Remote trouble - Bimmerfest - BMW Forums
Old 07-02-2020, 03:09 AM
naack naack is offline
Mein Auto:
Remote trouble
Everything was fine until the unlock function on the remote stopped working.
Things I've tried:
Changed battery
Recharged battery
I got a second control coded
During the battery change it would lock and open the trunk but it will not unlock and that only worked for 2 minutes up until I thought the battery had discharges. ( Never worked again )
I thought it might be the antenna but the reason seems to catch stations no problem.
What does happen after a while of leaving the car untouched. The second i press any button on the control the pump starts for one second. "Zzz" I'm guessing this means it's receiving signal from the control ( it happened on multiple occasions)
Any ideas ?
Old 07-02-2020, 07:26 AM
kd7iwp's Avatar
kd7iwp kd7iwp is offline
Mein Auto: '01 325i, '09 535xi wagon
Research the diversity antenna and antenna amplifier on here. Very common problems. I had to replace mine to fix the remotes not working and there were countless threads I referred to. I'm sorry to hear about them problem.
Also look at threads about tailgate wiring harness failure. It's possible some of the wires have broken.
Sorry, I just realized I had assumed you have an E61, but if it's an E60 then most of my message does not apply.
Old 07-02-2020, 07:42 AM
Mein Auto:
I forgot to mention it's an E60.
I didn't think it was the antenna because the pump would start when I press the remote buttons ( the car reacts ) and both controls don't work they do start the car however I read all about the diversity antenna I'll check it out anyway.
Old 07-04-2020, 12:25 PM
Mein Auto:
ill take a video the car reacts ( wakes up power buttons lights up ) when i press any button on the fob but it doesn't do anything.
is there is there separate coding for the lock unlock buttons?
its a new style fob with start button next to it.
Old 07-04-2020, 12:30 PM
wcr3d wcr3d is online now
Mein Auto: 2013 535iX M Sport
Can you post a picture of this new fob and how you acquired it?
Old 07-04-2020, 03:30 PM
Mein Auto:
New style as in not the diamond snapped key
Both fobs start the car just fine but none of which will lock/unlock the car. The batteries are fine I've tested them also transmits signal.
The one with the erased logo is the newer key it was programmed by someone that does this for living I guess?. I cracked the new one open it seems like an original key reprogrammed to work with this cas. Is the remote programing separate with the ignition programming ?
ID:	899227   Click image for larger version
Old 07-04-2020, 03:47 PM
These aren't made to open like that.
Also a true new one would have the logo.
I'm pretty sure it takes more than CAS programming.
There are many threads here about fobs, do some researching.
I'm afraid you may have been taken.
Old 07-04-2020, 04:01 PM
Mein Auto:
It's not Comfort access but hey do unlock by pressing the button however. The original used to work then it stopped the second was made in hope that it would work if something happened to the first but no. The problem is I cannot find anyone with the same issue . I'll keep searching thanks
