Help: Audio system has no sound - Page 2 - Bimmerfest - BMW Forums
Old 06-25-2017, 10:42 AM
Bucknfl Bucknfl is offline
Mein Auto: 328i
Fixed
I had the same problem on 2012 328i convertible. I took car to an independent garage that had a bmw computer analaysis system. They hooked it up to my car & did a software update & it fixed the problem. They had no idea what the issue was but its been fixed.
Old 07-14-2017, 04:47 PM
Lonnienielson Lonnienielson is offline
Mein Auto: BMW X5
Then what?
Originally Posted by wilt View Post
It could be that some liquid spilled in your trunk and it gravitated to the amp location under the floor of the trunk.
I had some ice that melted in the back of the X5 and think that might have been the coincided with the outage on my radio. What do I do to fix it?
Old 07-14-2017, 04:51 PM
efodela efodela is offline
Mein Auto: e90 325i
You need to find where your amp and combox is located.. if it's on the side at the rear I doubt the ice caused it..
Sent from my SM-G935W8 using Tapatalk
Old 07-14-2017, 08:40 PM
gbalthrop gbalthrop is offline
Mein Auto: 2007 328xi E91
Radio Fuses
I didn't read every post in this thread (BEGUN OVER 5 YEARS AGO -- why do people on this forum DO THAT -- why add to such an old thread that may NOT have even resulted in any meaningful info or solution to any identified problem???)
However in the posts I DID read, I never saw anyone mention the following:
You have TWO separate fuses:
(1) 10Amp (Red) for the radio dash or head unit (F14 for 2008 & later)
(2) 20Amp (Yellow) for amplifier located in rear cargo area (F15 for 2008 & later)
So YES, melted ice in rear could have damaged the amplifier, or shorted the electric supply wire. So IF your radio control panel lights up and displays stations or tracks, but you get NO sound, check your AMPLIFIER fuse, if you have one (if fuse socket 15 is empty, you may NOT have an amp. To see if you have Option S676, HiFi Speaker System (which has a small amp), enter your VIN in the following page and see the list of Options actually installed on your vehicle:
https://www.etkbmw.com/bmw/EN/vin/decoder/online
George
Old 10-14-2017, 12:28 PM
DLozada28 DLozada28 is offline
Mein Auto: 2006 330i sedan
Hello all I have a 2006 330i (no navi or cd changer) and recently the sound to my radio went out. Upon checking for signal from the optic cable connecting to the amplifier, I see a red blinking light which is good. I then checked the connection for the telephone module and I noticed it had already been bypass looped (which is why I never had Bluetooth. My guess is that both modules are bad . So my question is can I bypass both the amp and the telephone module to at least restore the sound to the front speakers? When I plugged both bypass loops I finally get a connection at the optic connection under the steering wheel, I also have a red light when I connect my radio. Help anyone ? Looking for a bypass until I can purchase both modules let me know if I'm missing another module or connection somewhere as I can only find info on e60s.
Old 05-12-2018, 01:50 PM
Berry1210 Berry1210 is offline
Mein Auto: 2012 BMW 750li
I have a 2012 750li with no sound. I woke up headed to work with no chime or sound. I can turn the knob and don't get any sound from the radio. The radio isn't on mute and it doesn't indicate that the sound is going up or down any more. I've read several threads saying it may be the amp so I went out and replaced the amp still nothing. Any suggestions
Old 08-07-2019, 02:36 PM
oRIDDLERo oRIDDLERo is offline
Mein Auto: 2006 BMW 650i
Just has this issue, this video help me out with the SOS issue / no sound:
Old 08-08-2019, 05:36 PM
wilt wilt is offline
Mein Auto: 2011 328i
Considering that SOS needs an outdated and no longer supported wireless network, you might ask yourself about "WHAT VALUE to be had in FIXING this?!"
Old 08-08-2019, 08:57 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
The thing about the Most Bus is any module bad in the Most Bus takes
everything out on the Most Bus. And if you have the Logic 7 amp it
takes out the sound to. If you did want to bypass the SOS completely
you have to program it out and bypass to the Most Loop at the TCU
with a Most Jumper. If you happen to have bluetooth phone programmed
on that module you will loose it.
https://www.e90post.com/forums/showthread.php?t=1641149
https://www.newtis.info/tisv2/a/en/
I would look up as much as I can at the tis
BMW uses the same sound system's across a lot of cars but the upper models may be different.
Also this is time warp thread why bring it back from the dead.
Old 10-04-2019, 08:11 AM
This was the answer to the no sound issue with my car. This loop seems to universally fit all components - https://www.amazon.com/gp/product/B07PDJPXCW It seems like it has helped allot of people:
audio system, e90, no sound
