Newbie looking at buying a car - Bimmerfest - BMW Forums
Old 06-24-2020, 08:36 PM
Bigjfrank Bigjfrank is offline
Mein Auto:
Hey all, newbie here. I am looking at buying a 2010 328i with 150k miles. Just looking to hear about general reliability. I know it will need maintenance, but all cars at 150k will. These seem like a pretty solid car and one of BMW's more reliable cars. This car is in very good shape and the dealership is super helpful and has the car priced right. Just looking to get opinions. Car seems to have been well taken care of. I will have a pre-sale inspection done. Please advise.
Old 06-26-2020, 07:26 AM
Mein Auto:
No one?
Old 06-26-2020, 08:01 AM
dharmabmw dharmabmw is online now
Mein Auto: 2006 530Xi
Have the inspection done and see what the mechanic advises. Keep in mind that in order to afford these cars, most of us do our own wrenching. Otherwise, an older BMW can be a wallet flush.....
2006 E61 MT
2010 E91 MT
Old 06-26-2020, 08:40 AM
Mein Auto:
Thanks! I am having a mechanic inspection done.
Old 06-26-2020, 08:44 AM
Yukoner Yukoner is offline
Mein Auto: 2011 328i x-drive
PPI (Pre-purchase inspection) is worth doing. 150K miles is a decent amount of mileage.....
You're looking at the second last year for the E90 328i (assuming we're talking a 4 door here). That puts you into the later model years of the generation, which is definitely where you want to be.
Things to look out for ?
- Ignition coils / plugs
- Leaking valve cover gasket
- Leaking oil filter housing gasket
- Leaking oil pan gasket
- Water pump failure
- Valvetronic system (component) failure
- Worn out drive belt / pulley / tensioner
- Signs of water leakage due to plugged drains
That's the common stuff. The rest is hit or miss - electronics can fail like the iDrive system (if yours is equipped with it), sensors can wear out, blah blah blah, but that stuff is all common to any ICE vehicle.
The expensive items are the water pump and oil pan gaskets, if you're not doing the work yourself.
How much is this car ? I'm betting somewhere between $5K and $10K USD ? Do you have another $3K to $4K USD to drop on preventative maintenance a month after you buy the vehicle ? Here's the laundry list of things that likely need addressing:
- Oil and filter change
- Brake fluid change
- Coolant change
- Transmission fluid and filter change
- Power steering fluid change
- Transfer case fluid change
- Differential fluid change
- Battery replacement
- Drive belt / idler pulley / tensioner replacement
That's the MINIMUM I would personally do. And I've done all the above, at a dealer, so I'm not some dude talking trash about spending money on preventative maintenance - I've actually done it.
If you DON'T have disposable funds available to perform maintenance (whether that's DIY maintenance or at a dealer / indy garage), then DON'T buy the vehicle. If you want this car to last you longer than a handful of months, at that mileage, you need to take proper care of it.
Not even sure if -40 degrees is cold anymore ?
Old 06-26-2020, 08:55 AM
Mein Auto:
It's about $5k purchase price. then drop $4-$5k in preventative maintenance immediately? so it's really a $9-$10k car? No thanks, I will pass. that's crazy.
Old 06-26-2020, 09:25 AM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is online now
Mein Auto: E93 335i, somewhat mod
No no no no.
That's BMW. Porsche. Mercedes too.
Why did you want a BMW?
Old 06-26-2020, 09:37 AM
Mein Auto:
Because it rides very well and drives nice? Not to repair all the time.
Old 06-26-2020, 09:50 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
https://www.e90post.com/forums/showthread.php?t=1517476
Old 06-26-2020, 09:59 AM
Mein Auto:
thanks, very helpful
Old 06-26-2020, 10:52 AM
It's a $60K+ car. You're valuing it at the depreciated used purchase cost. The actual cost of the car, when brand new, is $60K+. This means that ALL maintenance, parts, etc, are going to be valued against that original cost.
For example, a brand new crate engine for a 328i is going to run you ~$35K USD. That makes sense, since the engine is the single main component of the vehicle, and since the vehicle is $60K+, the replacement cost of ~$35K is justified. So if you consider that, then spending ~$4K in preventative maintenance to keep the existing engine you have healthy, makes a lot of sense.
Look, these are luxury vehicles. Dropping $1,500.00 next month on an unanticipated repair is supposed to NOT be a material concern for you. That's why I brought it up. There's nothing worse than buying something without a full understanding of what you're "getting into", and then being detrimentally surprised.
Also, just for reference, this isn't limited only to BMW. Mercedes-Benz, Audi, Jaguar, Range Rover, Bentley, take your pick of luxury brand, they're all the same. The luxury "game" is not the same as the econo-game. If it's not a game you can afford to play in, then don't. (I realize that comment might come off as conceded or entitled, but that's not the intent - I'm trying to ensure that you understand what you're getting yourself into and that you're prepared for it)
Old 06-26-2020, 11:31 AM
Mein Auto:
thank you Yukoner, and all of you. I appreciate your directness on this subject. I'm just not wanting to pay $5k for a car then have to sink another $4-$5k into it. Not what I am looking to do.
Old 06-26-2020, 12:30 PM
moosaud1998's Avatar
moosaud1998 moosaud1998 is offline
Mein Auto: 2009 BMW 328XI
I dont think it'll be $3-$5k if you do the work yourself. Everything's on google
Old 06-26-2020, 04:00 PM
edycol edycol is online now
Mein Auto: 328i xDrive 6MT
Ok, but at 150k you are about to invest a lot of money in any vehicle. Spark plug and coils on V6 transverse engines in Asian and American cars could go as high as $1,000. Water pumps too. Do you have maintenance history of that vehicle? If water pump is changed 20k ago, there goes away big chunk of what you need to invest. Ask about vehicle, maintenance records etc.
Sent from my iPhone using Tapatalk
Old 06-26-2020, 04:16 PM
Actually doesn't ride particularly well especially over potholes. Handles poorly; cornering force causes to roll onto side walls. Can be fixed....but you'll need aftermarket & M3 parts. Click on the suspension link [here].
Wanna have some fun? Test drive M3 to see what you can easily have w/335i, some cash; elbow grease.
Old 06-26-2020, 04:18 PM
Too true! Best as a hobby car; bad choice for daily driver.
Old 06-26-2020, 04:48 PM
marvinstockman marvinstockman is offline
Mein Auto: 1997 M#
Did you get a Carfax, which sometimes show the maintenance history. Also, the PPI mechanic should be able to tell you what it needs, and it may need nothing.
Old 06-26-2020, 04:53 PM
It will....it willl.
Old 06-27-2020, 07:44 AM
OP has to take into consideration that he is getting advice from people who maintain cars so meticulously that they will easily make 500k. So, things get expensive.
Old 06-27-2020, 07:48 AM
Mine is, Toyota Sienna is parked just for long trips when whole family is going.
Daycare runs? BMW. Grocery runs? BMW.
Old 06-27-2020, 08:02 AM
bmwbob51 bmwbob51 is online now
Mein Auto: 2000 BMW 540i 6 speed
Better be good with tools and willing to use them!
Old 06-27-2020, 08:48 AM
This is not my first rodeo with BMW.
Talking about wrenching, I have to replace rear shocks on Sienna, at 69k!
Old 06-27-2020, 11:30 AM
Easy, peasy. Plugs on Sienna, 4 hours+; 15 minutes for the front, 4 hours for the back. How about a defective rear O2 sensor......$2000 because the mechanic was too lazy to use a Dremel to remove the rusted nuts. Easier to replace half the exhaust apparently...
2006 E61 MT
2010 E91 MT
Old 06-27-2020, 05:47 PM
Oh I know plugs. I am dreading that job when time comes.
Old 06-27-2020, 07:34 PM
Oh I know plugs. I am dreading that job when time comes......
Don't wait too long. Plugs have been known to weld themselves to the head. The rear ones can be fatal.
2006 E61 MT
2010 E91 MT
