Remove Glove Box? - Bimmerfest - BMW Forums
Old 08-28-2019, 09:00 AM
daf290 daf290 is offline
Mein Auto: 2007 650 I
Remove Glove Box?
I have checked the TIS and removed the 4 screws on top of the glove box and the 2 larger torx screws on both sides of the glove box door but as specified in the TIS but the glove box won't move and seems like it is connected somewhere else.
Can someone tell me what I am missing?
Do I need to pull it down first? Do I need to remove the knee airbag?
I am trying to check the fuses in the glove box as my pass mirror adjust does not work. I suspect fuses are fine.
daf
Old 08-28-2019, 10:07 AM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2016 528i + 2007 650 Vert
daf
you do not need to remove the glove box.
The cover in front of it pops out. Fold it down, then lift a the the bottom in an upward motion. You can release the front door of the glove box from the straps on both sides and it will lower for easier access.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 08-28-2019, 10:19 AM
Roseng,
Got it!
Sent from my iPad using Bimmerfest
Old 08-28-2019, 03:25 PM
Raj24v Raj24v is offline
Mein Auto: 650i Individual
How do you actually remove the glove box though??
As I need to get mine out...
Old 08-28-2019, 06:51 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
If it's anything like the E46 there are screws that become visible with the glove box open. I imagine it's a bit more complicated than that on the E63/4 due to location of button to open it.
You can search BMW TIS for specifics.
Old 08-29-2019, 08:20 AM
roseng's Avatar
I think you will need to remove the trim piece around the open button. I believe there are screws behind there.
Old 09-04-2019, 04:34 AM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
You've probably done this by now but here is a PDF for it.
File Type: pdf BMW E63-64 Glove Box Removal-Install.pdf (112.8 KB, 9 views)
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 09-04-2019, 12:43 PM
