Why are transmission pan bolts included in trans service kit? - Bimmerfest - BMW Forums
Old 08-12-2019, 01:14 PM
Kestas Kestas is offline
Mein Auto: 2015 320i
In my opinion, the only time a transmission pan bolt is needed for purchase is if you lose one or horribly mangle it. So why are transmission bolts routinely sold with the service kits? It seems like a waste. My 2015 320i is new to me; I haven't dropped the transmission pan yet.
Old 08-12-2019, 01:27 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
One time use due to being made of aluminum I believe. Not made to be accurately torqued a second time.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 08-12-2019, 01:48 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
+1
A second torqued use will be as accurate, but the screw may break.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 08-12-2019, 01:49 PM
Okay, that would make sense. Weird though... why not use steel? Using this logic, why doesn't BMW make all fasteners from aluminum?
Old 08-12-2019, 02:35 PM
Might be a corrosion issue. Aluminum resists corrosion and does not get rusty. Steel bolts would. I wouldn’t want anything rusty on my transmission pan.
Old 08-12-2019, 03:02 PM
Aluminum is anodic to steel. May I remind everyone of the problem with aluminum fasteners on the power steering unit.
Old 08-13-2019, 07:55 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Indeed it is. Do you think the the 8HP's housing is made of steel?
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
Old 08-13-2019, 08:42 AM
What is the 8HP? Is that the steering unit? If it was made of steel, the problem for aluminum corrosion would be even worse.
Old 08-13-2019, 08:56 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
Interesting info here. Based on this article it may very well be a case of a BMW engineer deciding “better safe than sorry” to replace a $2 bolt vs a $4000 transmission.
https://www.portlandbolt.com/technic...reusing-bolts/
Can a bolt be reused? If so, what grades and in what scenarios?
A bolt that has already been used in a given application may or may not be reused, depending on the grade, application, and recommendation of the “Engineer of Record”. There are a tremendous number of conflicting opinions on this subject, but the only definitive published information we can find on this issue from a reputable source is in regards to ASTM A325 and A490 structural bolts.
According to the Research Council on Structural Connections, Section 2.3.3:
“Reuse: ASTM A490 bolts and galvanized ASTM A325 bolts shall not be reused. When approved by the Engineer of Record, plain finish ASTM A325 bolts are permitted to be reused. Touching up or re-tightening bolts that may have been loosened by the installation of adjacent bolts shall not be considered to be a reuse.”
“Pretensioned installation involves the inelastic elongation of the portion of the threaded length between the nut and the thread run-out. ASTM A490 bolts and galvanized ASTM A325 bolts possess sufficient ductility to undergo one pretensioned installation, but are not consistently ductile enough to undergo a second pretensioned installation. Plain ASTM A325 bolts, however, possess sufficient ductility to undergo more than one pretensioned installation as suggested in the Guide (Kulak et al., 1987). As a simple rule of thumb, a plain ASTM A325 bolt is suitable for reuse if the nut can be run up the threads by hand.”
When reusing bolts, it is critical to involve an engineer since the reuse of the fastener depends on a variety of factors including bolt type, application, grade, finish, installation method, etc. If the bolts have been tensioned beyond their yield point, they enter the “plastic zone” (where they elongate and do not contract once the load is removed), which means they may be subject to premature failure. Since it is virtually impossible to determine visually if a specific fastener has entered its plastic zone when previously used, the decision to reuse a fastener will be determined by the price to replace it versus the potential cost and/or liability of that fastener failing.
Spending a few hundred dollars replacing structural bolts supporting an overhead sign structure on the freeway makes sense when evaluating the potentially devastating consequences and liability involved in reusing bolts that may ultimately fail. On the other hand, attempting to reuse a few hundred dollars worth of bolts instead of replacing those fasteners on a noncritical pump or other piece of equipment might make sense when a failure would only result in the piece of equipment not working.
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
Old 08-13-2019, 09:10 AM
Zeichen311's Avatar
Sorry for the jargon: 8HP is the family model number of the ZF 8-speed transmissions. The 8HP has an aluminum housing; hence, aluminum screws to attach the pan.
BMW CCA
Old 08-13-2019, 09:11 AM
No, no, no. Though a good article, chiefneil, it plays strawman and doesn't address the question of why aluminum and not steel. For many decades, the motoring public has been just fine using steel bolts into aluminum housings for transmission pans, which were reusable for the life of the vehicle and beyond. For some reason BMW went with aluminum. If they really wanted to be safe and not sorry, use steel bolts for the sake of a $4000 transmission.
