Temperature Gauge on my F10 - Bimmerfest - BMW Forums
Old 05-25-2019, 08:50 AM
dewana421 dewana421 is offline
Mein Auto: 2012 535i
Guys see the pic below. My car temp gauge only raised just a bit after driving 1.5miles. Is this normal or an indication of bad thermostat?
I have no error codes or anything but just observing. Eventually it rises to normal when i keep driving but Iím not sure how long it takes the car to reach itís normal operating temperature?
Old 05-25-2019, 08:56 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
That is an engine oil temperature gauge not a coolant temperature gauge. Looks normal.
Old 05-25-2019, 09:27 AM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: 2011 535i
1.5 miles is not enough time for the car to reach temp. While the gauge is oil temp - its a fairly linear relationship between oil temp, engine temp, and coolant temp.
As long as the car reaches the standard 240~ mark after a bit of driving, your system is normal. If it never gets past 140-180, then you may have a faulty thermostat. If it overheats, then you may have a faulty thermostat and/or water pump.
If neither, then you are good.
2011 535i
2003 745li (Sold)
Old 05-25-2019, 09:43 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Ditto...unlike BMW instrument clusters of the past (not sure what your BMW history is)...the latest (new generation) BMWs have an oil temp gauge on the far right instead of the coolant temp sensor like in the past.
You can also tell by the icon on the gauge...it has the historical BMW "oil tin" icon along with a temp scale (to indicate oil temp)...whereas the old gen BMWs coolant temp gauge has an icon that has "waves" that indicate "water" along with a temp scale....and also has blue & red color blocks to indicate cool & hot:
And there's always the explanation of the instrument cluster in the good ol' owners manual.
{old BMW instrument cluster that has a coolant temp gauge on the far right}
{BMW traditional icon for "oil"}
ID:	853041   Click image for larger version
ID:	853043   Click image for larger version
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 05-25-2019, 11:27 AM
Ahhhh all this time I have been thinking itís coolant. Kind of assumed with my E46 Bmw history. Didnít pay attention to the oil mark.
So the question is how would I know if my car heats up for no coolant or something like that?
Is it software warnings on screen?
Old 05-25-2019, 11:32 AM
ezaircon4jc's Avatar
ezaircon4jc ezaircon4jc is offline
Mein Auto: 2014 535i M Sport
You'll get an iDrive warning. And it won't be too late like an "idiot light".
Mike
2014 535i M Sport, Carbon Black/Black (mine)
2012 535i, Dark Graphite II/Oyster (wife's)
Joshua 24:15; Phil 4:13
https://www.newtis.info/tisv2/a/en/f10-535i-lim/
Old 05-25-2019, 11:33 AM
No coolant? Your car would overheat within a minute or two. Low coolant, you will get warnings on the dash and idrive. You will also get overheat warnings. Youíre gonna know pretty quick if something is wrong.
2011 535i
2003 745li (Sold)
Old 05-25-2019, 12:08 PM
QSilver7's Avatar
In regards to overheating or low coolant...see info from the owners manual (which interestingly is right below the oil temp gauge info).
(SOLD)
Old 05-25-2019, 02:05 PM
2013F10 2013F10 is offline
Mein Auto: 2013 BMW 535ix
Don't be hard on yourself, I thought the same thing and I've been working on cars and airplanes for years. If you think about it, it makes sense. Oil warms up slower than coolant so waiting until the oil temp moves off the bottom peg before you drive hard is better than relying on coolant temp.
