100,000 KM Maintenance - Bimmerfest - BMW Forums
Old 12-25-2016, 02:12 AM
fouadg fouadg is offline
Mein Auto:
My X5 had just reached the 100,000 KM and I want to do everything to maintain my car but I don't want to send it to the dealership so it doesn't cost me a bunch of money.
therefore I would like to know from BMW users what are the things I need to check or replace in order to keep my car running perfectly.
Also, I want to know if changing the transmission oil is suggested or not since I'm confused about it.
Thanx
Old 12-25-2016, 11:24 AM
acoste's Avatar
acoste acoste is offline
Mein Auto: 2010 550i MT
engine oil & filter
air filter
cabin air filter
transmission oil
differential + transfer case oil
power steering fluid
spark plugs
fuel filter
engine drive belts
2010 BMW 550i MT
2003 BMW 325i @216k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 12-29-2016, 08:27 AM
Dash Riprock Dash Riprock is offline
Mein Auto: 2012 X5 35d
Since I had already replaced air filters, fuel filter, just prior to the 100,000 KM mark I ended up only replacing the transmission fluid, engine oil, break pads and sensors. X5 does not have a timing belt that needs replacing, it is my understanding they use a chain that never has to be replaced.
Hope that helps.
Old 12-29-2016, 10:40 AM
FredoinSF FredoinSF is online now
At that mileage consider trans fluid, differential fluids (two diffs), transfer case fluid. If coolant is still factory fill, I'd replace that too. Other things at that mileage would be spark plugs (assuming you have a gas engine, not applicable on diesel), fuel filter. While it is true these engines all have a timing chain and not a timing belt, there is still the accessory belt(s?) to consider and I like to change them at this time as well. This may seem a bit extreme, but it is the old school method that has carried several of my former BMW's into the 200k miles territory so I'm a believer. Expensive if you go to the dealer, likely less so if you can find a trustworthy independent, affordable of you DIY. I would skip the dealer.
If you want to learn more about BMW maintenance, Google Mike Miller lifetime BMW maintenance, read his white paper, draw your own conclusions and apply as you feel is appropriate.
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
Old 12-30-2016, 03:09 AM
Jethro1206 Jethro1206 is offline
Mein Auto: X5 4Di
Great read...Mike Miller lifetime BMW maintenance
100000 km, gearbox fluid, maintenance, oil, transmission, x5
