Z4 Roadster (E85) soft top problem - Bimmerfest - BMW Forums
Old 10-19-2013, 06:52 PM
cambed cambed is offline
Mein Auto: Z4
Cool soft top problem
Hello every one. I have a Z4 2004. The soft top wont work properly. change the motor, check a soft top cowl panel switch. check the wiring but cannot find the lower and upper switch.:
Old 10-19-2013, 07:22 PM
RhoXS RhoXS is offline
Mein Auto: Z4 & X3
The Z3s (at least my 2002) have a small microswitch mounted in the convertible top frame that shuts off the hydraulic pump when the top is almost fully seated. Don't know if Z4s have the same thing but suspect they might. Not uncommon for this switch to fail or the small wire pair to break. This causes the electric pump to not work. In the Z3, the wire is routed down the main structural member behind the driver's shoulder where the hydraulic ram connects. The usual repair is to just bypass this switch, since it really does nothing all that useful, in the well behind the driver's shoulder.
