh man =\ , cant wait to hear yours
Old 02-14-2016, 08:39 PM
tim330i's Avatar
Bimmerfest Founder
Mein Auto: Various
The engine in the M2 does not share the engine block or exhaust headers from the M3/M4 for example as two blatant errors in the video.
Old 02-15-2016, 06:04 AM
m293 m293 is offline
Mein Auto: Bmw 116i (F21) M2 (coming
Wen comes out your videos ?
Old 02-22-2016, 06:13 PM
LycanNyc's Avatar
BMWCCA '505245
Mein Auto: F80 ZCP
This
Old 02-22-2016, 06:15 PM
tim330i's Avatar
Bimmerfest Founder
Mein Auto: Various
I have a few track specific laps and of course there is my review (BMW M2 Review) but I did not make a technical oriented video. I feel the technical docs better cover the M2 then a video ever could.
Tim
Old 02-22-2016, 06:22 PM
LycanNyc's Avatar
BMWCCA '505245
Mein Auto: F80 ZCP
Tim
Ahh yes just bumped into that thread..
Anything for the X4 M40i ?
There's only 1 review so far on youtube
Old 02-22-2016, 06:24 PM
tim330i's Avatar
Bimmerfest Founder
Mein Auto: Various
I will have a driving review (written) but did not have time to do any video for the X4 M40i.
Old 02-22-2016, 09:08 PM
LycanNyc's Avatar
BMWCCA '505245
Mein Auto: F80 ZCP
I would still appreciate that
Old 08-30-2016, 03:17 AM
Bavarian e46 Bavarian e46 is offline
Mein Auto: BMW M3 E46
I haven't had a chance to drive the 1m from 2011 or the m2. But man the M2 after starting it up and comparing it to the e46 m3 I have.... it's identical in size and space interior to the e46. it was like living it again. I bought my m3 from a Kuwait guy who had it supercharged already with k sport coilovers, stop tech brake kit with a new built engine and it makes me wonder what the m2 will be like when I do drive it. I say that Because its like as good as the M2 is... I wonder if it will make me feel like I felt when I drove the e92 or 2013 m5? Time will tell. Glad to be in this group. It's my first day and learning how to take care of my m3.
Old 11-28-2016, 01:36 PM
BeemerGuy's Avatar
BeemerGuy BeemerGuy is offline
former motorcycle rider
Mein Auto: F87 & F01
I had the pleasure recently to attend the BMW M Performance driving event at the Performance Center in SC. We drove the M4, the M3 and the (drum roll please) M2.
What fun!
I'll be brief. I've driven the M3 and M4 before, and they are great cars. Great handling, awesome brakes, killer performance overall. My only complaint really is the faux engine noise.
Regardless of cost, with a limited option availability and fewer standard features, I preferred the M2. It has better balance, a more compliant ride and weighs a lot less. Sure, it's slower, it's got less power, but that's the car that I would pick, hands-down.
If I were racing competitively and were going to buy a dedicated track car to strip and prep, then it would be the M3/M4. But for street use as a daily driver and fun HPDE car, the M2 is much better. Only if you have to have 4 doors would I get the M3. You'd buy the M4 if you were shopping with looks as your priority.
F87 (mine)
E90 (hers)
F01 (ours)
Old 11-28-2017, 08:02 AM
Capobranco's Avatar
Capobranco Capobranco is offline
Eye of the Wolf
Mein Auto: M2, X5
What fun!
Ditto - I also attended M School in SC a few months ago and your experience is my experience.
..BMWCCA...10th BMW
bmw m2, bmw m2 forum, f87 forum, f87 m2, m2 forum, m2 n55, m2 review, m2 technical details, m2post, n55, n55 bmw engine, n55b30t0
HTML code is Off
