What do you think of this gadget? - Bimmerfest - BMW Forums
Old 06-09-2019, 08:46 AM
coug60's Avatar
coug60 coug60 is offline
06 BMW 650i Sprt/Prem Pkg
Mein Auto: 2006 BMW 650i e64
https://www.ebay.com/itm/12V-Car-Ele...kAAOSw8fpc08WQ
In theory it would boost a little psi into the intake, nothing like a real supercharger but any little bit helps.
There is this one too..
https://www.ebay.com/itm/Universal-E...oAAOSwyGZaO2ag
2006 BMW 650i Sport/Premium Package
+ Various Mods & Upgrades
Old 06-09-2019, 10:33 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
How would you know that even this little bit is helping at all? With minimal performance specifications of the fan and a minute on the back of an envelope one may calculate ... Wolfram Alpha can even do it for you if you know how to ask it. http://m.wolframalpha.com/
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 06-10-2019, 04:20 AM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
Realistically I'm afraid you'll probably find they just aren't worth it, rather than give you a random cryptic reply have a read of this, it explains why and lays out the math in an easy to understand way.
In terms of getting air into the engine (for ours anyway) your still only really looking at the Dinan system, which lets face it is bonkers money for what you get from it unless it is being used in conjunction with some major engine alterations and a tune up on top. The only other thing would be the open cone system of which I've just finished the design work and parts list on mine but this is more to change the sound than actually get any noticeable gains from it, there's also heat to think about with this.
It's just an idea but for the money you'd be spending you would find a more noticeable difference from something like a sprint booster, no more actual power but it will make the car feel like it has (at least for a brief time until you get used to it ).
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 06-12-2019, 06:12 AM
afeudale afeudale is offline
Mein Auto: 2008 650i 6-Speed
Won't work...they did a test of this on Mythbusters a few years back when those first started cropping up. They don't move nearly enough CFM to make any real world difference.
Also, they use the car electrical system which in turn uses the alternator, which in turn puts load on the engine, which in turn reduces power available! Assuming efficiency is <100% (which it will be much less), then it's an expensive & complicated way to *reduce* the power output of your engine.
Old 07-09-2019, 07:15 AM
WDKIK WDKIK is offline
Wilma
Mein Auto: Z3 3.0i Road, 650i, 328xd
Plus if the Fan were to liberate, guess where all the debris goes...Down the intakes
Old 09-01-2019, 08:45 AM
The Thomas J The Thomas J is offline
Living the dream.
Mein Auto: 2004 645 convertible
These guys did a before and after dyno experiment and found these "devices" cause the engine to lose HP. Waste of money.
This is how I roll
