No audio - Bimmerfest - BMW Forums
Old 07-20-2016, 05:30 AM
Pobob33 Pobob33 is offline
Mein Auto: 2008 750Li
No audio
My 2008 750Li audio has stopped working no sound from radio or door chime, it want let me choose a radio station,cd,or auxiliary, and want pull up reverse sensor.
Old 07-20-2016, 11:32 AM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
1 of the units on your Fibre optic
Line is bad . This will cause the
Problem your having . You can
Buy a Fibre loop to find the bad
Unit by looping each unit out
1 at a time .
Old 07-20-2016, 12:33 PM
1 at a time .
thanks I think it's going to be the amp..I kept hearing noise from speakers like amp was trying to kick on when the car was parked
Old 07-20-2016, 12:42 PM
PAPER's Avatar
CRISP & CLEAN
if it was your amp . You would still have sound
from front speakers , as those are controlled by
your Ask Unit ...
Old 07-20-2016, 12:47 PM
Thanks..looks like I'll be out of some change..to take it to a shop for them to check each component
Old 07-20-2016, 02:08 PM
PAPER's Avatar
CRISP & CLEAN
you can easily do it yourself if you buy the fibre loop
from the dealer . price should be $15 to $25 maybe
for the loop ...
Old 07-20-2016, 02:12 PM
PAPER's Avatar
CRISP & CLEAN
should look like this ...
ID:	571146   Click image for larger version
Old 07-20-2016, 02:19 PM
mybmw408's Avatar
mybmw408 mybmw408 is offline
Mein Auto: BMW 750i
Before doing all of that, reset most bus
Old 07-20-2016, 02:23 PM
mybmw408's Avatar
Mein Auto: BMW 750i
No audio
With the car turned off
Open glove box unplug fiber optic loop "lollipop" leave it unplugged for 6 to 10 minutes. The "lollipop" is located behind the little door in Glove box. Plug it back in then turn on car. Sometimes these units need to be reset. This happened to me a week ago.
Everything works as it should
Old 07-21-2016, 05:03 AM
Thanks, I'm going to try and locate it..do you have the 750..just curious if I have the same door in glove box
Old 07-21-2016, 08:39 AM
mybmw408's Avatar
Mein Auto: BMW 750i
No audio
Yes I have an 07 750i
Old 07-03-2017, 03:44 PM
750Homeboy 750Homeboy is offline
Mein Auto: 2007 750LI
I may have the same problem.
But I didn't see any little door in the glove box. Maybe I didn't know what to look for? 07 750li
Old 07-05-2017, 02:58 AM
alextenerife alextenerife is offline
Mein Auto: 735i
Sounds like the fuse has blown.
Old 07-06-2019, 10:25 AM
Spectre1957 Spectre1957 is offline
Mein Auto: 750LI
Same problem
I had a xenon l/h/s bulb go out. I checked all fuses before replacement of bulb. Changed the bulb and now I too am having no audio, radio, cd, door chimes, or parking sensor.
I unplugged the lolipop as suggested and checked all fuses. 08 750LI
Old 04-22-2020, 06:37 PM
MarcoK MarcoK is online now
Mein Auto: 2008 BMW 535I
Hi, my car has no sound at all, no door chime, no warning sounds, no parking sensor tune, Navi, BT, Radio, CD are working fine, but no sound from navigation, I can pair my phone, I can make phonecall through the car, I have voice control, just doesn't have any sound. I can switch radio stations, I can use the Aux and USB.
All fuses are fine, I use Fiber Optic Loop to bypass TCU, AMP, Radio modules, nothing changed. All the fiber optic connectors have red light flashing when I unplugged them. But I found out that the AMP does not have output power(the 20 pins connect to the big harness of AMP, not sure how to describe it), so I bought one from eBay with exact same part number, put it in, leave the car on Ignition for a while, still no sound. I tried to disconnect the battery for an hour, nothing changed, I also reboot the iDrive by holding on the volume button.
I am out of ideas here, if anyone has the same problem, please please help, I really appreciate it! I just disconnected the battery for overnight, not sure it will fix it but I don't know what else to look. Looking forward to hearing your opinions, Thank you.
Old 07-04-2020, 01:24 PM
Dsparks Dsparks is offline
Mein Auto:
Can someone tell me where this lollipop is located? I have an 07 750li
Old 07-04-2020, 03:31 PM
Dalplex's Avatar
Dalplex Dalplex is online now
Mein Auto: 08 Smart Fortwo
I nearly see the end of the connector. It seems the loop has off already.
06 750 Li, Clattering noise, suspect piston 2 hits head due to spun bearing.
03 760 Li,
coolant leak from back plate.
Random misfire codes.
Old 07-04-2020, 03:32 PM
Mein Auto:
Can you indicate on my picture where please?
Old 07-05-2020, 02:02 AM
Dalplex's Avatar
May be?
03 760 Li,
Old 07-05-2020, 09:45 PM
blazen244 blazen244 is offline
Mein Auto: 2008 750 Li
Wow have any of you guys had any water problems recently? I did and had to reseal the trunk and the sunroof and a week later the radio went out while driving it did start ot work again but only for a day or so it died right after. I get what most of you are saying I did remove the small panel in the rear roof console that had a different kind of wire sloted in it could that be an issue?
