Rear Camber Tire Wear: Alignment or Refresh? - Page 4 - Bimmerfest - BMW Forums
Old 09-06-2019, 04:28 PM
primem primem is offline
Mein Auto: 2005 x5 4.4L
overall the tires are done. the left rear tire looks toe scrubbed to me...you can see the featheredge pattern on the inside of the tread. if I was dishing out four 4 new tires. I want to make sure my suspension has no loose components and the alignment is done on new tires not worn out tires.
brc5 you can check for play in the rear ball joints...It's no different than any other independent rear suspension. Why replace good parts?
Old 09-06-2019, 04:30 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
Agreed. That’s what made me suspect worn suspension parts. The tire on that side was doing the same thing before my alignment. Probably exacerbated by thousands of highways miles at the speed causing the worn suspension to have the most symptoms.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 09-06-2019, 04:48 PM
maybe worn parts or bad toe setting. you can still get toe wear with no loose parts. springs sag over time (unless you have air springs). When springs sag...the ride height lowers...this forces the toe to go negative.
Hopefully, the alignment shop did a pre-aligment inspection for worn parts...Its part of an alighment. I think they put to much toe in it. I would have put everything on the target. You best keep an eye on it. Once a toe wear pattern sets...the tires are noisey and the pattern is there for the life of the tire.
Old 09-06-2019, 06:00 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
I am sure that they put in what toe was ordered.
Oh, you didn't order a toe-in setting. Tsk tsk tsk.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 09-06-2019, 06:02 PM
As I reported earlier I had it readjusted. They were able to hit .02 both sides. I reported it was re adjusted. Not to what. This is with .02. I did request. They wrote the order note incorrectly and I’m guilty of not checking.
Old 09-06-2019, 06:43 PM
I had a second look at the specs...I was mistaken, its not as bad as I thought. Its a tight spec
ideal is 0.14 total toe and its set at 0.20
+ 0.10 degrees... probably works out to 1/16 of an inch toe in.
if the toe wear was there before the alignment correction...the toe wear i'm seeing is probably from b4 the correction.
Old 09-06-2019, 06:56 PM
New matching tire to the passenger side was installed right after the alignment and before the thousands of miles.
Old 09-06-2019, 08:59 PM
ard ard is offline
Resident Curmudgeon
i think i am officially lost in this thread...
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 09-07-2019, 04:22 AM
Long story short. Toe was readjusted to .02 on both rear sides. What you recommended correct? After 5,000 miles or so of highway driving, I have accelerated wear on both rears. Just looking for the cause. Seems like suspension parts but would like your opinion.
Old 09-07-2019, 03:56 PM
one new tire on an AWD. do you hate the ptu.
Old 09-07-2019, 04:12 PM
“New matching tire” = identical tread. I’m not that dumb
