All BMWs ICOM Ports Not Open for e-sys - K001 Motorbikes - Bimmerfest - BMW Forums
Old 07-03-2020, 08:37 PM
fredaroony fredaroony is offline
Mein Auto: R1200GS
I've spent hours trying to work this out and searched in here....trying not to rip out what little hair I have left lol
Using a ICOM A2 clone that worked perfect in the past with ISTA+ and e-sys 3.27. Still working with ISTA+ 4.23 but e-sys not connecting.
The previous port I used was 50160 but I can see it is not open on the ICOM. Neither is 52410.
Open ports are: 22, 80,5302,6801,6802,51560,58000,60080.
I tried using 51560 but not go.
Application firmware is 1.45.00.
Anyone seen this before?
Old 07-04-2020, 02:03 AM
dayvg dayvg is online now
Mein Auto: F10 530D MSport
Always used port 50160 with no problem at all. What does iTool Radar say?
2015 530D MSport
Retrofits: KAFAS2, TV Module, Paddle Shifters, Leather Sport Shifter, Rear Cam, Top View Cams, Folding Mirrors, Side View, Extra 12v sockets! (601, 6WB, 2TB, 3AC, 5DL, 430, 5DP, 5AT, 316, 5AG and ACC)
Retrofits to complete: Comfort Access
Old 07-04-2020, 02:55 AM
Mein Auto: R1200GS
Figured it's easier to show it. Tried reserving and not reserving..
I never had to use it before in the past and was able to connect to the ICOM unit with e-sys
Old 07-04-2020, 03:09 AM
Looks to me that the ediabas port is set to 6801.
2015 530D MSport
Old 07-04-2020, 03:15 AM
Mein Auto: R1200GS
I remember changing that a couple years ago while trying to get a K+DCAN working.
Why would cause the issue though? I can't see anywhere on the ICOM itself to change any ports and it's the ICOM itself that should be listening on 50160 right?
Old 07-04-2020, 03:19 AM
I canít comment exclusively as my ICOM worked without changing any settings. Try it? Or change the EDIABAS port back to 50160. Then see what iTool radar reports. Iím not familiar with these changes, just thought Iíd offer some help.
2015 530D MSport
Old 07-04-2020, 08:34 AM
EdgaBMW EdgaBMW is offline
Mein Auto: BMW
I had this problem couple years ago. Everything was working fine, one day ista+ connects fine, esys donít. Problem was main icom cable from obd to icom. Bought new cable and problem was solved
Old 07-04-2020, 03:01 PM
Mein Auto: R1200GS
Originally Posted by EdgaBMW View Post
I had this problem couple years ago. Everything was working fine, one day ista+ connects fine, esys don't. Problem was main icom cable from obd to icom. Bought new cable and problem was solved
Just tried that and no change. For whatever reason, the ICOM is not listening on 50160 or 52410
Old 07-04-2020, 03:02 PM
Post your ediabas.ini
2015 530D MSport
Old 07-04-2020, 03:31 PM
Mein Auto: R1200GS
I don't see what this has to do with it if I am connecting to the IP of the ICOM directly? tcp://169.254.92.38:50160
Old 07-04-2020, 03:32 PM
Just trying to help mate, thatís all. You got any better ideas? Iíll leave you to it.
2015 530D MSport
Old 07-04-2020, 03:34 PM
Mein Auto: R1200GS
Cheers
Old 07-04-2020, 04:22 PM
Mein Auto: R1200GS
I checked on another laptop that doesn't even have Ediabas installed and iToolRadar shows the same exact thing. Appear the 6801 port you see in the screenshot is actually the listening port on the ICOM itself. You can see it listens on 6801 and 6802 on it's webpage
Old 07-04-2020, 04:23 PM
Ok, well that rules out the ediabas file. So have you logged onto the icom using the web interface?
2015 530D MSport
Old 07-04-2020, 04:25 PM
Mein Auto: R1200GS
Yes and I cannot see anywhere to change/enable any ports That is what I was hoping to get an answer to by posting in here
Only ports it shows is 6801 and 6802.
Old 07-04-2020, 04:31 PM
Have you tried things like this?
https://cartechnology.co.uk/showthread.php?tid=20693
And
https://cartechnology.co.uk/showthread.php?tid=33341
2015 530D MSport
Old 07-04-2020, 04:35 PM
Mein Auto: R1200GS
And
Port 50160 on his ICOM was open, mine is not. This is what I am trying to fix
Second link
2015 530D MSport
Old 07-04-2020, 04:37 PM
ICOM and E-sys.pdf
https://mega.nz/file/r5VSwYDJ#O50OOY...hcU9kjQthyPENo
2015 530D MSport
Old 07-04-2020, 04:40 PM
Mein Auto: R1200GS
Second link
Read that too but doesn't mention how to fix it. No firewalls or anti virus running on either computer I tried it on.
It's already running 1.45.0 application firmware. Might look at a restore
I tried reserving with ItoolRadar already but if it's not listening on 50160 I don't see what difference that will make.
Suppose I could look at Easyconnect just to rule it out
Old 07-04-2020, 04:41 PM
Got nothing to lose mate
2015 530D MSport
Old 07-05-2020, 04:22 PM
Mein Auto: R1200GS
Ok finally got this damn thing working lol
My bike is a 2016 R1200GS so has the round diag plug for reference.
I had to use 'Connection via ICOM/D-CAN' instead of 'Connection via ICOM/Ethernet'. I was sure I has used the ethernet option in the past but oh well.
Port 52410 was still dead on the ICOM but I scanned the bike with ISTA+ completing the full vehicle test and could see that port 52410 was finally open. Then just used tcp://169.254.92.38:52410 under Connection via ICOM/D-CAN and it connected right away.
Reserving the ICOM in iToolRadar did not open port 52410 on the ICOM.
Would be good to know about the inner workings of the ports.
Old 07-06-2020, 01:35 AM
Glad itís working mate
2015 530D MSport
