Water spilled in trunk 320ix 2014 - Bimmerfest - BMW Forums
Old 08-07-2019, 03:39 AM
bugey32 bugey32 is offline
Mein Auto:
Greetings I have an accident that spilled about 3 gallons of water in my trunk last week. I tried to make it dry as much as I could by pumping the water out of the compartment where the electronics are and use tons of paper for absorbing. but never blew with dryer. Here are the issues:
-The iDrive & radio die (blackout). /// It came back to work after 2 days. and work perfectly!
-Both of the windows in the back are malfunction (won't go up or down).
-The trunk won't open.
-The tail signal won't blink when turning, the front would blink rapidly.
-The brake signal works fine
-connected drive on apps is not working
-the car start run fine
I went to the local mechanic for basic inspection, they said my whole control module is fried and need to be replaced and reprogram. They suggest me to trade-in instead of repair it??
I appreciated the help. Thanks!
Old 08-07-2019, 05:42 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
Try drying the trunk with a fan. A chance of reviving other electronics.
Old 08-07-2019, 05:48 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
A chance only. Modules are quite sealed, high concentration water diffuses in easily, low concentration vapor barely diffuses out. Plenty of time for corrosion.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 08-12-2019, 07:55 PM
Mein Auto:
I went to the BMW dealer. They said I have a short in K-can, and it should be an easy fix for them.
Old 08-13-2019, 02:00 PM
namelessman namelessman is online now
Mein Auto: bimmer
Thanks for followup. Make sense dealer/tech also check for any corroded connectors and such and replace as needed.
2014, 320i, water
