vtg supply control unit terminal 30 53fc - Bimmerfest - BMW Forums
Old 09-11-2019, 12:08 PM
deodath deodath is offline
Mein Auto: x5
good day need some help please thanks keep getting this code on my x5
Old 09-11-2019, 06:42 PM
ard ard is offline
Resident Curmudgeon
transfer case gear drive perhaps?
OP- only a code? no lights, no warnings, no nothing else????
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 09-11-2019, 06:57 PM
Mein Auto: x5
yes the 4x4 light is on and i did change the transfer case gear drive
Old 09-11-2019, 09:50 PM
ard ard is offline
Resident Curmudgeon
did you not think that might have been useful to include in your initial post??????
i wont play this game. best of luck
Old 09-12-2019, 03:56 AM
DEADF15H DEADF15H is offline
Mein Auto: 01 325i sedan 222,222 mi
Read through this thread, it should help.
https://r.tapatalk.com/shareLink/top...ink_source=app
Sent from my SAMSUNG-SM-N910A using Tapatalk
Old 12-25-2019, 04:51 PM
rabbiii rabbiii is offline
Mein Auto:
Im having the same problem with my X5 E70, the same code and my 4x4! and DSC lights are on, the fwd is disabled so its rwd only, i replaced my TC motor with no luck, so its not that, the original one didnt even have stripped teeth, im also getting code 55C6 "Message (wheel speed, 0xCE) error, receiver VTG, transmitter DSC" but im guessing thats just because the dsc module is confused cause its rwd, i've opened the oil plug on the TC where i could see the chain and it seemed like it had good tension and when i hand turned the front driveshaft the chain moved so i think the TC is fine and both front wheels moved aswell so the front drive must be fine. So now im thinking that its the transfer case module, although from what ive read its very rare that those fail. is it possible that its a bad battery? can i lose fwd just because of that?
Specs: X5 E70 3.0D 2009 driven: 122.xxx km
