Tire Pressure Too High? - Page 2 - Bimmerfest - BMW Forums
Old 09-25-2019, 07:05 PM
Pete_NZ Pete_NZ is offline
Mein Auto: E61 530D E91 330d E46 328
Nitrogen vs air. If someone suggests they fill their tires because of an apparent "massive" variance in pressure over temperature changes consider this: The owner's manual and door card stipulate cold pressures. They also know that cold pressure thus gives the correct pressure when at operating temperature.
So here's the rub.. if you're filling with Nitrogen because you believe it minimises cold to hot pressure variance, then by necessity of your argument you are running pressures at operating temps that are lower than recommended by the manufacturer.
Boom! Air-roasted.
Old 09-25-2019, 07:11 PM
Originally Posted by Autoputzer View Post
How old is that BFG report? I can remember when passenger car tires took 20-something PSI of air... back in the 1970's.
1980
https://www.jstor.org/stable/4463244...n_tab_contents
Autoputzer Autoputzer is online now
Boom! Air-roasted.
The charges for nitrogen are sort of a tax on those who weren't paying attention in high school physical science class.
I had somebody tell me he has them put nitrogen in his tires because it makes the car ride better.
Old 09-25-2019, 07:16 PM
That's a pretty cool link... read six SAE papers free each month.
As expected, the article is from before the "P Metric" generation of high-pressure passenger car tires.
Old 09-26-2019, 05:19 AM
surly surly is offline
Mein Auto: '11 F10 535xi
That's a myth, probably mostly propagated by tire salesmen selling nitrogen.
Dry air and nitrogen both obey the Ideal Gas Law. Air with a lot of water vapor in it would deviate slightly from the Ideal Gas Law. The Ideal Gas Law is where Dougie's "ten degrees F equals 1 PSI" rule of thumb comes from.
Huh? I said the pure nitrogen difference is "very minor", meaning the promotion of using nitrogen to reduce pressure variance is bogus, which agrees with what you say.
Ambient temperature certainly does have an effect. One mid-winter weather system and a few psi are lost or gained.
I don't understand why my statements are "myth" and "bogus".
Old 09-26-2019, 06:55 AM
O.k. Then, what you said could be taken two ways and I picked the wrong way.
Dry air and nitrogen both closely follow the Ideal Gas Law: PV=mRT, where:
P = Absolute Pressure (gauge pressure plus the pressure of the atmosphere)
V = Volume (inside the tire)
m = mass of the gas
R = The Ideal Gas Constant (for the particular gas)
T = Absolute Temperature (Kelvin or Rankin, not Celsius or Fahrenheit)
If you assume the volume inside the tire is constant, the V, m, and (pertinent to our discussion about nitrogen) R all cancel out and you get:
P1/P2 = T1/T2 or P2/P1 = T2/T1 or P2 = P1 (T2 / T1)
Plugging in the Ranken to Fahrenheit conversion and adding the ambient pressure at sea level (14.7 PSI):
P2 = [(P1 + 14.7)(T2 + 459.67)/(T1 + 459.67)] - 14.7
Pick a starting pressure (P1) and temperature (T1), and then vary the temperature (T2). The new pressure (P2) will go up or down about one PSI for every ten degrees F. Here's a table starting with a gauge pressure of 35 PSI and an ambient temperature of 70F, and then varying the temperature from 30F to 110F.
Name:	20190926 ideal gas law starting from 35 psi & 70F.jpg
