11' 50i N63 Valves or turbos? Need some advice - Page 2 - Bimmerfest - BMW Forums
Old 06-14-2019, 06:28 PM
B4_685 B4_685 is online now
Mein Auto:
Originally Posted by Tekken24/7 View Post
Where did you find the upgraded cross over pipe? Definitely worth a swap. I plan to do some heat wrapping when I have to go in there
Stock pipe - just replaced the y junction with stainless off amazon - will try n find link
Edit: Food Grade, 303 Stainless steel,... https://www.amazon.com/dp/B0078RP35K...p_mob_ap_share
3 stainless clamps as well is all you will need
N63 E70 X5 2012
Old 06-18-2019, 06:57 PM
Gene Horn Gene Horn is offline
Mein Auto: 2009 BMW X5 4.8 L
reaction
It seems to me that a mechanic who knows X5 BMWs could give you a more accurate diagnosis. Your guy has named everything it most likely could be. My first suggestion is to check another mechanic.
You say you see smoke both under the hood and coming out of the exhaust. Obviously, smoke coming out of the exhaust had to come from the combustion chamber. That could come from oil leaking through the valve seals or the pistons or from oil leaking from the oil cooled turbos into the air intake. Smoke under the hood suggests an oil leak not associated with combustion touching something hot enough to smoke. Since you have both, it sounds like a leak associated with the oil cooling system on the turbos.
Hopefully, it is only a hose.
The valve stems are not a major problem as long as you keep the oil level up. You could easily burn up turbo bearings if the oil cooling system is leaking.
Good luck
Old 06-20-2019, 09:54 PM
scwilsonct2 scwilsonct2 is offline
Mein Auto: 328xi SDN, 335iCPE, X5
Sounds like the current BMW campaign for the VCS! I'd suggest taking the vehicle to BMW for inspection & diagnosis and not an independent repair shop. BMW is covering vehicles provided the current owner has owned the vehicle for the past 6 months. You might still go through hoops depending on the dealership but it's definitely worth it. The job is about $8k!
Old 06-20-2019, 10:58 PM
ard ard is offline
Resident Curmudgeon
do tell.
what is this vcs campaign and what are the BMW rules about how long you need to own it before they pay for it.... a link would be most helpful
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 06-21-2019, 07:13 PM
chitown312 chitown312 is online now
Mein Auto: 2011 x5 v8 M adapative
Good luck
I would disagree with the statement that the valve stems are not a major problem if you keep your oil level high. If the seals are done they're done and oil will pass out the exhaust as blue smoke.
e46 330ci, sport package. (sold)
e70 N63, M adaptive suspension.
Old 06-21-2019, 10:49 PM
ard ard is offline
Resident Curmudgeon
I think he is saying that burning oil isnt a risk as long as you dont let the oil level run too low.
Not that keeping the oil level high will change valve stem smoking...
I think
Old 08-27-2019, 03:04 PM
trumann trumann is offline
Mein Auto: 2011 BMW X5 x50i
I replaced my hoses for the pcv for $52 for two and its fixed
Old 08-27-2019, 04:00 PM
ard ard is offline
Resident Curmudgeon
So you had:
Smoking from exhaust after engine is warmed up, heavy oil smell from the engine area after driving, sometimes it will smoke after sitting at a red light for a bit, but not always, and randomly I'd see smoke coming from the engine area like it was dripping on the manifolds.
fixed w only 2 pcv hoses?
Old 08-27-2019, 08:53 PM
Originally Posted by ard View Post
So you had:
Yes. Simple fix Click image for larger version
ID:	862585Click image for larger version
