Liftmaster garage door opener - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 04-26-2017, 01:50 PM
airboss1998 airboss1998 is offline
Car poor
Send a message via Yahoo to airboss1998
Mein Auto: 2006 X3, 2009 Z4
Had an extra bay built on to the house, with a door close to the ceiling so I can add a lift. Had a garage door opener put in that installs on the door spring rod, which decreases clearance near the ceiling.
https://www.liftmaster.com/for-homes...ies/model-8500
Unfortunately, it uses a new technology (security + 2.0) which supposedly sends a new code each time I push the opener button. I'm afraid the Homelink in the 2009 Z4 doesn't work with this. Anyone know for sure? (I can't get it to pair).
Old 04-26-2017, 10:08 PM
PennBruce PennBruce is offline
Mein Auto: Z4 sDrive28i
You could install an internet gateway, LiftMaster 828LM, and control it from your phone.
My garage has a Chamberlain door opener. I had to add a HomeLink Compatibility Bridge Kit to use it with the HomeLink in my Z4. It works but the range is poor and the reaction time of the door opener is much slower.
Bruce
Old 04-26-2017, 10:51 PM
cityjohn's Avatar
cityjohn cityjohn is offline
Mein Auto: 1998 M3 . . . 2012 528i
Is there a light involved and you have to get it to go purple and blinking? I ask because I programmed one like that and if it's what you have I can try to retrieve the pairing sequence.
Old 04-27-2017, 04:38 PM
Car poor
Bruce
Thanks. Much as I hate to, I'll just clip the opener to the visor and forget the Homelink.
Old 04-30-2017, 09:42 AM
Trevon Trevon is offline
BMW Enthusiast
Mein Auto: 2012 M3
I think Liftmaster has an app to open the door from your smartphone.
"Imagination is more important than knowledge." - Albert Einstein. Trevon AKA Mini
Old 05-23-2017, 08:57 PM
Thebubbleboy Thebubbleboy is offline
Mein Auto: 2009 Z4
Homelink will work with it!
airboss,
It will work with your new opener. I have a 2009 Z4 with Homelink and have paired it with the new technology openers. (I found the information below online somewhere and would give the original author credit but I don't know who it was. Anyway, it works perfectly so give it a try!)
DIY for programming the Homelink Garage Door Opener (GDO)...
BATTERY:
'They say" it is best to have a strong battery in the remote before you program your Homelink transmitter in your BMW overhead. The reason 'they say' this is because it's a recording; weak signal in === weak signals out ('they say'). Anyone with proof ... or logic ... please advise.
RESET PROGRAMMING MODE:
You do not need to reset but you might wish to erase all buttons when you obtain the car or sell the car.
To reset all three Homelink buttons at once:
1. Set the ignition with your key to the ACC2 position (no need to start the engine).
2. Simultaneously press and hold the two outside buttons (#1 and #3) of your Homelink control unit
3. Keep holding both outside buttons until the Homelink LED flashes rapidly (this will take about 20 seconds).
That's it; the old settings are now wiped out for all three buttons.
Note: Do not repeat this step unless you wish to wipe out all existing settings!).
RE-PROGRAM PROGRAMMING MODE:
0. You can program the Homelink after a reset or you must put the Homelink into "programming mode".
1. To put the Homelink buttons into programming mode, press the desired button that you would like to reprogram and keep it pressed until the LED starts to flash slowly.
2. Let the LED flash slowly for about 20 seconds.
3. Only then (after the LED flashes slowly for about 20 seconds) should you release the button.
The Homelink system is now in programming mode.
Note: You will have five minutes to carry out the re-programming.
PROGRAMMING FOR STANDARD CODES:
This first procedure assumes a fixed code GDO (not rolling codes - instructions for which will come later).
0. Position your hand-held remote transmitter 1 to 3 inches away from the HomeLink surface (located on your overhead sunroof panel), keeping the HomeLink indicator light in view (the closer the better in most cases).
1. Using both hands, simultaneously press and hold both the desired HomeLink button (e.g., button #1) and the hand held remote's transmitter button.
2. DO NOT release both buttons until the HomeLink indicator light flashes slowly and then rapidly.
3. When the Homelink indicator light flashes rapidly, both buttons may be released.
That's it (if you have a simple GDO); the rapid flashing indicates successful training of Homelink.
Note: Apparently "Canadian Instructions" are slightly different; go figure.
HOW TO TELL IF YOU HAVE ROLLING CODES: (i.e., encrypted codes)
1. Press and hold the now-trained HomeLink button and observe the indicator light.
a) If the Homelink indicator light is solid and continuous, training is complete and your garage door should activate when the HomeLink button is momentarily pressed and released.
b) If the indicator light blinks rapidly for 2 seconds and then turns to a solid and continuous light, proceed with the following training instructions for a rolling code device.
Note: A second person may make the following steps quicker and easier. Please use a ladder or other device. The Homelink people warn "Do not stand on your vehicle to perform the next steps" (duh).
PROGRAMMING FOR ROLLING CODES:
0. Apparently, you have to do the non-rolling code stuff above first; then, if you find you have rolling codes (based on the indicator light action described in 1b avove), then proceed as described below ...
1. At the garage door opener receiver (aka, at the motorhead unit) in the garage, locate the "learn" or "smart" button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the garage door opener's manual or contact Homelink at +1-800-355-3515.
2. Press and release the "learn" or "smart" button (the name and color of the button may vary by manufacturer but a black button with a red LED is common).
NOTE: Once the button is pressed, you generally have about 30 seconds in which to initiate the next step.
3. Return to the BMW and firmly press and hold the previously trained HomeLink button for three seconds & then release.
4. Do step 3 again (they actually told me to do this when I called for help).
5. Do step 3 yet another time (just to be sure).
6. HomeLink should now activate your garage door with rolling codes.
Note: You can re-program any button at any time. If this procedure fails, you can call Homelink at 1-800-355-3515 for help (which is what I did and where additional steps above were added and a lot of my description was improved).
PLACEMENT:
1. To train, some remotes must be placed directly in front of the transmitter.
2. Others at a distance of up to 30 centimeters
3. In my case, I placed the remote transmitter right next to the BMW Homelink roof panel, actually touching the panel (that's what the Homelink Customer Support guy said to do - and it worked).
Note: Make sure your battery in the remote is good. This may be an old wives' tale but 'they say' it's like a tape recording'; low-volume in, low-volume out.
TESTING:
1. Press the Homelink button you have now programmed.
2. If the LED is constantly lit, you have successfully concluded the programming.
3. You also should see the garage door opening (duh).
Here are some more details on programming and troubleshooting the Homelink system on the BMW:
RANGE PROBLEMS:
Poor range can be caused by interference around or near the vehicle or due to the use of older batteries in the original transmitter during programming.
Put a new battery in your hand-held transmitter. Training the HomeLink takes more power from the battery than when you push the button to open the door. Sometimes by putting a new battery in the hand-held transmitter, it does help pick up a better train and increases the range.
Retrain the HomeLink at different lengths and angles. Start by holding the hand-held transmitter 3-4 inches away then 5-6, even 6-8 inches from the buttons. Sometimes this helps pick up a better train to HomeLink.
Try a second transmitter with new batteries.
Straighten the antenna wire that hangs down from the garage door opener motorhead.
FREQUENCY:
HomeLink is an integrated transceiver (a transmitter and receiver) that can be programmed to activate radio frequency (RF) devices such as garage doors, estate/community gates, entry door locks, home/office lighting, or other RF devices.
HomeLink is compatible with radio-frequency devices operating between 288 and 399 MHz (exclusive of the restricted 322-335 MHz range). Select 2007 and newer vehicles are compatible up to 433 MHz (exclusive of the restricted 400-410 MHz range).
COMPATIBILITY:
Please contact us by email or phone (1-800-355-3515) to verify vehicle compatibility.
TROUBLESHOOTING:
You can either call our customer service number (1-800-355-3515) or contact us by email for complete programming assistance. First try the following troubleshooting tips:
Check the frequency of the device's hand-held transmitter (usually found on the back). HomeLink is compatible with radio-frequency devices operating between 288-399MHz (some 2007 and newer vehicles may be compatible up to 433MHz. Please contact us for vehicle compatibility).
Put a brand new, store bought battery in the hand-held transmitter. During the programming process the battery's energy tends to drain (more so with an older battery). A new battery will increase the speed and accuracy in which the hand-held transmitter sends its signal to HomeLink.
Retrain HomeLink holding the hand-held transmitter at different lengths and angles from the HomeLink button you are trying to program. Try 4-6 inches away at a different angle.
Cycle the hand-held transmitter during programming: Press and hold the HomeLink button while you press and release the hand-held transmitter every 2 seconds until the indicator light changes from a slow blink to a rapid flash.
To verify HomeLink has programmed, press and hold the HomeLink button and observe the indicator light:
o If the indicator light remains solid, it has picked up the signal and should operate the device.
o If the indicator light blinks rapidly for two seconds and turns solid, HomeLink has successfully picked up the rolling code signal. Please follow the rolling code instructions outlined in the "programming a garage door opener" section to complete the process.
o If the indicator light remains a slow blink, HomeLink has not picked up the signal from the hand-held remote. Try programming the button again or choose another button to program.
thebubbleboy
Old 06-26-2020, 03:03 AM
Amy Young Amy Young is offline
Mein Auto:
Where can I find a receiver for my garage door?
Old 06-26-2020, 07:38 AM
I'm not quite sure what you are asking.
If the question is how do i add wifi to a garage door opener then this article should help.
https://www.allstyledoor.com/blog/ad...e-door-opener/
Bruce
1991 Miata
2009 335i (E93)
2016 Z4 sDrive28i
Old 06-26-2020, 06:16 PM
Rlajoie Rlajoie is offline
Mein Auto: 2016 Z4 sDrive 35i
I have a lift master and I got my BMW Z for 2016 to work it was a video online but I can't find it but the key to it is there's a button on the lift master that's learn your car signals you have to push it during the set up push that button search the Internet and you'll find a video on how to do it
Read the article below
https://www.bankogaragedoors.com/blo...emote-control/
Be carful pressing the lead button to many times may cause it to lose its other Program
Found the video
https://www.google.com/search?q=how+...D9PwPwdiniAg38
HTML code is Off
