10' e90 ac problems! - Bimmerfest - BMW Forums
Old 10-01-2016, 12:47 PM
Cdm86 Cdm86 is offline
Mein Auto: 2010 bmw e90 328i sedan
Hello guys!
I have a 2010 e90 328i sedan with different problems but of them is when I turn the ac on, the car begins to fail especially when I stop on a red light or parking sometims even looks that it's going to die, but reverse and neutral is fine! So conect the scanner to the obd port and got that in the pic.... anyone knows what is that mean or any can help me? :dunno:
Thanks.
ID:	577870   Click image for larger version
Old 10-03-2016, 02:27 PM
Anybody???
Old 10-04-2016, 06:24 AM
Spacegray Spacegray is offline
Mein Auto: E90 328
Idk what those codes mean maybe someone will be able to translate that?
But I also have the same car sedan '10 328i & I have the identical symptoms for my a/c. It gets freezing on the highway but in traffic it acts up.
https://www.bimmerfest.com/forums/sho...d.php?t=453774
^ recharge
Or
https://www.bimmerfest.com/forums/sho...d.php?t=617542
^ Post #4
IHKA is basically the auto climate combines cluster for hvac controls.
Taking it out is easy maybe worth mentioning my car has already had the evaporator replaced under warranty. Id get someone from an indy or AutoZone to read those
Old 03-08-2019, 01:12 PM
shaun.marsh shaun.marsh is offline
Mein Auto:
I have a 328i 2012 BMW. The AC works but for some cause when i set the temperature on 60 it is very cold however when I set the temperature on 62 and above it gets really hot. So 62-63 and above is really hot air 60-61 cold air. Please suggest me why reason for that?
Old 03-08-2019, 01:38 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Problems with the Hot-water Control Valve(s) are quite common as the seals disintegrate and (partially) block the valve seat orifices.
You may get better advice with your own thread.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
328i, ac, ac compressor, ac failed, ac leak, air conditioner, air like, bmw sedan. n52, e90, obd code, repair ac, sedan
