2001 z3 intake camshaft postion sensor - Bimmerfest - BMW Forums
Old 10-02-2011, 05:42 PM
tjh54 tjh54 is offline
Mein Auto: bmw 2001 z3
My 2001 3.0i z3 with 73k mile has the check engine light on. The code was for the intake camshaft position sensor. I replaced it however after driving it for about 10 miles the code came back. I removed the sensor and double checked to make sure everything was installed correctly. The light came back on. Does anyone have an idea on what I should check next?
Old 10-03-2011, 06:23 AM
yellowjack yellowjack is offline
Mein Auto: Z3, 2.3 2000, Passat 1.8
Did you reset your service light?
Old 10-03-2011, 08:28 AM
Yes, I reset the light.
Old 10-03-2011, 05:46 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
What is your exact code say?
Old 10-03-2011, 07:58 PM
It is just two numbers that tell me I have an error with my intake camshaft postioning sensor.
Old 01-17-2012, 12:44 PM
roswelljohn roswelljohn is offline
Mein Auto: 2001, Z3 2.5 roadster
Same problem
I have the same problem...was there ever a solution?
Old 01-18-2012, 08:13 AM
eken eken is offline
Mein Auto: 2001 Z3 3.0i
What are you using for a code reader? OBDII reader should read one of these codes PO340, P0344, P0365, or P0369 Camshaft Position Sensor The first two refer, I believe to the exhaust sensor and the last two to the intake. Was the part you replaced a genuine BMW part from the dealer? I've heard the some of the after market parts can be faulty. I had the same problem in the summer and replaced the exhaust sensor with genuine part and have not had a problem since.
Ekenn
Old 01-18-2012, 12:51 PM
fault Codes
Using Peak R5/FCX3 tool Table 19 code 41
I am waiting for delivery of new OEM intake camshaft position sensor.
will update later today...thanks and anything else you can tell would be great...THe installation is pretty strait forward according to Bentley service manual and second time for me.
Old 01-18-2012, 06:07 PM
Good news... installed the new OEM (intake camshaft position sensor) and 30 miles and numerous engine starts...NO FAULT codes. hurray!
