ABS Tone Ring Cracked - Replacement - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 08-01-2014, 06:25 AM
gbmw2001 gbmw2001 is offline
Mein Auto: 2001 BMW 330I
I have a 2001 330I issue where the traction control is engaging all the time on smooth dry surfaces and the ABS will sometime engage. I took it to a local shop and they said the left rear tone ring is cracked and needs to be replaced (associated sensor is also shot). They said the part was not available even from a dealer and that instead the entire axle would have to be replaced. I looked at a few parts sites and can't find the part. Is anyone aware of where to get this part or is the shop correct in saying that the axle needs to be replaced? Irronically this shop did brake work on the car 1 month prior. Is it possible that they did something incorrectly which could have caused the tone ring to crack? Thanks....
Old 08-01-2014, 10:37 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
I say BS on part availability from the dealer! But, it does look like the rear wheel speed rings are attached to the axle.
Personally, I'd find another mechanic. Get recommendations from the Windy City chapter of the BMWCCA. It has a website, and members are happy to make recommendations.
Old 07-31-2017, 07:34 AM
Monkeywrenched Monkeywrenched is offline
Mein Auto: 2008 128i
Did you ever figure this out? I'm having the same problem with mine, the dealer is saying both axles' tone rings are rusted and swelling.
Old 07-31-2017, 07:54 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Then, unfortunately, you need to replace the axles. The tone ring is not available as a separate part.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
abs, tone ring, traction control
