Z3 electricial system flickers - Bimmerfest - BMW Forums
Old 10-10-2012, 10:30 AM
tjh54 tjh54 is offline
Mein Auto: bmw 2001 z3
Bmw z3 when I hit a bump, or shift gears the electricial system flickers. Could this be motor mounts or trans mounts?
Old 10-10-2012, 10:59 AM
wifesauto wifesauto is online now
Mein Auto: sloporsche
loose electrical connection some where,start at the batt................good luck
Old 10-10-2012, 11:30 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
Aftermarket battery? Some batteries' posts are slight undersize relative to the battery cable connectors. You may need battery post shims. Autozone is one place that has them - http://www.autozone.com/autozone/acc...ntifier=257147
Start by checking the battery connections are clean and tight.
Old 10-10-2012, 11:49 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
I would follow wifesauto's advice. Double check all electrical connections. Good luck.
Old 10-10-2012, 01:17 PM
Thank you for your suggestions. I checked a few connections under the hood and started the car. As I was backing up I hear sparks coming from somewhere behind the passenger's seat and the car went dead. I disconnected the negative terminal with sparks flying. HELP!!!!
Old 10-10-2012, 01:30 PM
this maybe the time for a flatbed to a shop you trust. DO NOT HOOK UP BATTERY
Old 10-10-2012, 02:57 PM
I just had a new battery, (covered by insurance) installed by the dealership. They failed to reconnect the bracket that holds it in place. When I hit that bump it must have moved the battery to where it caused a short to exist. I had to use a grinder on the bracket so that it would work with the new battery. The test drive seemed okay, I'm keeping my fingers crossed. Thanks for all the help.
Old 10-10-2012, 05:26 PM
gee i wonder if you had given us some history on the car if that would have helped................
Old 10-11-2012, 05:48 AM
formerly updmst
How did you get insurance to pay for a BMW battery? Has the car been in accident?
Old 10-12-2012, 07:09 PM
My car was parked outside of my girlfriend's house when we had 13 inches of rain in an hour. Progressive wouldn't total it so I keep taking it back to the shop they had taken it to originally every time an electrical problem occurs. I will not sell it to else and make it their problem or let progressive off the hook.
electricial, flickers, system
