Interchangable tires? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Old 06-02-2020, 04:49 AM
listerone listerone is offline
Oil Burners Rule!
Mein Auto: 2018 540d
Recently got a huge gash in the sidewall of one of my tires (original equipment Pirelli).I found a new replacement...exact size,run flat,etc...that came off a Mercedes (code "MOE" which,I assume,means Mercedes Original Equipment). Will there be any issues placing it on a BMW rim? IOW,are there any small,subtle differences between Mercedes and BMW rims that would lead to problems?
TIA to all who reply.
Current: 2018 540d / Sapphire Black Metallic
Formerly: 2014 328d / Mineral Grey Metallic
Formerly: 2011 MB E350 Bluetec / Palladium Silver
Formerly: 2009 335d / Monaco Blue
Fuelly
Old 06-02-2020, 06:16 PM
wcr3d wcr3d is online now
Mein Auto: 2013 535iX M Sport
If you are talking about the tire, no.
If the rim, yes.
Old 06-03-2020, 10:57 AM
LMC's Avatar
LMC LMC is online now
Mein Auto: BMW & Porsche
You do not specify that the new replacement is also the exact model of tire that is on the car. Pirelli no doubt makes multiple tire models in your size. Gotta be the same model. The MOE should not matter.
Larry
BMW CCA #115780
Old 06-25-2020, 08:39 PM
ard ard is offline
Resident Curmudgeon
The issue isnt the rim or fitment on the rim...
the issue is that the overall tire size, specifically the 'revs per mile' will almost surely be different between two different manufactures and two different tire models. Even if bth are xxx/yy-zz...they WILL be slightly different. This can burn up your diff, even create handling issues.
OEM is not what BMW sells
