Whirring Noise from Front Decelerating On Highway - Bimmerfest - BMW Forums
Old 08-10-2019, 09:20 AM
heliskiier heliskiier is offline
HAVOC 2 YOU
Mein Auto: 428xi Coupe
Question Whirring Noise from Front Decelerating On Highway
OK I've got a 14 428 x drive with M sport coupe. I've been hearling a low whirring/whining sound from the left front, but only when coasting down from around 70 or so on the highway. I have zero vibration and no effect on the handling. I've only got 40k miles. It's not grinding and there is no vibration. I've got new pads so it's not the brakes. It's weird.
Has anyone else had this problem? It ONLY happens when I let off the gas and coast on the highway. I've experienced bearing issues many times and it's doesn't share the issues when bearings go. Typically bearings are a high mileage car issue IMO.
Anyone? It's weird and irritating, but no issue with handling or other.
2014 428i X Drive M-Sport Coupe
2007 Saab 9-3t Anniversary (retired-window motor issues)
2000 Camaro SS road course setup. (pure unadulterated insanity)
Old 08-11-2019, 02:27 AM
El_Quandro El_Quandro is offline
Mein Auto: F30 335IAX
I had the same issue with the bridgestone potenza s001 rft
It went away after changing the stock runflat tires to ps4.
Probably when the tires are at a certain % worn the issue occurs
Old 08-11-2019, 06:09 AM
HAVOC 2 YOU
I have replaced all 4 with non RFT's. I did replace the fronts about 7k miles before the backs. If it's just a bit of noise I have little problem with this. Just trying to see if it might be something more sinister. I put Continentals on to replace the RFTs BTW.
