Best place to hook up a battery charger - Bimmerfest - BMW Forums
Old 04-22-2018, 08:05 AM
chitown312 chitown312 is offline
Mein Auto: 2011 x5 v8 M adapative
With the IBS in mind where is the best place to hook up the CTEK battery charger?
The shop manual states "to prevent the intelligent battery sensor from malfunctioning, use the charging points in the engine compartment."
I have a 4 year old battery that I want to replace. It works fine except when I try to listen to the radio (play with the options) for 1-2 minutes with the car off, at that point the battery light comes on. I have the upgraded ~16 speaker package so I assume the battery draw is high. Wonder if a new battery would buy a few extra minutes or if the CTEK charger will allow me to listen to the radio indefinitely with the car off if i'm hanging out in the garage.
Old 04-22-2018, 09:36 AM
edycol edycol is offline
Mein Auto: X5 35d (traded in)
Hook it where manual says.
Old 04-22-2018, 10:05 AM
I guess I should just read the manual and take it to BMW for every service too.
Old 04-22-2018, 10:19 AM
ard ard is offline
Resident Curmudgeon
Your car, your call....
Next!
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 04-22-2018, 10:37 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Originally Posted by ard View Post
Your car, your call....Next!
+1
There are reasons to let the Intelligent Battery Sensor see every Coulomb through it, charge and discharge, and their rate. The IBS is first a Coulomb counter reporting to the ECU. Coulomb rate in seconds is amperes.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 04-22-2018, 11:19 AM
ArgentoCarNut ArgentoCarNut is offline
What was that?
Mein Auto: 05 M3, '13 TLC, '11X5 35i
There are two charging points under the hood. Positive has a red plastic cover, negative is nearby.
They are on the driver side of the engine compartment.
Old 04-22-2018, 01:37 PM
ard ard is offline
Resident Curmudgeon
You have a sum total of NINE posts on Bimmerfest... Some of them (most of them) Utterly newb posts.
Yet you decide to wisemouth someone with 5000+ posts who is usually, if not always. On point with technical advice.
And in fact, in this case- as you can see by all the other people saying the same- he was spot on with his advice.
Do you understand the unique maintenance issues around the E70 V8s, battery wear and the CCP recall? You should.
Old 04-22-2018, 03:01 PM
I think it is pointless. I have a feeling this was wishful thinking post and attempt that there is someone in the crowd to confirm that wishful thinking.
Old 04-22-2018, 03:25 PM
What was that?
OP - This is a tough crowd but if you can look past that, the wealth and depth of knowledge here is akin to what you can expect in a Land Cruiser forum.
Old 04-23-2018, 10:18 AM
It is a tough crowd. I guess I'll just connect the battery charger to the engine bay terminals from time to time.
I used to work on my e46 back in the day when I had more time. Now I don't so I purchased the X5 with a Carmax warranty because I knew the v8's or just the x5's in general could have a number of big ticket repairs based on the forums. Some of the mentioned repairs are beyond my abilities. I don't have a lift for example so i can't drop the transmission to replace the rear seals.
I could care less regarding the issues with the v8, battery draw, or customer care package. I just drive it into the BMW dealer and they fix it with much cost or any to me. I've already had the rear and oil pan seal, turbos, and various suspension components replaced. I'll enjoy a perfectly sorted car for years to come without worrying about expensive repairs and will sell it one day in a perfectly mint mechanical condition before the warranty runs out.
Old 04-23-2018, 10:35 AM
ard ard is offline
Resident Curmudgeon
Option 1
Zero deductible $6800
Up to 100,000 miles - 5 years - so covered for 47,000k more
Option 2
100 dollar deductible $7400
Up to 125,000 miles - 5 years- so covered for 47,000k more
Option 3
Zero deductible $9000
Thats one way to not worry....
Old 04-23-2018, 11:01 AM
So far my warranty has paid off just getting the car sorted. Yes it was a lot. I can always get my money back based a prorating(mileage/time) if i decide to cancel it or I could even transfer it when I sell the care.
Should I have bought a newer car without a warranty, maybe. I wanted to try something different this time around and hope it works out.
50i, battery, discharge, ibs, radio, x5
