645 SMG gear Will NOT work - Bimmerfest - BMW Forums
Old 03-20-2016, 01:45 AM
Skorstensgaard Skorstensgaard is offline
Mein Auto: Bmw 645i
bmw 645 2005 SMG gear, do not go into reverse or 1 gear
after I have run about 35 km and held still for about 15 minutes came the problem. until I could get it into first gear but not in the bark. I could hear that it was trying to find reverse gear where I clearly could hear a change arm running back and forth in the gearbox. it is as if it could not find the gear. after some time where I drove a little walk in 2 gear where it jumped 1,3,5 gear about would suddenly nothing. I could start the car in N with no problems, but when I tried to put it in gear, tried gearbox to find the gear (I can hear a metallic sound of a switch arm which tried of getting the car in gear) but we did not. after the car had been stationary for 1.5 hours could suddenly good run normally without the slightest problems. there are some who have any advice or have tried it before. I look forward to hearing something ***128077;***127996;
Old 03-20-2016, 07:57 AM
6 Coupe 6 Coupe is offline
Mein Auto: '05 645ci
I believe that's your cluth position sensor.
If it would not shift into any gear at all from whatever gear it is stuck in then it is more likely the whole SMG hydraulic pump assembly has failed. http://www.realoem.com/bmw/enUS/partxref?q=21532229715
If you stand next to your car and unlock the doors with the fob and you do NOT hear the whine it makes all the time when you unlock the doors, then the SMG hydraulic pump assembly has failed.
There is a $20 salmon colored relay located in the relay box under the passenger side cabin air filter box under the hood. Replace that and it may fix your problem. If it does not then its likely your Cluth Position Sensor has failed $300 https://www.ecstuning.com/BMW-E63-64...ssion/ES43871/
Old 03-22-2016, 09:15 AM
speed645 speed645 is offline
Mein Auto: 645ci
Are there usually any codes when it is the clutch position sensor?
Old 03-22-2016, 10:50 AM
Mein Auto: Bmw 645i
I get the following error codes on our computer there are some who have an idea of what it might be?
Do you think still that it's switching position sensor ?
4f6f hydraulic pumpe acctivation - i have 50 bar on that one, so it not the punp.
4f75 gearbox , gear selection not possible
4fb4 control unit internal fault ( Cpu )
Old 03-22-2016, 12:13 PM
Mein Auto: 645ci
I would replace the pump then if it persists then its the position sensor too. I def think its the pump though.
Old 03-22-2016, 01:58 PM
Mein Auto: Bmw 645i
Why do you think still that it is the pump when it makes as much pressure as it does. Have been told that the pressure must be between 40-80 bar. What position sensor for gear shifting them there are 2 of the gearbox. It sounds like the gearbox can not figure out or find the right gear.
Old 03-22-2016, 04:21 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
Just to note that there is a repair kit that contains just the hydraulic pump, it is about 380 and not the crazy money that the entire hydraulic assembly costs. I got mine replaced for 621 at the dealer in January.
Here's a link to the part number:
http://bmwfans.info/parts-catalog/E6...ion_tank_pump/
(#3 In the diagram)
Current cars
1996 e36 320iC (convertible)
2006 e63 630i Sport w/SMG
2007 e63 M6
Previous Cars: 2002 e39 525iA Sport, 1994 e36 318i, 1990 e34 520i, 1989 e30 325i, 1986 e30 316
Old 03-22-2016, 11:47 PM
Mein Auto: Bmw 645i
Hello again
Why are so confident that it is the pump when it makes so much pressure?
This actuator what is its function.
Thanks for the help
Old 04-24-2016, 08:58 PM
Mein Auto: 645ci
I went through similar issues
Old 04-30-2016, 01:49 PM
Scooby1021 Scooby1021 is offline
Mein Auto:
I have a 05 645ci smg too. I have the same problem goin on now for 2 yrs. I jus gave up. Car sits in the garage. But it will drive fine for 20 mins to 30 mins then when I stop at a light it will get stuck in neutral or it will go in 1st but jus Rev up same as reverse. . But when I let it seat for a hour or so it normal. I've changed the pump but still same problem. I don't know what to do at this point I love the car but it's becoming a headache.
Old 04-30-2016, 01:50 PM
Mein Auto:
Or sometime it gets stuck in 1st gear and won't start for like 45mins
Old 04-30-2016, 02:11 PM
Mein Auto: 645ci
Scooby yours might be the clutch position sensor kit
Old 04-30-2016, 03:03 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
Please take your car to a good indie shop. It's criminal to leave a 6 in the garage because of a fixable problem. I know a good one in Catonsville, MD, but I'm sure there are others around.
Old 01-08-2017, 10:11 AM
Vinbee35 Vinbee35 is offline
Mein Auto: 645ci
I have exactly the same probkem. So what shoukd i do?
Should i change the cluth position sensor?
I changed the hydraulic pump but still same problem occur to me.
Pls help.
Old 01-08-2017, 10:46 AM
Mein Auto: 645ci
Has anyone found the definite solution?
Old 01-08-2017, 11:50 AM
Mein Auto:
Bro I gave up. Car has been sitting in the garage now for a lil over a year now all I do is start it once in a while and maybe drive it around the block once in a while. I can't drive it far no more than a 30 mins before it acts up. It will go in neutral by its self or cut off and when I restart it again it's stuck in 1st gear and won't start for 1 hr. Car is so beautiful clean in and out Blk on Blk. .
Old 01-09-2017, 10:18 PM
Mein Auto: 645ci
Bro, I m facing the some problem with you. Been 7 months now. Sitting and waiting. Anyone could help?
Old 01-10-2017, 06:17 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
I would go to the M5Board where M6's have SMG tranny's. You will get more help there.
Old 01-10-2017, 08:09 PM
Mein Auto: 645ci
Thank you bro, will check it out there. Appreciate your help.
Old 02-16-2017, 02:09 PM
Mein Auto: 645ci
Hey, just changed cluth position sensor but the problem still occur. What should i do next. Pls help........
Sent from my SM-P555 using Bimmerfest mobile app
Old 02-25-2017, 12:10 AM
The system on the 645Ci has more in common with the e46 M3 than the e63 M6. It is SMG II and the M5/6 is SMGIII.
So another place to go searching is e46 M3 boards like M3 cutters.
Current cars
2007 e63 M6
Old 02-26-2017, 04:27 AM
smgsociety smgsociety is offline
Mein Auto: E46 325Ci SMG
Wrong. The SMG system built in the 645/650 is the same as built in the Non-M E60, Z4 E85 and E46 models. It's the 6-speed Non-M SMG (also often referenced as SSG) which is completely different to the SMG II (M3) and SMG III (M5 and M6).
Old 02-28-2017, 11:26 AM
Mein Auto: 645ci
Originally Posted by 6 Coupe View Post
I believe that's your cluth position sensor. If it would not shift into any gear at all from whatever gear it is stuck in then it is more likely the whole SMG hydraulic pump assembly has failed. http://www.realoem.com/bmw/enUS/partxref?q=21532229715
I had changed hydraulic pump and clutch position sensor but problem still did not solve. What/where else should I look into? Been almost a year since I bought and always in the garage and I drive not more than 300km. Could anyone pls help me?
Old 02-28-2017, 11:42 AM
Did you check the clutch actuator if leaking?
Old 02-28-2017, 11:45 AM
Mein Auto: 645ci
Will check and get back to u. Thanks
