Turbo Lag/Wastegate Discussion - 2008 335xi - Bimmerfest - BMW Forums
Old 06-18-2019, 02:31 PM
PlzCalmDown PlzCalmDown is offline
Mein Auto: BMW 330Xi
Hi,
I was a long time owner of a N52 E90, I finally had to part with the vehicle after hitting 325,000km due to work =(
I recently picked up a used N54 - 2008 335xi. The vehicle has significant wastegate rattle when letting off the throttle. I purchased knowing there was this issue.
My question is... does a wastegate rattle mean that the turbo/wastegate definitely needs a rebuild/replacement ? Am I losing power/fuel economy at the moment? I have tried searching da Google and da forums with no luck... the vehicle still pulls hard, a lot faster than the N52 - 330xi. So I'm unsure if the vehicle is faster based on pure engine power, or if the turbos are still functioning fine albeit with waste gate rattle. I just don't want to spend the time or money ($3500) to have the turbos pulled and rebuilt, just to find out all I paid for was to get rid of the wastegate rattle sound.
For those that have, or recall; on a 2008 335xi STOCK everything. Is there turbo lag on a OEM setup ? Should the vehicle pull hard then you feel a noticeable turbo kick at a specific RPM ? Or is there no turbo lag and the vehicle just pulls fine at all RPMS's and gears etc.
Thanks for any input !
Old 06-18-2019, 10:14 PM
Mech_Man's Avatar
Mech_Man Mech_Man is offline
I'm much better now, Dave
Mein Auto: 2008 335i e92
I have an e92 (2008). The waste-gate rattle was a huge and very public problem for a year or so when it first came out.
Then the dealer fixed it. I believe by a recall.
Go online and check for Service Bulletins and such. I think they reprogrammed the gate software. The rattle came from a tune aspect that was a bit off, I think.
RE: your second question about Turbo Lag. This also comes from the gate problem. After it's fixed, there will still be a lag, (can't avoid some, from any turbo), but its barely noticeable, certainly less than the single-turbo car I had before.
-=] 2008 335i e92 Montego Blue & Black; Prem; Sport; AT-paddles
-=] Mods= VEI Digital Boost Gauge in RiXeffects custom Pod
-=] Tinted (front: 3M Crystalline 70); (rear: Johnson InsulatIR 40 ceramic); 3M ClearBra
Old 06-18-2019, 10:25 PM
Thanks for the response Mech_Man. Your E92 has noticeable lag though? As in, if you accelerate and floor it. You can feel the difference between engine power and when the turbo kicks in?
Old 06-19-2019, 08:12 AM
Mech_Man's Avatar
All turbos have lag. It's a physical limitation.
On increase of need, it takes a moment for them to overcome their own inertia and spin to a faster RPM.
BMW went to two smaller turbos (one for each half of the 6 cylinders), for the N54 engine, so each turbo would have less mass, therefore less inertia, therefore less lag. Which is true, except the software controlling the waste-gate (the bypass flapper-valve) was set too far, and caused the rattles.
My first car was a Dotson (now Nisan) 280Z with one turbo. It had a lag that was a bit more than my e92. Punch-it, and the car would just barely start going faster, then there was a half-second pause, then catapult off the flight deck.
Old 06-19-2019, 08:31 AM
Mech_Man. I think youíre misunderstanding. I am aware of how turbos work etc. I am simply asking, if you are at a dead stop, and accelerate to 100km/h etc, do you actually feel a noticeable moment where the turbos kick in.
Iím going to go test drive a used 08 335xi at a used dealer to find out for myself, then at least I will have a baseline to decide repairs
Old 06-19-2019, 09:05 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
No, unless you are paying close attention and deliberately trying to catch the engine off-guard. Under WOT, these engines produce full rated torque from just off idle (~1,300rpm IIRC).
Now, transmission lag, for the automatics...that's a separate question.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
Old 06-19-2019, 09:39 AM
Thank you!
e90, lag, n54, turbo, wastegate
