Valley Pan Transfer Pipe - Bimmerfest - BMW Forums
Old 08-23-2019, 11:35 AM
Omarcujar Omarcujar is offline
Mein Auto: 2008 E64 650i
I have a coolant leak after the engine shuts off.
Local shop says its the seals on the valley pan. I should likely have the transfer pipe changed while they are in there. Can anyone give me ball park repair costs on these two items?
It seems like a long job to get everything off but trying to make sure im in the right ballpark with I get my estimate.
Old 08-23-2019, 05:02 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
This is a DIY job. Not too difficult. Just tedious if you are in a bind and want to save money. Ballpark by me would be $1,200. I have done all of this myself. And yes do both jobs at the same time if they have never been done.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 08-23-2019, 07:20 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Look closely at the front of the intake at the Y coolant crossover hose that runs to both sides. If you see a white chalky residue at the front of the intake near that hose, it might be just a bad hose. This is worth looking at before pulling the intake, since it is a common problem. If coolant is running out the front center section of the block near the water pump, your coolant pipe is probably the problem. Pressure test the coolant system, & watch where the leak actually is.
Old 08-24-2019, 06:19 AM
+1
