850 steering play - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 8 Series - E31 (1989 - 1999)
Old 04-01-2019, 04:28 PM
Sundancer Sundancer is offline
Mein Auto: '93 850Ci, '97 328is,
850 steering play
I have the dreaded speed wobble going on on braking, I've started replacing the upper and lower control arms, the steering link, the center link, tie rods...
I've noticed some play in the steering box, can this be adjusted by tightening in on the bolt that controls backlash? Any advice would be appreciated....
Old 04-17-2019, 10:49 AM
redandgearhead redandgearhead is offline
Mein Auto: 525i
Are you SURE it isn't the brake discs? You have changed so much and nothing has changed the shake.
Here is a link to an online 1994 BMW manual on a BMW site. It should discuss what that nut does on the box. On GM steering boxes, the nut on manual boxes will tighten up the play, but on power steering boxes, all it does is add friction.
https://www.bmwtechinfo.com/repair/main/721en/index.htm
Similar Threads
2004 m54 Steering wheel play stephthebarberq E60 / E61 (2004 - 2010) 3 07-24-2018 05:47 PM
Variable sport steering SergeyM F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 6 07-06-2018 12:17 PM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
M Sport Steering Wheel vs stock M-Technic js19707 5 Series 11 05-20-2003 09:31 PM
325 not eligible for steering retrofit? hmr 3 Series & 4 Series 4 12-04-2002 06:53 PM
