Do manual transmissions have a Transmission Control Module? - Bimmerfest - BMW Forums
Old 07-03-2020, 04:01 PM
SoCalJim SoCalJim is offline
Mein Auto: 2000 740i and 2004 Z4
I installed another ECU on my 2004 Z4 2.5L manual transmission car and got a P1611 code which is Serial Communicating Link Transmission Control Module. Does a 2004 Z4 MANUAL transmission have a Transmission Control Module?
Old 07-03-2020, 08:23 PM
Clearancediver's Avatar
Clearancediver Clearancediver is offline
Mein Auto: 2004 Z4, 2009 Nomad mc
Look in realoem.com using your last 7 VIN numbers.
Look under the appropriate parts diagram to answer your question. That will also tell you the correct part number if it does indicate the part is installed on your particular vehicle.
Old 07-04-2020, 10:31 AM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
It does not have a TCM. Sounds like the ECU you installed is from a car with an auto tranny and it's looking for the TCM to respond.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 07-04-2020, 04:29 PM
That is what I was thinking... but not familiar with automatics so... You can never go wrong checking out the part numbers to ensure compatibility.
Old 07-10-2020, 03:06 PM
pokeybritches pokeybritches is offline
Mein Auto: G-Power & ESS Z4Ms, VF Z4
Did you clone your original ECU? If not, how did you change the VIN?
G Power Z4M and VF Engineering Z4 3.0i
Old 07-10-2020, 03:23 PM
Uh oh... The ECU is tied to the VIN? Is there a HOWTO describing how to do that?
Old 07-10-2020, 06:29 PM
dc_wright's Avatar
VIN and mileage are stored in cluster and ECU. If you don't get the cluster set same as ECU at a minimum you'll have the mileage tamper warning in the odometer.
I don't know if you can do the settings with INPA as I haven't had to try that yet, but someone who has will likely chime in.
