Rpm bounce at idle - Bimmerfest - BMW Forums
Old 03-31-2020, 02:45 PM
R3jus R3jus is offline
Mein Auto:
Rpm bounce at idle
So i have an e39 528i manual 2000y and i replaced both pre cat o2 sensors, spark plugs, TB gasket, intake manifold gasket, and CCV, and now the rpm bounce at idle, what could be the problem? There are no vacuum leaks... my computer shows bank 1 and bank 2 codes but not always
Old 04-01-2020, 06:26 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
on your year/model, vanos seals would be the first culprit id look at. what are the bank 1 and 2 codes?
99 528i 5sp sport
be alert...the world needs more lerts
Old 04-01-2020, 11:04 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Please explain "Rpm bounce."
Old 04-02-2020, 01:43 AM
Mein Auto:
When i stop at a red light the rpm doesnt stay consistant it bounces up and down almost stalls the engine at idle
Mein Auto:
Fuel trim bank 1 and fuel trimk bank 2
Old 04-02-2020, 09:43 AM
Do you know for sure there are no vacuum leaks?
Have you checked operation of the idle control valve? Item 7: https://www.realoem.com/bmw/enUS/sho...diagId=11_7535
It should rattle slightly when shaken, and buzz in operation.
Old 04-02-2020, 03:25 PM
mattmar1's Avatar
Wingnut
but what are the codes? those are the definitions.
99 528i 5sp sport
Old 04-06-2020, 03:13 PM
Mein Auto:
Now im gettin p1250
Old 04-06-2020, 05:22 PM
mattmar1's Avatar
Wingnut
im going to add to the list of questions youve not answered as of yet on here....are you reading with a generic scanner? code P1250 is in a manufacturer assigned code block....all valid OBDII codes will start with P0XXX. any code starting with P1XXX or P2XXX are assigned by each specific manufacturer. youve not given the answers to the questions of edjack or myself. you need to get a BMW specific scanner, or have the codes read by a shop who has one.
we're trying to help you. but youve got to help us to do so.
99 528i 5sp sport
Old 04-06-2020, 11:11 PM
Mein Auto:
Okay thanks for the answer im going to go to a shop to check it out
