Ampere draw on 2005 Z4 3.0 - Bimmerfest - BMW Forums
Old 10-14-2019, 12:59 PM
ATCBMW ATCBMW is offline
Mein Auto: 2005 BMW Z4 3.0i
Does anyone know how many amp's are drawn with car asleep on 2005 3.0. Had a parasitic battery drain which was pulling 1.55 amps. 3rd tail light leaked and I had water in the battery compartment. Radio quit working so I am pretty sure radio amplifier is fried. Since radio didn't work I pulled the 7.5 and 10.0 fuses associated with it. I still have a 0.55 amp draw which seems high. Figured with car asleep it should only be around 0.05 amp or in that neighborhood. I do have yellow ABS and DTC light on but just replaced battery. Thanks for your help in advanced.
Old 10-14-2019, 01:30 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Closed circuit current (what BMW calls properly off current) is probably about 20 mA, 0.02 Amps but does vary with equipment and platform.
newTIS.infobeta
Home / BMW E85 Z4 3.0i Roadster / Wiring Diagrams and Functional Description / Power train / Voltage and current control / Voltage and power supply / Standby current / Closed-circuit current measurement
https://www.newtis.info/tisv2/a/en/e...urrent/XPSPyxk
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 10-14-2019, 10:01 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
.55 A is high, have you tried pulling fuses one by one until it drops.
[SIGPIC]
Old 10-15-2019, 05:55 AM
Thanks folks for the help/information
Pulling or checking each fuse is my next plan
Old 10-15-2019, 08:57 AM
Nuclear engineer
Pulling fuses is not required by BMW Advanced Technical Diagnosis. I have posted it and / or the fuses excerpt a number of times. See Current Draw Diagnosis page 216
File Type: pdf Advanced Vehicle Diagnosis - 07-2013.pdf (7.14 MB, 17 views)
