E64 bmw 650i fog light swap out - Bimmerfest - BMW Forums
Old 08-26-2019, 11:17 AM
Mikeuno583 Mikeuno583 is offline
Mein Auto:
Any body have a video or tutorial on hanging the fog lights mine look all fogged up just received my new pair today thanks
Old 08-27-2019, 01:58 AM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
If these are the rear fogs you'll need to remove the rear bumper, it's all really easy from there on, if you haven't taken the bumper off before there a vid here (bottom of the page).
If it's the front fogs you need lift the front of the car onto axle stands, remove the engine under-tray, undo and pull back the wheel arch cover and then you can get to them, if your car was built before 07 it should have one slide in fitting and two screws, after 07 it will be two slide in fittings and one screw. I do remember the torque setting was tiny, only about 3nm for the screws. I'm sure there's a TIS for this I'll have a look and post it if possible, might explain things a little better than me.
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 08-27-2019, 02:11 AM
Hsurf's Avatar
Super Moderator
Here you go and I was wrong, tightening torque was 2.5nm for the screws.
https://www.newtis.info/tisv2/a/en/e...-lamps/PKiMXs2
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
