Torque Wrenches - Bimmerfest - BMW Forums
Old 06-28-2020, 04:21 PM
moosaud1998's Avatar
moosaud1998 moosaud1998 is offline
Mein Auto: 2009 BMW 328XI
Torque Wrenches
What size torque wrench is commonly used on BMW's? And how often will I need to use a torque wrench? I am planning on doing majority of the maintenance on my E90 (water pump, starter etc) and since the bolts are aluminum, it would be smart to invest in a torque wrench, Just not sure which one is most commonly used. 1/2 or 3/8?
1/2 I found on amazon: https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Old 06-28-2020, 04:59 PM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is online now
Mein Auto: E93 335i, somewhat mod
1/2" has greatest versatility though I also use 3/8"
I like Gearwrench electronic....beeps when correct torque is reached and does angle.
Old 06-28-2020, 05:04 PM
I was looking at Harbor Freight tools. Both 1/2 and 3/8 have lifetime warranty. So for $15 each, that's a no brainier.
Old 06-28-2020, 05:23 PM
>Snort< . Well, do they beep?
'Sides which, you now drive a BMW. A level of sophistication and reassuring expense is expected.
Old 06-28-2020, 05:28 PM
Just clicks
Old 06-28-2020, 05:30 PM
What brand jack and jack stands do you use? If you don't mind me asking
Old 06-28-2020, 05:51 PM
Bought jack stands @ Sears when they were in business; others so old don't remember - all 3 ton. Floor jacks at Sears, have a pair.
But I also scored a Bendpak mid-rise lift and in case lift is in the way, I rest tires on 12" Raceramps wheel cribs + pull lift outta the way.
ppointer ppointer is online now
Mein Auto: '11 335i, '00 323it
I did one of each. Haven't used the 3/8" all that much on a car, but use it often on motorcycles. Anything less than 30lbs I don't trust to my 1/2", but that one gets used most often. Brand of mine - Craftsman.
Old 06-28-2020, 06:09 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Big fan of these two. Hard to find one torque wrench for all jobs because of small torque and huge torque requirements. I have done extensive work and these have been great. No worries on size because you can always get an attachment that does not effect functions. Click image for larger version
ID:	898581Click image for larger version
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 06-28-2020, 10:22 PM
08 335Ci 08 335Ci is offline
Mein Auto: 2010 335 M sport
The majority of the torque settings on the engine are between 6 ft/lbs (72 in/lbs) to 14 ft/lb (168 in/lbs). A 1/4" in/lb wrench will do 80% of the engine fasteners. The power steering pump is 28 ft/lb so a 3/8" wrench works for that. Wheel lugs are about 100 ft/lb, 1/2" wrench for those.
BMW uses a torque to yield process. Example 12mm head bolts: 28 nm +90 degrees + 90 degrees + 45 degrees. So an angle meter is necessary for the proper torque.
HINT: Not all bolts are aluminum. Some are aluminum coated steel. Those bolts can be reused. A magnet will show which ones are steel. And make sure you get the PROPER Torx drivers and sockets. BMW uses a lot of T8, T11 and T14 sockets and T15, T25 and T27 bits. Don't scrimp on them. A few dollars spent here will save a lot of headaches later.
No matter how fast I go, there's always someone slower in front of me.
2010 E92 335 M Sport, Titan Silver Metallic, Steptronic, JB-4 G5 ISO, WMI, 3.5 Tmap (22 psi boost), ARM Relocated inlets (don't do it), BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC, Pedal tuner, Escort Max 360
Gone, but not forgotten ( totaled)
'08 335 E92, M-Sport suspension, 6 sp auto, w/paddle shift
CCA Member 109065 since 1993
Old 06-28-2020, 10:52 PM
I'll also need E torx sockets too, correct?For things like The water pump starter Etc, would I need a 1/2" or 1/4" torque wrench?
Old 06-28-2020, 10:59 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
You need two torque wrenches to cover the Common
fasstners in a BMW correctly. It's a matter of range.
Old 06-28-2020, 11:11 PM
1/2" and a 3/8" correct?
Old 06-29-2020, 04:56 AM
MadJoe MadJoe is offline
Mein Auto: 2011 328xi
Correct, a 3/8" and 1/2" torque wrench will cover ~90% of all bolts you need to torque on a BMW and 100% of the common ones you'll be torquing. Also you'll want at least 2 E-Torx sets because inevitably you'll misplace one on the set you're using and need to quickly get a stand in until you can do a more thorough search for the missing one. At least that's been my experience
And wheel lug torque is only 88ftlbs +/-2ft/lbs. You absolutely do not need to put more torque on them. As long as you haven't greased your lug bolts up with something like anti-seize they aren't coming off when set at the correct torque, but they can part (break in 2), and/or warp your rotors if you over-torque them too much. I've learned the hard way that it's a great idea to remind any garage that's doing work that requires them to remove a wheel that the torque values are what they are (and then go back and double check when they're done).
Old 06-29-2020, 05:03 AM
The lowest value of torque I know of on a BMW is 2nm. Thats low. You will need a nice torx set. There are adapters to change the socket size. Check out these sets. They have been great for me at a great price. Click image for larger version
ID:	898653Click image for larger version
https://www.lowes.com/pd/Kobalt-10-P...B&gclsrc=aw.ds
(They make a larger adapter set. This one just for example of what you can buy)
Old 06-29-2020, 05:19 AM
+1 on @madjoe reply
Old 06-29-2020, 07:25 AM
propchef propchef is offline
Do You Smell That?
Mein Auto: 997.1
Im looking for a low value torque wrench right now. Even most 1/4 drive wrenches only go to 10ft/# and I need as low as 7. Any recs?
Sent from my iPhone using Tapatalk
Old 06-29-2020, 07:30 AM
As I posted above. This would suit your needs. EPAuto 1/4-Inch Drive Click... https://www.amazon.com/dp/B01LX4ND65...p_mob_ap_share
Old 06-29-2020, 08:09 AM
Do You Smell That?
Mein Auto: 997.1
Torque Wrenches
Thanks but sorry, no, I looked at that one. The range is 20-200 which I already have. I need it for far lower values. Im doing a water pump in a 997 and I need values as low as 7ft/lb
Old 06-29-2020, 08:16 AM
Torque Wrenches
7ft/lb = 9.49nm. This wrench is 2.26nm-22.6nm. Your needs are easily within the range.
The 20-200 is for inch lbs not foot lbs.
Old 06-29-2020, 08:20 AM
Do You Smell That?
Mein Auto: 997.1
Today I learned something. Thank you very much!
I need to look closer. Greatly appreciated.
Old 06-29-2020, 08:47 AM
Jim328 Jim328 is offline
Mein Auto: 2008 328xi
I was looking at Harbor Freight tools..
I purchased a torque wrench from Harbor Freight several years ago.
I was greatly saddened to discover that I had received exactly what I paid for, when the bolt I was tightening sheared off, because the inexpensive torque wrench was not accurate.
Your mileage may vary.
Since then, I've purchased 3; with different torque ranges and sizes at home depot.
2008 328xi
BMW CCA
Old 06-29-2020, 09:00 AM
Some of that harbor freight stuff is pretty bad. My torque wrenches came with calibration printout numbers specific to the wrench I received. Not just reprinted from what I can tell. There are some ways to test it at home. Like hanging a 10 pound weight from it when the head is in a vise. Some stores even have a calibration station for free. Remember to store them at the lowest setting. Try not to drop them. I also test at half the needed torque to hear the click and then adjust closer or full.
Old 06-29-2020, 09:13 AM
Patton001 Patton001 is offline
Mein Auto: 2009 335i
These days you will also find frequent need of a 1/4" that measures inch pounds. None are terribly expensive unless you get into the electronic tools
Old 06-29-2020, 05:01 PM
I picked up this one off Amazon I checked it against my 3/8" Snap On wrench and it was right on.
The only thing I don't like is if you're not careful the friction lock loosens and your set value changes plus the ft/lb scale is a little hard to use so I just convert to in/lbs. 1 ft/lb = 12 in/lb.
