How to know if car is ripe for smog check after reconnecting battery? - Bimmerfest - BMW Forums
Old 07-01-2020, 05:51 PM
Bob2019 Bob2019 is offline
Mein Auto:
Tried to do smog check today and I was told by technicians that my car would fail smog check because car battery died and I have not driven enough miles since then. They were not able to advise me how much more miles exactly I would need to drive, but they said around 500 or in some cases even 1000 miles.
But I need smog certificate very soon because otherwise I can't renew registration in California. And with COVID19 it is really hard to ramp up miles as I pretty much don't drive anywhere else but grocery store.
So - Is there a way for me to know when car has ramped enough miles so that it is worth doing smog check again? I have ISTA/D, but not sure under which setting I could see any metrics related to smog check that could help me to know that car is ripe for smog check.
Old 07-01-2020, 06:45 PM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
You need to monitor OBD READINESS ,
A scanner will report when the various monitors have completed their cycles and are now monitoring engine systems
150-250 miles will be enough
Old 07-01-2020, 06:49 PM
dukedkt442's Avatar
dukedkt442 dukedkt442 is offline
Anti-Hack
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: 2008 BMW X3
If your systems are in good health, you can drive 50 miles and be ready. You have to vary the speed, not really go higher than 50 mph, coast down from that speed a few times, hit stop and go... really vary it. The DME has to go through maybe 10 tests for the different readiness modules, and each subsequent test wonít begin until the previous one completes. The cat ones are sometimes the trickiest to get through... itís damn near impossible in winter because some vehicles require ambient temps no less than 40*F. Took my F150 over 1000 miles to clear after I did the timing job, good thing I couldnít care less about getting pulled over. Miles donít mean anything, itís all about completing the specific tests, in order.
Any GOOD scanner will be able to tell you which readiness modules have cleared and which ones havenít. Iíd assume ISTA should be able to tell you, but I donít have any idea. I have a handheld that tells me that stuff.
Hereís how to complete the Ford driving cycle tests, which applies to pretty much any OBD2 car.
http://www.obdii.com/drivecycleford.html
The "need to have my head examined " E21 build thread
2008 BMW E83 1981 BMW 320i
2016 Chevy Silverado 2011 VW Jetta
1984 GMC S-15 1986 Oldsmobile 442
Another half dozen '60s tractors
Old 07-02-2020, 04:08 AM
I have three different AUTEL scanners , including the$25 cheapies , and everyone has obd monitor status as a function.
We keep one in every car , historical when the cars were at colleges and if they popped a code, the girls were all trained to read the code and log it
Volvo is so tricky to get readiness that several models are actually exempted by model name, my record was 2500 miles on a v70 of non-readiness
Old 07-02-2020, 05:02 PM
CoolShirtDude CoolShirtDude is offline
Mein Auto: 2011 BMW X3 2.8i F25 N52
You can pay your fees online, this will prevent you from incurring any late fee, you wonít get your sticker until the smog cert is complete. The smog check stations send the cert in electronically.
The drive cycle test as part of the readiness test also includes a cold start cycle, and an Evap test, having the tank level over 3/4 may help. Meaning itís not only mileage based.
You might also check for hard faults, mine failed due to a thermostat being stuck open last year. CA changed the requirements regarding hard faults a couple of years ago.
2011 BMW X3 2.8i (F25) N52
2015 BMW 328i (F30) N20
Old 07-02-2020, 06:20 PM
3/4 tank or less to help the evap monitor ready. Thatís usually the one that hangs up on vacuum based systems but the E83 are pump systems that are less picky.
Ac off
Keep it under 60
No full throttle operation
Old 07-04-2020, 01:22 PM
Mein Auto:
ISTA/D under "OBD readiness" shows:
Diagnosis for:
Misfiring: Yes
Fuel System: Yes
Fuel Tank Ventilation: No
Oxygen Sensors: No
Oxygen Sensor Heating: No
Catalytic Converter:No
Catalytic Converter Heater: XXX
VANOS/Exhaust Gas Recirculation: XXX
Secondary Air System: XXX
Air Conditioning: XXX
Component Monitoring: Yes
Do I understand correctly that I need to drive the car until all "No" and "XXX" change to "Yes"? Or only some subset of them need to change to "Yes"?
Old 07-04-2020, 03:50 PM
dukedkt442's Avatar
Anti-Hack
In NY weíre only allowed a single NO before failing inspection, I donít know about CA. I also donít know about the XXX, my scanner just shows yes or no. Youíll definitely need to change those NOs to YESs. Did you try the OBD2 drive cycle instructions posted earlier?
Old 07-04-2020, 04:11 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
A Technical Bulletin has just recently been posted here on BF describing the mandatory drive cycle.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 07-04-2020, 06:24 PM
Xxxx probably means that circuit isn't applicable for your car
All the other No's need to turn to Yes, correct
Those OXS should go ready right away, there is likely a problem in that circuit. You will have wait for that to fault
emission, ista d, smog check
