rear quarter window seal (molding) - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F12 / F13 (2012 - 2018)
The all new 3rd generation 6 series coupe (F13) and convertible (F12) forum. The F06 BMW 6 Series Gran Coupe forum is here
Old 07-14-2019, 04:06 PM
Gene37 Gene37 is offline
Mein Auto:
Has anyone had to reattach the window seal to the rear quarter window on a 650i convertible. it looks like its just glued on. is there a special epoxy you need to use? It just popped off when we put the window up after putting the top down.
Old 07-14-2019, 06:50 PM
Yardney Yardney is offline
Mein Auto: X3 28i
Do you mean on the front edge of the window? Can you post a pic?
Old 07-15-2019, 04:17 AM
Mein Auto:
Yes the front edge. I can not figure out how to add a pic.
Old 07-16-2019, 05:18 AM
Mein Auto: X3 28i
I've never heard of that problem in the 18 months I've been on this forum or others. I assume you mean the metal came loose from the glass and not the rubber from the metal. I don't know that you need anything special. I think the most important thing is to prep and plan a bit so you are ready to clean off what squeezes out. I honestly think I'd try automotive or marine Goop. It adheres well to glass, is pretty strong, and remains a bit flexible. You'll need to let it sit overnight to cure without moving things.
Old 07-16-2019, 06:50 AM
Mein Auto:
It popped off clean (metal from glass) I used a thin gel instant adhesive ( gorilla glue) placed a thin bead and had no extra squeeze out. I clamped it with 4 hand clamps and left it over night. It seems to have worked. If it comes off again. I try your suggestion of
Marine grade goop. Thanks for the reply
