2008 BMW 328i Errors - Bimmerfest - BMW Forums
Old 03-12-2018, 01:47 PM
AswanE90 AswanE90 is offline
Mein Auto: 2008 BMW 328i
Quick back story about this car
I purchased this vehicle from copart as a project to get it back on the road it is flood car and the water level is to the top of the steering wheel.
Note: this the first BMW to work on so I'm not a little feel lost.
first thing i did is opening and cleaning all the electronics and modules.
The vehicle now is turning but no start.
I checked the spark plugs for power but no sparks.
I scanned the vehicle with FOXWELL NT510 and here's a list of the errors:
A0B6/present CAS: Selector-level interlock
A0B5/present CAS: Fault, road speed signal
A0B0/not present CAS: Input, brake lights, implausible
A0B3/not present CAS: Starter motor, terminal 50
CF1C/present EGS: No messages from engin control
CF1D/present No messages from DSC, receiver DHG/DSC
CF19/present No message (wheel torque request) from the LDM, receiver DKG/EGS, transmitter KOMBI/LDM-DSC
CED4/present No message (0xAA) receiver EKP, transmitter DME-DDE
D13E/present Message from control unit, receiver RDC
A091/present FZD: Sunroof drive
E717/present Message (engine data, 0x1D0) faulty, receiver IHKA, transmitter DME-DDE
E71A/present Message (torque 3, 0xAA) faulty, receiver IHKA, transmitter DME-DDE
E71C/present Message (speed, 0x1A0) faulty, receiver IHKA, transmitter DSC
9C6E/present IHKA: Solar Sensor
E71B/present Message (heating current, engin 0x1B6) faulty, receiver IHKA, transmitter DME-DDE
E720/present Message (power management, consumer/load control, 0x3B3) faulty, receiver IHKA, transmitter DME-DDE
9C50/not present IHKA: Rear compartment stratification flap motor
A3AC/present Message (distance traveled, 0x1A6) faulty, receiver KOMBI, transmitter DSC
A3AD/present Message (engin data 0x1D0) faulty, receiver KOMBI, transmitter DME-DDE
A3C1/present Message error (footwell module, 0x4F0), receiver instrument panel, transmitter footwell module
A3B9/present Sporadic fault (failure, DSC message, 0x19E0) No repair measures available, receiver KOMBI, transmitter DSC
A3B4/present Message error (lighting state, 0x21A), receiver instrument panel, transmitter footwell module
A550/present Message (speed, 0x1A0) faulty, receiver KOMBI, transmitter DSC
A3AE/present Message (engine speed, 0x0AA) faulty, receiver KOMBI, transmitter DME-DDE
C90B-not present JBE: PT-CAN Communication fault
C918/present No message (wiper operation, 0x2A6), receiver JBE: transmitter FRM/SZL/LWS/IHKA
A6C9/present JBE: Windscreen wipers
A6CF/present JBE: AUC sensor
93C3/present MRS: Seat-occupancy detection, passenger
93FB/present No message (vehicle speed) from DSC, ACSM receiver/MRS5 DSC transmitter
93B3/present MRS: Passenger airbag, stage 2
93B4/present MRS: Driver's airbag, stage 2
93AB/present MRS: Passenger airbag, stage 1
I really appreciate any help understanding these error and how to fix them.
Thank you all in advanced
Old 03-16-2018, 01:08 PM
damittron damittron is offline
Mein Auto: 2009 335i Coupe M Sport
The diagnostic tool you have is pretty good for general stuff, but you should find the BMW specific software and dongle to use with a laptop. It will give you a lot more information and allow you to get much deeper into specific issues to better pinpoint the problems. It looks like you have your hands full, but all of this may be tied to 1 or 2 parts that you can replace and save tons of time and money.
Old 03-16-2018, 01:57 PM
Thank you for your reply,
I installed few software on my laptop but I'm a little confused with what is the right cable to buy for diagnosing, coding and programming.
Old 03-16-2018, 03:58 PM
gbalthrop gbalthrop is offline
Mein Auto: 2007 328xi E91
If you installed INPA or ISTA, then a K+DCAN Cable is what you need to connect the OBDII socket to your Computer USB port, and the BimmerGeeks Cable at $45 is suggested more than any other on this site:
https://www.bimmergeeks.net/product-...eeks-pro-cable
Read the BimmerGeeks site info as to what is needed for certain types of flashing or other uses other than diagnostics.
I am NOT familiar with your Foxwell scan tool, but it appears from a quick glance at your post of readout that the DME (Engine Control Module) is NOT functioning, for instance 5th line says EGS (Transmission Control Module) can't communicate with DME. Also I don't see any indication of any code from the DME, either present or past. If your Foxwell has the ability to connect to the DME alone, try to get it to do that & see if it confirms that it CANNOT connect.
I would suggest trying to get the DME to power up. There is a separate relay that powers the DME. The DME itself activates the relay K6300 soldered into the JB as shown in this "Installation Location" link:
https://www.newtis.info/tisv2/a/en/e...i-lim/IROpqxeg
Here is the Wiring Diagram for the Relay:
https://www.newtis.info/tisv2/a/en/e...8-fuse/vFbq6N3
NOTE: there is a typo for the Connector at the DME; it SHOULD BE X60005; see pin #13 of Connector X60005, White/Gray wire in the 2nd diagram below.
Here are other relevant Circuit diagrams for the DME:
https://www.newtis.info/tisv2/a/en/e...l-unit/hqIOB9Z
https://www.newtis.info/tisv2/a/en/e...l-unit/hsMiJTp
https://www.newtis.info/tisv2/a/en/e...l-unit/i0Xh6ut
https://www.newtis.info/tisv2/a/en/e...l-unit/i6jSpwF
You have quite a project on your hands, and I wish you luck,
George
Old 03-16-2018, 07:01 PM
Thank you George!
I actually sent the ECU, CAS and 1 Key to the repair shop so they can test it but most likely they gonna get me another ECU and they gonna sync the CAS and Keys to the ECU.
Also I bought relays to replace
1 black for the ECU
1 black for the fuel pump
1 green for the wipers
1 blue (I can't remember for what)
I installed ISTA, INPA, NcsExprt, NcsDummy, WinKFP, Coding Tool and few more.
Please let me know if you have any sugestion.
I will keep you posted with all updates.
Old 04-27-2019, 10:42 AM
shaun.marsh shaun.marsh is offline
Mein Auto:
I bought a 2011 bmw 335ix coupe and that is my dream car. I just don't understand why I'm already running into troubles. I bought it with 56,234k miles I've drove it only 2,000 miles. Right now i need to change water pump, new temperature measure, oil gasket housing.
Old 05-01-2019, 12:08 AM
bmw330cigirl bmw330cigirl is offline
Mein Auto:
08- 335i twn turbs. Steering assist keeps going out. Showing brakes, DSC, dash lights. Don't have the codes. My mechanic clears the codes, & they keep coming back shortly after. This has happened 3x's within last 6mnths. Also after having a new steering angle sensor replaced. Is this common for this model and year? Any suggestions, besides selling it..
Old 05-01-2019, 07:10 AM
relative4 relative4 is online now
Mein Auto: '08 335xi E90 manual
Is this the designated thread for threadjacking?
Old 05-01-2019, 06:21 PM
BMW-North's Avatar
BMW-North BMW-North is offline
Kostspieliger Spaß Quandt
Mein Auto: e46;e92;f30;e83, AMv8v
I’m assuming the person who replaced the SAS performed the necessary calibration routine and coded the part to the vehicle. These are required steps for replacing that component.
2008, 328i, bmw, code, e90, error
