weird clutch pedal issue - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 10-20-2019, 10:11 PM
William Mills William Mills is offline
Mein Auto: 1986 BMW 325e
started driving, car working normally
got on highway and drove about 35 miles at highway speed (65-85mph)
when I exited the highway and went to put the car in neutral
the clutch suddenly only had about an inch of throw
and it stayed really low to the floor the whole time
it still worked, but would engage instantly when I let up on it
I made it to my job
when I left the job it was still doing the same thing
I went back the same way I came
but when I exited the highway this time
I didn't feel any pedal and the stick kinda banged as it went into neutral
I was just trying to downshift into 2nd
but it wouldn't go into gear
I coasted it to the side of the road
and there it sits
...am I screwed?
This is a 1986 bmw 325e
Old 10-21-2019, 05:35 AM
tomstin tomstin is offline
Mein Auto: 2005 525i - 1985 325E
Going to be tough to diagnose on the side of the road. I would pull the clutch slave cylinder and see how that looks and feels. My bet is the clutch master / slave cylinder when out on you.
Is there plenty of fluid in the master cylinder? Is it clear or dark? Any sign of fluid leaking on the carpet (master) or under the car (slave)?
2005 525i Sport, manual - 1985 325E Coupe, manual
Old 10-21-2019, 02:58 PM
Nothing in the floorboard, and nothing on the ground... starting to get worried... where did that fluid go?
Old 10-22-2019, 04:55 PM
I take it from your post the fluid is low. Fill it up and push the clutch in and out a lot of times. You may need to pull the pedal up with your foot. Itís supposed to be self bleeding but can take a lot of pumps.
If you remove the slave cylinder youíll probably find itís leaking into the bell housing.
clutch, pedal
