BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Help with F10 ACSM reset to OEM
Hi all,
Happy New Year!! I messed my F10 ACSM module after coding it just after my wife's F25. Now I have an Airbag faulty code and System restrain Module error at the iDrive. How do I reset and re-code the ACSM module with the Factory configuration? Any helps and directions will be appreciate. Thanks, Alex |
Sponsored Links | ||
Advertisement | ||
Does ACSM have CAFD with Green Dot next to it?
If so, you need to lock ACSM: Lock ACSM (Required After Flashing to reset the Airbag) Try E-Sys Transmitter: Click "External Applications" in the left menu. Click "External Application" Double-click "Transmitter" Double-click "ACSM verriegelung_schreiben" (ACSM verriegelung_schreiben_new?) If that does not work, try EDIABAS / Tool32: Launch C:\EDIABAS\Bin\TOOL32.EXE Hit F3 Load C:\EDIABAS\Ecu\ACSM4.prg In the "Select Job: F01" window, select steuern_verriegelung_schreiben Hit F5 Results" window should show "JOB_STATUS = OKAY" Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc. |
Thank You Shawnsheridan!
Do I need a new EDIABAS Version? Could you PM where I can find it? Thanks, Alex |
Advertisement | ||
PM sent.
Hi Shawnsheridan,
The F10 ACSM ECU still with the issue. When I read the CPS from ACMS it shows [yyyyyyy] instead of the VIN. Should I send it to the dealer or is it possible to fix this error? Thanks for you help. Alex |
Back to my first question. Does ACSM have CAFD with Green Dot? If so, what is name of CAFD?
It shows: ACSM[1] BTLD_00000906_003_003_001 HWEL_0000090C_002_005_000 SWFL_00000908_004_003_001 Thanks, |
Exactly, and therein lies your problem. You must inject CAFD (all 3 of them) into ACSM and VO Code it,
How do I inject the 3 CAFD into ACSM?
PM me TeamViewer login and I will fix it
Solved by Shawnsheridan! Thank you very much.
Be my guest when you fly to Rio!! |
Sp-daten files and stupid brother
hello I have a 2007 x5 my brother convince me that he can update daten files so now the issue is I have an error on my screen pass. restraint system so my question is how do I go back to an old file to corrected please keep in mind I'm new and have a day and a half of reading all this information I appreciate
Hi shawnsheridan, I have 2011 535xi, I have a few issues I need help with. I have code 930AB7 after replacing airbag and seatbelts. (Three crashed data stored) how can I recode the acsm. 2) I changed the fog lamps to led from a 2014 style, how can I code it to the car in order to get rid of the fog lo malfunction message. Thanks in advance.
Clear Fault Codes:
Lock ACSM:
As for LED Fog Lights, I would FDL Code the fol;lowing: FRM => AUSG_11_NSW_L_IS_LED = aktiv FRM => AUSG_11_NSW_L_KALT_UEBERW_AKTIV= nicht_aktiv FRM => AUSG_11_NSW_L_WARM_UEBERW_AKTIV = nicht_aktiv FRM => AUSG_12_NSW_R_IS_LED = aktiv FRM => AUSG_12_NSW_R_KALT_UEBERW_AKTIV = nicht_aktiv FRM => AUSG_12_NSW_R_WARM_UEBERW_AKTIV= nicht_aktiv
Thanks ill try that and let you know if it works.
You need code DSC,SZL will be coded.
Shawnsheridan
Can you please help me because im stuck i the same position? The green dot is missing and i cant fix it. I have teamveiwer and the esys software. Thanks |
Did you try and Inject CAFD into it and VO Code ACSM?
I dont know how to do it my friend
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on ACSM => Click on "Detect CAF for SWE" => Select the CAFD (all 3) from latest I-Level shown => Select OK => Right-Click on ACSM (the ECU itself not the underlying CAFD) => Select CODE.
#25
Hello,
I have the same problem, after uptade all block in my F10, i get the airbar error. and if i go in e-sys "ACSM verriegelung_schreiben".. the error is still there do you can help me ? i have TeamViewer |
See More Related BMW Stories |
Forum Navigation | |||||||
Today's Posts Search |
Thread Tools | |
Display Modes | |
