Heated Steering Wheel not very warm - Bimmerfest - BMW Forums
Old 12-12-2014, 10:44 AM
jojobebe jojobebe is offline
Jojobebe
Mein Auto: 2012 Z4 35is
Purchased a 2014 528I this summer with the cold weather package. Started using the heated steering wheel, however, it does not get very warm. What should I expect? I cannot even feel the heat if I wear a thin pair of gloves. Appreciate feedback from others who have one.
Old 12-12-2014, 10:45 AM
armoredsaint's Avatar
armoredsaint armoredsaint is offline
Mein Auto: 2018 M5
same here, compared to my other car. but the seat heaters are very hot.
2015 F10 535i xDrive ///M-Sport / Carbon Black / ///MPerformance Exhaust
2013 F06 650i GranCoupe xDrive ///M-Sport / Black Sapphire
Old 12-12-2014, 10:50 AM
Jojobebe
Agreed, the heated seats can get very warm
Old 12-12-2014, 11:22 AM
DieselJunkie DieselJunkie is offline
Mein Auto: 2018 F90 M5
I don't think I would want mine any warmer than it gets, but then I'm not wearing gloves. It was 25 here this morning and both the steering wheel and seats were warm and cozy.
Old 12-12-2014, 11:42 AM
Jojobebe
Thanks, mine is hardly noticeable without gloves. Sounds like I need to bring it into BMW to be checked.
Old 12-12-2014, 12:02 PM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
The whole idea of heated steering wheel is that you don't need to wear gloves. I would say if you cannot feel the heat without the gloves, then you have a problem.
Old 12-12-2014, 12:10 PM
wrickem wrickem is offline
Mein Auto: '19 G05, 07 M6
+1.
My steering wheel gets warm and I don't even need to see the light and know that it's on. I don't wear gloves when I am driving though. It's not Lava-hot like the seats on high, but since there's only one setting I wouldn't want it that hot anyway.
current - '19 X5, '19 911, '17 Jeep Wrangler, '07 M-6
Old 12-12-2014, 01:12 PM
north of 60's Avatar
north of 60 north of 60 is offline
Mein Auto: 535 xdrive
Mine get very warm , and I have to turn it off , and it seams that as the car warms up it cools down . Thermostat kicks in ?
The drivers seat heating element has been replaced twice , the shelf only stays very warm / hot on the 3rd and 2nd settings , on
the lowest setting then it goes cold -
The passenger seat front shelf stays on , on all 3 settings warm , very warm , hot .
It's possible that the steering wheel , the seats and the STOP / GO gas saving mode , A/C default switch are all tied to the same
thermostat . I think this because of the way they all function / or turn themselves {A/C} off as the temperature drops .
BMW is constantly up-dating the computers on the i drive , so it's worth a check to see if there is an up-date to correct this .
Old 12-12-2014, 01:18 PM
Dodge DeBoulet Dodge DeBoulet is offline
Mein Auto: 2014 535i XDrive
With mine I can feel the heat within 15 seconds or so, and it gets uncomfortably warm after a few minutes. I don't leave it on once the steering wheel has reached body temperature.
2014 Dark Graphite Metallic BMW 535i XDrive
Date Purchased: 07/02/2014
Options: Cold Weather Package, Driver Assistance Package, Multi-Contour Seating, Premium Package, Black/Dakota Leather Upholstery
Old 12-12-2014, 08:35 PM
drkeng's Avatar
drkeng drkeng is offline
Mein Auto: 2014 435 'vert
mine gets quite warm, but it takes a few minutes to feel it
I usually turn it off
seat heat is great; some had said it wasn't as good as in the past, but I think it is as good as my E93
[SIGPIC][/SIGPIC]
2018 M4 Tanz Blue
Old 12-12-2014, 09:10 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2018 540i
Another vote for the steering wheel heat is definitely felt. As others said, with 1 setting, I think it's about perfect. I feel it heat within about 30 seconds, takes maybe 1.5 minutes to reach full temp. I too usually turn it off once it warms up -- the wheel cools a bit but never gets as cold as it was sitting for hours. Sounds like the OP has a problem that needs checking.
Oh, one more thing. I haven't proven this or anything, but I wonder if the amount of heat is related to outside, or cabin temp. Reason is, I've sometimes thought the wheel seemed warmer when it was very cold -- maybe my hands are just colder and the wheel feels warmer.
BMW-CCA
Bimmerfest Supporting Member
Current: 2018 540i MSport | Med Blue/Cognac| MSport Brakes | Multi-Contour | HK | ZLP
Prior: 2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather
Old 12-12-2014, 09:27 PM
FastMarkA FastMarkA is offline
Mein Auto: 2015 X5 3.5x
I can feel the heat in my F10, but in this car the heat isn't as noticeable as my previous F10 (regular Sport, not M-Sport).
And my E60...in the words of Alicia Keys...that steering wheel was on fire...
2008 535xi 6-sp - Blk Sph, Blk Dkta,---2011 535xi - Jet Blk, Blk Dkta, Alum----2014 535xi - Jet Blk, Blk Dkta, Alum Hex
Bamboo | Prem | Cold | Sprt Pkg | Nav -Prem | Prem 2 | Cold | Sport | SAT ---- Cold | DA & DA+ | LED | M-Sprt | SAT | Multi
iPod/USB | Sat | Fld Dwn Seats --- ----Fld Dwn Seats | Side/Top Cameras -- ---HK Audio
Htd Rear Seats | PDC | 18" | Logic7 -- ---
(Good riddance!)
Old 12-12-2014, 09:38 PM
slick316 slick316 is offline
Mein Auto: 2018 X3 M40i
Doesn't get cold enough in Oklahoma for me to need the heated steering wheel, but I've used it a couple times to see what it was like when the weather got cold enough. I would describe mine as warm, but spotty. Maybe if I left it on longer the heat would have spread across the entire steering wheel, but I was basically only able to feel it in certain spots.
The heated seats on the other hand, wow, good thing I can change the distribution of the heat in iDrive. I don't need my butt to get that hot!
Former: 2012 BMW 550xi M Sport, 2015 Corvette Stingray Z51 Coupe, 2017 Mercedes E300 4Matic
Present: 2018 BMW X3 M40i
Old 12-13-2014, 07:57 AM
markl53's Avatar
I have the standard steering wheel (unfortunately, not the Sport wheel), and it pretty much gets the same warmth all around. However, there is no heating other than the rim itself, so when your hands touch other areas, like where the spokes meet the rim, you still feel coldness. I don't think this is really a fault, but the difference in temperature at those points is very noticeable. Otherwise, I find the temperature is pretty much the same across the surface. I actually wouldn't want the wheel to get hotter than it does.
For the seats, and I learned this with my first '11 535i, the seats work differently from my previous '05 and '08 3-series. That is, they heat up unbelievably fast, compared to most other cars, but they give the initial impression that they're going to roast you, even on the lowest setting. I think this is more like a "preheat" function. After a few minutes, the temperature reduces to a lower, more constant level. When it's really cold here (like 20's), I start the seat on level 2 just until I feel a little heat, then back down to 1.
BMW-CCA
Old 12-13-2014, 01:42 PM
I didn't realize the heat could be redistributed. I just played with mine and now it's more to my liking.
This car has lots of surprises.
Old 12-13-2014, 04:29 PM
Spartan01's Avatar
Spartan01 Spartan01 is offline
German Engineering Junkie
Mein Auto: 2015 535xi
I actually like how warm the seats can get. It keeps my lower back comfortable
https://www.bmwcca.org/profiles/bmwcca/themes/bmwcca/bmwcca_logo.png
Member ID: 526116
Old 12-14-2014, 05:54 AM
Where are the heat distribution controls? Thanks
Old 12-14-2014, 06:36 AM
You go to iDrive, climate, Seat Heating? Then you can adjust what proportion to both the back and seat.
Old 12-14-2014, 06:52 AM
Originally Posted by dieseljunkie View Post
you go to idrive, climate, seat heating? Then you can adjust what proportion to both the back and seat.
ty
Old 12-14-2014, 07:00 AM
markl53's Avatar
This has been discussed before. My '14 535i (and '11) with standard seats does not have this feature. I think it might only be on the 550i with the Executive package, or some other item that also provides the extra distribution capability.
BMW-CCA
Old 12-14-2014, 10:05 PM
BMW Obsession BMW Obsession is offline
Mein Auto: 2011 F10 M Sport xDrive
My '11 535i M Sport has this feature.
2011 F10 BMW 535i Sport xDrive - Alpine White/Black/Anthracite - Cold Weather Package - Premium Package - Premium Package 2 - All Black Front Grilles - Color Matched Reflectors - M5 Rear Spoiler - 35% Huper Optik Ceramic Tint - Xpel Clear Bra
Old 12-15-2014, 06:10 AM
Must be a LCI multi-contour seat feature, my 15 with MC seats has it, but my 12 with MC did not. My bad back thank you for pointing this wonderful feature out to me.
Old 12-15-2014, 09:10 AM
My '14 LCI 535ix has Multi-Contour seats, and the seat-to-back heat ratio is adjustable in iDrive. So yes, the feature appears to be tied to MC seats (at least in later models).
Old 12-15-2014, 10:28 AM
Art234 Art234 is offline
Mein Auto: 2014 535d x drive
I have also noticed that the heat on the steering wheel of my '14 535d is not as strong as it was on my '11 535i. It took much longer to warm up, then didn't get as warm.
Old 12-15-2014, 03:20 PM
ManiZ ManiZ is offline
Mein Auto: F10 550i xD
As does my '11 550 non-M Sport. It may be either a Premium package or Convenience package feature (at least for MY11), I have those two.
On a side note, the title of this thread could win a 'First World Problem' award if those were given out
2018 M4 Coupe 6MT
